Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 28th Apr 2008, 01:01   #1
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Case Painting ???
I finally got a case this weekend (my computer used to be in a cardboard box) and next weekend I'd like to paint it
I was thinking of painting it glossy black with a light red or blue over spray (little dots all over) but how do I do that??? I have an airbrush but it isn't the greatest or could I use regular spray paint (rattle can)??? How would I do the over spray???
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 28th Apr 2008, 02:09   #2
swift_wraith
I love you Pig.
swift_wraith's Avatar
swift_wraith has yet to learn the way of the Dremel
depends on how you want the finish to look. if you want a lustrious car showroom type finish then be prepared to take weeks of work on it.
the main points to consider:
  • Sand with 320-400 grit sandpaper
    Clean and let dry (sand again if needed and repeat)
    Apply first coat of primer
    Sand 400-600 (clean then dry)
    Apply second coat of primer
    Sand with 600-800 grit (clean and dry) (repeat above if 3 or more coats needed)
    Apply first coat of colour
    Sand with 1000 (clean then dry)
    Apply second coat of colour
    Sand with 1000 then 1500 (clean then dry)
    Apply 3rd coat of colour
    Apply rubbing compound. (clean then dry)
    Buff, polish then wax or apply clear coat
When painting, use light coats (spraying in smooth strokes across the panel) and build up the paint in small layers. Try and overspray the edge by about 2-3 inches, then come back on yourself, spraying from a distance of about 10 inches. Please dont be tempted to just coat it in one go as this will result in paint runs and the coat will look awful.
if you need any more pointers theres plenty of guides on google or you can pm me and ill try and help you out.
.... may cost you a sketchup model of a p182 tho
swift_wraith is offline   Reply With Quote
Old 28th Apr 2008, 03:22   #3
marcus000
Watercooling Mad
marcus000's Avatar
marcus000 has yet to learn the way of the Dremel
See BigDaveGrrr's guide here, it's pretty damn good!
http://www.watercoolinguk.co.uk/foru...php?f=9&t=2940
marcus000 is offline   Reply With Quote
Old 28th Apr 2008, 21:19   #4
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
Should I use a rattle can or a crappy air brush??? If I did use the air brush where would I find paint for it (don't have many hobby shops in town)???
__________________
Old 28th Apr 2008, 23:11   #5
swift_wraith
I love you Pig.
for a standard coat a rattle can will be more than adequate. As for the overspray, try getting a fan and blowing a colour from a rattlecan over your project from about 2 foot away. I'd suggest trying this effect on a sample piece first though just in case you dont like the finished effect.
Old 29th Apr 2008, 14:07   #6
Hazardous
Mod Master
Hazardous's Avatar
Hazardous has yet to learn the way of the Dremel
Here are a few guides I've got saved in a text doc for future reference:
Bill Owen (of MNPCTech fame)'s guide on how to 'Spray paint your PC case and give it a mirror finish'
Shatterstar's Painting Guide
BoxGod's Case Painting 'How to'[101]
Spooky's Computer Painting Guide
How to paint your computer case (Part 1)
How to paint your computer case (Part 2)
__________________
Beauty is in the eye of the beer-holder
Hazardous is offline   Reply With Quote
Old 29th Apr 2008, 22:14   #7
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
I bought sand paper and glossy black spray paint last night
My brother is pretty good at painting so I'm going to let him do it. He said I don't have to prime it unless I'm going all the way down to bare metel (saves my sanding and priming time)
Do I need a clear coat to go over the glossy black???
__________________
Old 29th Apr 2008, 22:38   #8
swift_wraith
I love you Pig.
I would clear coat it, if anything it will help protect the finish and also add a little depth to it.
Old 30th Apr 2008, 22:16   #9
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
I'll return the primer and pick up some clear coat
thanks for you're help, I'll post before and after pics
__________________
Old 5th May 2008, 21:50   #10
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
Ok so I painted it, it didn't turn out so great because there was a lot of dust/dirt in the paint
so I sanded to down to the bare metal and I'm going to restart from scratch, primer, paint (no dirt this time) and clear coat
__________________
Old 6th May 2008, 11:15   #11
Hazardous
Mod Master
Hazardous's Avatar
Originally Posted by The_Beast View Post
Ok so I painted it, it didn't turn out so great because there was a lot of dust/dirt in the paint...
How'd that happen? You must've been in a really dusty environment - so I assume it was outdoors?
__________________
Old 6th May 2008, 21:04   #12
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
no, I painted it in my garage and it wasn't dusty at all
this paint job turned out much much better (there is still a little bit of dirty in it) I'll try to get pic up here
__________________
Old 6th May 2008, 21:07   #13
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
To minimize the dust, I'd run a tackcloth over the piece at least beforehand.
__________________
Latest Builds:
LilyPC - in progress • BIO-A10 - MotM Jul. '12 Nominee Loser! • "Movie Sign!" - in progress • CheckMate - MotM May '09 Nominee Loser! • BluBawx I - MotY '09 Nominee Loser! • Lumi่re Noire - MotM Apr. '08 Nominee Loser! • NOTalis w/ MNPCTech • "Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 6th May 2008, 21:10   #14
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
I cleaned the panels with alcohol before priming
remenber I used spray paint, my brother said that spray paint has a little dirt in them already
__________________
Old 6th May 2008, 22:17   #15
E.E.L. Ambiense
Acrylic Heretic
No paint has "dirt" in it from factory, lol. The final painted result could have dirt in it if done in less-than-optimal conditions like a garage. You can get awesome results with a rattlecan if you're careful and go into it knowing some procedures to get good results beforehand. All the posts up top have examples of good tutorials on how to paint with a rattlecan; my favorite is Bill Owen's from MNPCTech.com. Top-notch and easy to follow for people that aren't normally into painting. A tackcloth will remove nearly all debris like dust, dirt or fibers if it's present just before painting. Alcohol will mostly remove contaminants like oils/etc., but what did you use with the alcohol to clean the panels? A cotton ball? A piece of cloth? Any of these things pick up dirt/debris or break up into debris itself and deposit them on the case while you're cleaning it.
__________________
Latest Builds:
Old 7th May 2008, 21:32   #16
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
I used a paper towel but I didn't see any debris left from the paper towel
I don't really want to paint it a 3rd time
I'll try to get pic of it tonight
__________________
Old 12th May 2008, 23:10   #17
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
Sorry I didn't get pics to the paint job in progress
Side panel painted
Side and top panel
Close up of the vent
The front painted(I left the 3.5" and the 5" bays along with the power and reset buttons unpainted because I'm thinking of painting them Fire Red)
Close up of the shiney front
All the panels and front are primed, painted and clear coated with a "rattle" can paint. The paint job cost a whopping $4.03 (.97 primer, $1.94 of paint [2 cans] and $1.12 for clear coat). Ohh yeah I spend $5 for a wire drill brush. I spent more on the brush then the paint job
Here is a pic of the internals of the case
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
