RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Apr 2008, 08:02   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Working with Wireless in Linux
http://www.bit-tech.net/bits/2008/04...ess-in-linux/1
The more we cover it, the more we find that many of you are interested in getting your feet wet with the penguins. But some things just aren't that simple in Linux and one such thing is wireless networking. Our resident guru Ken Gypen takes a whack at de-mystifying what is one of the biggest pains in Linux.
Tim S is offline   Reply With Quote
Old 25th Apr 2008, 09:03   #2
Denis_iii
Hypermodder
Denis_iii's Avatar
Denis_iii will become famous soon enoughDenis_iii will become famous soon enough
A lil off topic but ... I tried Ubuntu 7.0 which stopped my cdrom being visable/working in windows and in ubuntu. Also I couldnt get the nvidia restricted graphics driver to work. Do you know if these problems have been rectified in Ubuntu 8 and if not would I come across these issues with all other linux distro's.
I have a Evesham Voyager 720DC, the one you reviewed an age ago, ie the Clevo 575U.
and bigup to microsoft for Windows XP, I'll never slate them again....well untill the next arb IT issue comes calling down the phone line. Please god don't let it be Vista! Its hard enough fixing something in XP let alone Vista which I've not used.
Denis_iii is offline   Reply With Quote
Old 25th Apr 2008, 11:22   #3
airchie
Mod Master
airchie's Avatar
airchie is on a distinguished road
Installed Ubuntu8 Beta on my friend's laptop and he's been happy since.
Well, once he got the weird Flash issue resolved so he could look at his pr0n online.
Gonna be installing Ubuntu8 on my own system soon.
Once I finish this coursework shich needs a bit of windows-only software.
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64
Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF.
Originally Posted by astralwandrer
Being a legitimate customer of the games industry is increasingly like being in a relationship with an abusive spouse.
airchie is offline   Reply With Quote
Old 25th Apr 2008, 11:41   #4
Spiny
Modder
Spiny is on a distinguished road
Thanks for this - good article! I wanted to install DSL on an ancient thinkpad (48mb RAM ) & turn it into a wireless digital photo frame, but I gave up trying to configure the wireless. I may try again now!
Spiny is offline   Reply With Quote
Old 25th Apr 2008, 12:04   #5
Panos
Multimodder
Panos is on a distinguished road
Great article.
With Ubuntu 7.10 I had some issues with my WIFI (using USB stick) after I did the installation. On the Live CD was working fine!!!!
It was solved in 10 min copying the kernel and the modules from the CD.
Same device I never manage it to work under Vista (no matter how many drivers and tools I tried), and under XP was refusing to work from time to time. (And around Xmas dediced to refuse connecting, while on Linux was fine).
When I switched to an MSI wifi PCI card, XP were OK, Vista after long fighting manage to work, and Ubuntu 7.10 just found it straight the moment it boot with no issues.
I believe Ubuntu and Mandriva now, have very mature Linux solutions where you don't need access to the terminal. And do your job easily.
Panos is offline   Reply With Quote
Old 25th Apr 2008, 12:39   #6
Zut
Multimodder
Zut is on a distinguished road
Does Ubuntu not install and configure WiFi modules etc by itself? I remember SuSE 8.1 YEARS ago did this right out of the box!
Zut is offline   Reply With Quote
Old 25th Apr 2008, 13:43   #7
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Most of the time, it does. However, there are many wireless chipsets that simply don't have Linux drivers. Hence the point of this article - an attempt to help people understand that just because it's not fully functioning right out of the box, it doesn't mean that there's no solution. It's all about troubleshooting those pesky buggers that don't work.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 25th Apr 2008, 14:01   #8
bilbothebaggins
Multimodder
bilbothebaggins is on a distinguished road
Nice article. I remember needing a week to setup my USB-Wireless card with Ubuntu :
The ubuntu forums are indeed a great source of information when you're stuck with these things ...
bilbothebaggins is offline   Reply With Quote
Old 25th Apr 2008, 18:43   #9
DanaG
What's a Dremel?
