Thread Tools |
#1 |
Player Character
bit-tech Staff
Intel to team up with Cray
http://www.bit-tech.net/news/2008/04...up-with-cray/1
Intel is entering into a partnership with high-performance computing legends Cray to create a next-generation supercomputer - and it could well be Nehalem-based.
__________________
#2 |
regular bit-tech reader
Just a small detail - isn't Intel's QuickPath answer to AMD's Directconnect, rather than Hypertransport?
#3 |
Web Developer
Does/will it run Crysis? XD
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
#4 |
I'm not a modder.
Probably not, unless you can run Crysis in software rendering mode. In which case, it will be incredibly fast!
Some one has got to try running Crysis on a supercomputer sometime
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#5 |
Sir Bongaminge
That's the problem with Supercomputers, Excel works REALLY fast on them, but try sticking in a good game or playing a new BluRay title and they'd fall over and die. Really, what's the point of a PC if you can't even play Quake 3 on it? Pah.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups |
#6 |
Ultramodder
Well that's probably the end of big iron.
__________________
#7 |
quad fuelled, GTX200 powered
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#8 |
Truly truly truly outrageous
If Excel runs well, then this is the 3d engine for a Cray.
http://www.gamasutra.com/view/featur...3d_.php?page=3
__________________
Armagetron Advanced!
| Thread Tools | |
