RSS
Old 23rd Apr 2008, 08:47   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
AMD Phenom X3 8750
http://www.bit-tech.net/hardware/200...enom_x3_8750/1
If you think quad-core is excessive but dual-core is old hat, how about a Ménage ŕ trois from AMD's new Phenom X3 8750? Is it the cheap and cheerful multi-threading meat eater enthusiasts have been waiting to lap up? We just had to find out...
Tim S is offline   Reply With Quote
Old 23rd Apr 2008, 09:56   #2
Naberius
Multimodder
Naberius is on a distinguished road
Yet more disappointment from AMD, think i will stick with Intel for a while longer.
Naberius is offline   Reply With Quote
Old 23rd Apr 2008, 10:21   #3
p3n
Hypermodder
p3n is on a distinguished road
It really doesn't seem like a huge leap for someone to take AMD's place as second best; since they are second by such a large margin now
p3n is offline   Reply With Quote
Old 23rd Apr 2008, 10:38   #4
Kúsař
regular bit-tech reader
Kúsař will become famous soon enough
Hi Tim & Richard
Great review!(as usually) and +1 for including results of overclocked CPU.
Seems like AMD should focus on core architecture to catch up with intel(or leap ahead).
I've got one question for you - I've bought Athlon X2 5000+ black ed., Asus M3-A32 MVP dlx and Corsair XMS2 at 800MHz CL4.
I managed to overclock it from 2.6GHz to 3.2GHz. I only had to rise CPU voltage to 1.325V to get it running completely stable, however I had to loosen memory timings from 4-4-4-12-2T to 5-5-5-15-2T. I would like to get mem's running at CL4 setting. Can you give me any advice on this? There are some other voltages to increase, but I'm not sure about them.
I'll be very thankful for any help.
Cheers
-K
Kúsař is offline   Reply With Quote
Old 23rd Apr 2008, 10:40   #5
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Thanks.
We were told and were expecting the CPU to be Ł90-100: basically an E6550 contender. However we waited until this morning and it's far in excess of the price we were told
Have you increased the memory voltage/northbridge voltage (if there's a specific option for the CPU-NB)?
Bindibadgi is offline   Reply With Quote
Old 23rd Apr 2008, 10:49   #6
Kúsař
That was quick!
It's the very same mobo you used(M3A32) - I think I noticed "northbridge voltage" there.
I'll try it(and perhaps report how much it helped)
Thanks!!!
Old 23rd Apr 2008, 12:04   #7
K20
Minimodder
K20's Avatar
K20 is on a distinguished road
I don't know what I'm most disappointed about: the lack of higher clock speeds, the stupid model number system AMD's using which stops them raising the clock speeds, AMDs slides saying quad was upto 20% faster than tri when we can clearly see it's >20% faster at times or the fact that Bit-tech didn't try gaming and encoding at the same time. Now so that you don't think I'm completely unappreciative of the work you do: Thank you, a nice thorough review as always.
K20 is offline   Reply With Quote
Old 23rd Apr 2008, 12:12   #8
Amon
inch-perfect
Amon's Avatar
Amon is on a distinguished road
Statistically, it doesn't seem like that bad of a processor. Lower the price about Ł25 and we've got a pretty decent chip.
And is it just me, or is the colour key for the "PCMark Vantage x64 Composite Scores" still off like it was in the last review?
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals
Amon is offline   Reply With Quote
Old 23rd Apr 2008, 12:34   #9
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Originally Posted by Kúsař View Post
That was quick!
Thanks!!!
"Northbridge" is different to "CPU-NB". I know Phenoms have the CPU-NB option which is specific to the memory controller on the M3A32
Amon - "off"?
Old 23rd Apr 2008, 12:55   #10
Amon
inch-perfect
Amon's Avatar
Amon - "off"?
Yup. E8500 and E8400 are burgundy and orange, respectively. But in the key, they are represented as blue and violet.
__________________
Old 23rd Apr 2008, 13:14   #11
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
:| strange. I'll look at it.
Old 23rd Apr 2008, 13:17   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Yep, the problem is price - nothing else, really.