DanaG is on a distinguished road
Two incorrect pieces of information I noticed:
A. 'sudo gedit' -- though it doesn't much matter for that one app, it's a _bad habit_ to 'sudo' gui apps. Use gksudo or gksu instead -- or kdesu if you use KDE. Look here: http://psychocats.net/ubuntu/graphicalsudo
B. editing /etc/network/interfaces: You have to either do this, for fixed configurations, OR use NetworkManager (or one of several alternatives) for roaming -- don't do both. Setting up networking in the 'interfaces' file prevents you from using NetworkManager with that network interface.
DanaG is offline   Reply With Quote
Old 25th Apr 2008, 19:25   #10
notatoad
pretty fing wonderful
notatoad's Avatar
notatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to all
Originally Posted by Denis_iii View Post
... I tried Ubuntu 7.0 ...
Originally Posted by airchie View Post
...Installed Ubuntu8...
not that it matters, but ubuntu doesn't follow normal naming conventions. there is no ubuntu version 7.0, or 8. ubuntu 8.04 means it was released april 08. similarly, 7.10 was a whole version past 7.04. they both have the number 7 simply because they were both released in 2007.
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian
notatoad.net fdo eff
notatoad is offline   Reply With Quote
Old 25th Apr 2008, 20:03   #11
proxess
Victim of AdvancedModernCapitalism
proxess is on a distinguished road
Running Ubuntu 8.04 fresh install, working fine. I've never had wireless issues, always worked out of the box, even a CNet wireless dongle running on Ubuntu server (old laptop with custom install) just to show off at school how linux runs on anything (I had it running on my ipod as well at the time).
__________________
Netbook: Asus eeePC 901; 12Gb SDD; Custom Ubuntu 9.04 Minimal Compiz Standalone.
Laptop: Intel Centrino Duo T5500 1.66ghz; 2048mb RAM; ATI Mobility Radeon x2300; Hitachi 120gb iPod Classic 120GB; Maxtor 160GB External; Ubuntu 9.10 x64 and Windows 7 x64.
proxess is offline   Reply With Quote
Old 28th Apr 2008, 14:09   #12
Kode
Multimodder
Kode's Avatar
Kode is on a distinguished road
I ended up installing windows on my sister laptop, it had no cd drive, couldnt boot from USB so basically i was stuck with PXE booting an OS, ubuntu is my OS of choice so thats what i went with, http://www.lockstockmods.net/2008/04...u-via-windows/ details how to PXE boot ubuntu if anyone is interested, unfortunately ubuntu ran a little slow, so i tried xubuntu, worked flawlessly, was extremely happy with it until i tried to get it on the wireless network, i had a USB adapter, could not get it to work, so i bought a netgear WG511v2 which supposedly worked, and it did, sort of, until i put WPA or WPA2 encryption on, could not get it to work with WPA, 2 weeks later i gave up and decided to work out how to pxe boot windows (which i also put up on that site) 5 minutes after starting the setup it was on the network, its a real shame because i really wanted to get my sister using linux, but never mind.
*edit* I first installed Ubuntu fiesty, then xubuntu edgy, then xubuntu fiesty, then xubuntu gutsy, also tried installing network-manager, as well as many other things
Kode is offline   Reply With Quote
Old 29th Apr 2008, 21:06   #13
completemadness
Hypermodder
completemadness is on a distinguished road
1 thing i noticed in this guide, You start off by saying to do "sudo su"
But then throughout the guide, you swap between using sudo and not
for example you dont say to use sudo on
rmmod, dhclient, iwconfig and more
yet they all need it
other then that, quite interesting
completemadness is offline   Reply With Quote
Old 1st May 2008, 21:30   #14
pendragon
I pickle they
pendragon's Avatar
pendragon is on a distinguished road
meh, wireless networking is very hit or miss in linux from my limited experience.. my old compaq laptop has a somewhat propreitary W200 wireless lan adapter.. which sadly is not very well supported (if at all) last I checked... the other PCMCIA card I have works with NDISWrapper, however the configuration never saves and everytime I load Xubuntu I end up opening the Network Manager ... Applying the Location settings, and then type sudo su and then
iwconfig wlan essid <ssid> THREE FRIGGIN TIMES in a row.. before the card recognizes the network.. *sigh* hardware configs like this make me want to pull my hair out
pendragon is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
