Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 28th Apr 2008, 05:14   #1
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysis
My computer lost its bios settings
Today I closed a program, and then a few minutes later started it again. but it didn't start. so I hit ctrl alt delete and saw that 2 instances of it were currently running. I tried to shut them both down but one refused to do so. so I tried to restart windows but it wouldn't shut down.
I hit the restart button and the pc did not come back on. It powered up but that was it. no post or anything.
I turned it off, started it again. same thing. Turned it off, disconnected the power and let it sit for a minute. Turned it back on and I got a message (cant remember the exact wording) that said something about the settings in the bios being wrong. I had an option to go into the bios, or load defaults. I went in and set it up as i had it before. Now it is working fine.
Anyone know why it would do this? It happened once about a month ago as well but it wasn't the exact same problem. I just turned it on in the morning and found that my bios settings had reset.
Running an asus p5k deluxe
Q6600
Corsair 620
ati 1950 pro
2gb ram
edit: how do i edit the title?
chrisb2e9 is offline   Reply With Quote
Old 28th Apr 2008, 07:52   #2
badders
Neuken in de Keuken
badders's Avatar
badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.
Not sure what would cause BIOS outage, but to edit the title, edit the post and Go advanced.
Good luck.
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Old 28th Apr 2008, 08:29   #3
Krazeh
Mod Master
Krazeh's Avatar
Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.Krazeh is the Cheesecake. Relix smiles down upon them.
It's an automatic feature on the P5K. If the board fails to POST then on the next power up it resets all bios options to default, tells you that overclocking has failed and asks you to go into the bios or load defaults.
__________________
"My name is don don
I am pretty elephant
Love me well!"
Krazeh is offline   Reply With Quote
Old 28th Apr 2008, 15:32   #4
chrisb2e9
Dont do that...
chrisb2e9's Avatar
ok, thanks. At least I know its not doing it because its broken.
I still wish I knew why it failed to post though. It started up fine today after being off all night.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
