RSS
Reply
Thread Tools View Mode
Old 20th Apr 2008, 19:58   #1
Anobis
Multimodder
Anobis is on a distinguished road
Temp name: Black Tower project [Update 16 Sep 2008]
Hi every one!
Whel this is my first ever project that i ever placed online. Hope you will like it
Ok the picture below is a ruff 3d scratch of it. So you know the ruff idea how its gonna look...... the basic lines i mean.
Hire is not put in the window front lightings switches and so on in jet. Ok it ain't so good like most can make 3d but it is something
And to make it interesting i am making this one out of something i never yous 'd ore build with be four. Namely MDF. Its cheap so i can make a few mistakes and it wont cost me a lot. I work a few times with steel aluminum and a few times with glass. But never with wood So this is kinda new to me
Ok hire is the first real built pic.
This is the under side and the side panels from the lower part.
I was end planing to make a work log. so a few pic's are missing of the work i did
__________________
Sorry four my bad English. If you feel offended by it then to bad four you!
Powerd by:
AMD 4800+ X2, 4x 500GB Sata2 Raid0, 2GB DDR, Asus Sli Premium, Asus 8800GT TOP SLI
Anobis is offline   Reply With Quote
Old 20th Apr 2008, 20:17   #2
rambo
Multimodder
rambo is on a distinguished road
he firts of all good luck with your project/log. I like te sketch it looks good and i had a program with mdf realy nice to work with. are you going to glu every thing together or are you going to use some nales or screws?
succes with the project.
rambo is offline   Reply With Quote
Old 20th Apr 2008, 20:31   #3
Anobis
Multimodder
Hire you can see the middle part. With my old stacker on top. to give a better idea of the looks. The triangle pieces art the one thats gonna be on it. this is just some junk i pud on to give a better feeling how it 's gonna look.
It is still ruff. but needs some lots more work
At this point i was thinking hwy the hell am i not yousing my old stacker It cuts down a lot of thinking and work time lol
So of this point i am yousing my stacker Hire i cut out the bottom. And made my first blunder lol. I measured it a couple of times. But stil made a bad cut
O whel no worries Got some aluminum solder. What i always wanted to try out
But thats four later.
Then after i cut out the shape out the wood.
still needs some refining do.
Hire you can see how i glued it and nailed it.
__________________
Powerd by:
Old 20th Apr 2008, 20:32   #4
Anobis
Multimodder
Glue nails and bolts
__________________
Powerd by:
Old 20th Apr 2008, 20:47   #5
Anobis
Multimodder
Hire you can see the radiator A 3x 120mm. And their gone be 2 of them in my case.
and the aluminum U is four holding and sliding a dust filter in it. And you can se the bracket i made. To make it so i can take it in 2 parts. An upper and lower half
I fount it to look to much square so i cut of the corners hire the left side.
Not bad still needs some refining. But thats four later.
But hire i made a slip. I fallen on the ground. While cutting it.
Lucky the spring is very strong. And puled the safe guard around my saw. Ore els i wood of gotten a nasty cut in my lag.
Still a nice clean cut do.
O whel nothing a bit of filler can't fix
__________________
Powerd by:
Old 20th Apr 2008, 20:58   #6
Anobis
Multimodder
Hire you can see i made the corner blocks and a few blocks to give it more strength. Still ruff but it still needs some work.
This is the good left one.
And hire the bad right one
So you can see it needs some filler. But after paint no one will ever notice it
__________________
Powerd by:
Old 23rd Apr 2008, 15:39   #7
Anobis
Multimodder
Ok small update today.
Filed the bad corner with filler and made a 45 degree strip to top off the air ducts
Still needs some sanding do.
Left side the same.
Both need some more sanding. But its getting their
Meanwhile my neighbors cat came by. She loves the attention and likes to be cuddled.
Such a sweet cat
More maby later. Need to go to the hospital. My mom has almost every thing broken on her right side. except her ribs and key bones.
__________________
Powerd by:
Old 24th Apr 2008, 21:20   #8
Anobis
Multimodder
Ok not much done to day.
I mounted the old stacker on top of the under half.
And glued the first of 4 corners on
And like all way's my neighbors cat came by. She is such a friendly cat.
Well thats four to day. I am very tired and hope tomorrow i can do something more than this
And i got some good news my mom is aloud to go to an revalidation center to morrow. She still may not walk. But she is aloud to try a few movements without resting on her right lag.
Wood be grant to she her back home over 2.5 to 3 months. And if she is lucky. the metal construction on her arm and pins will go off. Over 8 to 10 weeks. And hopefully she may go home four revalidation at home She is already 6 weeks in hospital. And it ain't no fun
__________________
Powerd by:
Old 25th Apr 2008, 05:19   #9
Ashaman
M'hael
Ashaman's Avatar
Ashaman is on a distinguished road
Looking good!
