Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 29th Apr 2008, 17:37   #1
xen0morph
Bargain wine connoisseur
xen0morph's Avatar
xen0morph has yet to learn the way of the Dremel
escputils on Hardy Heron...
I'm having a few problems cleaning the print heads of my Epson Stylus DX4050, which worked fine using escputils on Gutsy Gibbon. I can't seem to install it on the new release, I do sudo apt-get instal escputils and it tells me the package doesn't exist. I can't find any other way to install it having done a google search. I have all repositories checked in the package manager.
I have tried mtink but it just doesn't recognise my printer. escputils worked fine for me before.
Any ideas? Cheers.
xen0morph is offline   Reply With Quote
Old 29th Apr 2008, 18:41   #2
Millusdk
Multimodder
Millusdk has yet to learn the way of the Dremel
try a sudo apt-cache search escputils, maby it really has been removed or renamed.
__________________
Core 2 Quad Q9550 @ 2.83 GHz - 8 gb DDR2 PC6400 CL4 - 2 * GeForce GTS 250 1GB - 500GB hdd @ 7200RPM - nForce 780i SLI - Windows 7 Ultimate
Millusdk is offline   Reply With Quote
Old 29th Apr 2008, 20:34   #3
trigger
Procrastinator
trigger's Avatar
trigger has yet to learn the way of the Dremeltrigger has yet to learn the way of the Dremel
On my debian install it's call escputil (i.e. no 's') - could be that, though I'm not running Ubuntu
__________________
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.
- Benjamin Franklin
flickr
trigger is offline   Reply With Quote
Reply
Tags
linux
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