Old 23rd Apr 2008, 17:49   #13
fev
Corporate Whore
fev's Avatar
fev will become famous soon enough
faiding since when has faiding been a word?!
__________________
I know what I'm doing... do you?
Follow me on Twitter..go on
fev is offline   Reply With Quote
Old 23rd Apr 2008, 18:42   #14
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka is on a distinguished road
poor AMD that can't seem to contend at all with intel on this round, definately not on price point.
metarinka is offline   Reply With Quote
Old 23rd Apr 2008, 20:26   #15
Brett89
Ultramodder
Brett89's Avatar
Brett89 is on a distinguished road
I saw the numbers and X3 and thought, what kind of crazy graphics card is this for a second. I hope AMD can get a good high end chip into the market soon, competition is so much better for the consumer, like you don't know that though.
__________________
C2D e6700 @ 3.25 Asus P5n-e SLi, 4GB of OCZ Platinum, Xonar D2, 320 and 160 GB Seagate, eVGA 8800 GTX and an Antec P182.
C2D T7500 2.2ghz, 2GB DDR2, Quadro NVS 135M 14.1in screen
Brett89 is offline   Reply With Quote
Old 24th Apr 2008, 04:46   #16
Spaceraver
Weekend Junkie
Spaceraver's Avatar
Spaceraver is on a distinguished road
so an underclocked X3 8x50 in a microatx for a htpc isn't the way to go??
pitted against a BE is it a viable option for the price??
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard.
Spaceraver is offline   Reply With Quote
Old 25th Apr 2008, 12:11   #17
xtremeownage
What's a Dremel?
xtremeownage is on a distinguished road
I have a question about AMD and ATI products. ON paper their Spec out perform the Nvidia GPUs...
400 or more stream proccessors compared to the 128 or 256. Its really wierd. Higher clock speed etc. Whats going on. They even use ddr4 and still cant beat the GTX versons of high end cards. there X2 came yes it was powerful on paper and couldnt out perform the gx2
xtremeownage is offline   Reply With Quote
Old 25th Apr 2008, 12:11   #18
xtremeownage
What's a Dremel?
400 or more stream proccessors compared to the 128 or 256. Its really wierd. Higher clock speed etc. Whats going on. They even use gddr4 and still cant beat the GTX versons of high end cards. there X2 came yes it was powerful on paper and couldnt out perform the gx2
Old 26th Apr 2008, 12:34   #19
K20
Minimodder
K20's Avatar
DAMMIT (AMD/ATI) and Nvidia have different ways of counting stream processors:
AMD counts a cluster of 4 small ones (which can't do special functions) and 1 fat one (which can do special functions) as a single stream processor.
Nvidia counts a cluster of one normal processor and one special function processor as a single stream processor.
- note that neither processor is comparable to its competitor's version.
So the total number of individual processors in:
AMD's Radeon HD 3870 - 320 SP running at 775 MHz - Total GigaFLOPS = 496. Core clock speed = 775 MHz. Mem speed = 2250 MT/s GDDR4.
Nvidia's GeForce 9800 GTX - 256 SP running at 1125 MHz - Total GigaFLOPS = 416. Core clock speed = 650 MHz. Mem speed = 970 MT/s GDDR3.
- Reference specifications. The core clock speed is what the rest of the chip (i.e texture units, command processor, output units etc.) runs at. Since both cards I've mentioned have identical ammounts of RAM and an equally wide bus to RAM, their RAM bandwidth is directly related to the speed of their RAM. GDDR4 has higher latency than GDDR3 so although it runs faster it has to do this to 'catch up', it offsets this by being able to run at higher speeds.
But the real reason for the Radeons falling behind the GeForce is the difference in texturing capacity: 12.4 GigaTexels verses 41.6 GigaTexels. I'm sure that the fact Nvidia works with almost every game developer has nothing to do with. .
Old 27th Apr 2008, 09:07   #20
maha_x
What's a Dremel?
maha_x is on a distinguished road
just proves that most stuff benefits squat from anything beyond dual cores.. Software hasn't been keeping up with these multiple cores..
maha_x is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