I like the idea to build out the bottom, looks cool and there is more space to put things in.
Keep up the good work, and I hope for your mom to get healthy again!
Ashaman is offline   Reply With Quote
Old 25th Apr 2008, 08:43   #10
Burnout21
is true bit-techer!
Burnout21's Avatar
Burnout21 is a glorious beacon of lightBurnout21 is a glorious beacon of lightBurnout21 is a glorious beacon of lightBurnout21 is a glorious beacon of lightBurnout21 is a glorious beacon of light
you ran out of room in a stacker! F**K me! lol!
nice, this might be an interesting mod here!
__________________
DFI P45-T2RS Plus, Q6600, 4GB Reaper HPC, GTX280 & FX3450, X-Fi Xtreme Music, 1570GB Storage
Burnout21 is online now   Reply With Quote
Old 25th Apr 2008, 14:03   #11
Anobis
Multimodder
Originally Posted by Ashaman View Post
Looking good!
The 2 3x120mm black ice exstreem rad's even with low noise fans makes a lot of air movement. So way wast it
The air will be guided from under on to the mobo. and from the sides. So the mobo hdd and every other heat making device. Will be cooled
Thanx. She shall recover. Only it will take a lot of time.
__________________
Powerd by:
Old 25th Apr 2008, 14:07   #12
Anobis
Multimodder
true thats hwy i have now a Lian Li 2000 plus plus. and even that is getting to small four me
__________________
Powerd by:
Old 25th Apr 2008, 14:19   #13
Squadexodus
I got my cookie. What about you?
Squadexodus's Avatar
Squadexodus is on a distinguished road
Dude, dont feed the cat electricity, its bad for the wires.
__________________
I blame the sun. It makes my computer short out.
http://valid.x86-secret.com/cache/banner/357403.png
Squadexodus is offline   Reply With Quote
Old 25th Apr 2008, 14:20   #14
Thacrudd
Where's the any key?!?
Thacrudd's Avatar
Thacrudd is a jewel in the roughThacrudd is a jewel in the roughThacrudd is a jewel in the rough
Paint flames on it and call it "The Towering Inferno"
I hope you mom recovers okay!
__________________
Just as you touch the lives of every life form you meet, so, too, will their energy strengthen you. Fail to live up to your potential, and you will never win... - Gaspar, The Guru of Time
Project: Andromeda
Like game/Anime music?
My Sale Thread - HERE Bit-Tech Wallpapers! - HERE
Thacrudd is offline   Reply With Quote
Old 25th Apr 2008, 14:38   #15
Anobis
Multimodder
Ok got this a few day's back. But I forgot to make pic's so i did it just few minutes a go.
On the left is the Aluminum solder. I had that stuff longer. Day say its 5x stronger then aluminum it self. So good inuf to fix my first blunder with. And you can melt it at lo temps. Ore els i have to make a few brackets
The switches on top are four the lightings. I am not going to yous them all. I was planing using only 4 and 2 extra in case of defects. But four only 1 euro more i got 10 in stead four future yous.
The blue pressure button is four power. And the red one Four reset and HDD
And later the evening after i see my mom. Ill go and build so far i can go to day.
__________________
Powerd by:
Old 25th Apr 2008, 14:50   #16
Anobis
Multimodder
Lol she wont eat it
Weird cat. You can try give her lots of jummy things that cat's like. But food noop she wont try ore eat it. But if you make a cuddling kind of movement with your hands. She even comes jumping over the fence. And runs to wards you
__________________
Powerd by:
Old 25th Apr 2008, 14:54   #17
Anobis
Multimodder
Well i was thinking of using a big sheet of aluminum I have. And make kind of old school flames. Highly polish 't aluminum on a high gloss black case.
__________________
Powerd by:
Old 25th Apr 2008, 16:25   #18
Cheapskate
know-it-all b*stard...
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
How about covering it with carpet and making it a scratching post?
-A little cat nip behind the fans...
Cheapskate is offline   Reply With Quote
Old 25th Apr 2008, 19:23   #19
brinkz0r
Supermodder? Well tnx :)
brinkz0r's Avatar
brinkz0r is on a distinguished road
You never cease to amaze me with your imagination
__________________
Find out what's in my avatar: Phase 2 Casemodding
My casemod in progress: Cubeleon
brinkz0r is offline   Reply With Quote
Old 27th Apr 2008, 15:00   #20
Anobis
Multimodder
Lol its an interesting idea
__________________
Powerd by:
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
