Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 30th Apr 2008, 15:44   #1
reddragon105
Multimodder
reddragon105 has yet to learn the way of the Dremel
Laptop LCD displays green instead of black?!
Just got a new laptop off ebay - it was sold as faulty because there's a problem with the screen - it appears to work fine, except that everything is washed over with green. Booting into BIOS gives me a green screen with the HP logo in the middle (I presume the background is supposed to be black, but instead it's a mid to light green). Blue and white display fine in the BIOS settings, but anything darker than than is just green. I've installed Windows and everything is running fine - all software and games perform well (it even plays Crysis, albeit on low settings), it's an excellent laptop, except for this damn greenish hue over everything - I can only use it comfortable with the screen at certain angles. I bought it for work, and it's fine for typing, but I also need to do photo and video editing and those require being able to see colours.
So - differential diagnosis: what could be causing this?
I connected it up to my LCD monitor using a VGA cable and my TV using S-video and the colours are normal on both of those displays, so I'm guessing it's not the graphics card.
I opened up the laptop and checked the cable between the motherboard and the screen. It doesn't seem badly chewed up, but I gave it a wiggle anyway and for a few seconds the display did appear normal (this was in BIOS, so light green text on a dark green background turned into white text on a black background), however then the screen went off as the cable slipped out, I replaced it, only got the green hue again, and I've been unable to repeat this. If I didn't dream it, then I'd say the LCD itself is fine.
So I bought a new cable - had to get one imported, took 10 days. I've just put that in and it hasn't made any difference
So what's left? The invertor? Could that cause this colour problem? Or, as wiggling the cable corrected the display, could it be the internal connector on the motherboard?
Any ideas? Please?
reddragon105 is offline   Reply With Quote
Old 30th Apr 2008, 17:13   #2
Golygus
Hypermodder
Golygus has yet to learn the way of the DremelGolygus has yet to learn the way of the Dremel
not the inverter.
either the cable going from monitor to pc, or the connector at either end.
I'd try replacing the cable. Laptop boards are expensive.
__________________
Intel Core i7 920 @ 2.8GHz | Akasa Nero S | 3x2GB Corsair XMS3 | Gigabyte GA-x58A-UD3R r2 | Gigabyte GTX770 OC 2GB | SB X-Fi Extreme Gamer | OCZ 120GB RevoDrive, 2 x 1TB WD 1002FAEX | 2 x Samsung SH-S223B DVD+RW | Corsair HX620W PSU | Windows 7 Pro 64bit
Canon EOS 7D | Canon EFS 17-55 f2.8 IS USM | Canon EF 70-200 f2.8 L IS USM | 2 x Canon Speedlight 550EX
Golygus is offline   Reply With Quote
Old 30th Apr 2008, 17:34   #3
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
My brother had this exact same problem with his ASUS laptop, and we came to the conclusion it was the cable or the LCD. We sent it back to ASUS (out of warranty) and they said it was the LCD itself, not the cable, and replaced it for 180.
ch424 is offline   Reply With Quote
Old 30th Apr 2008, 17:47   #4
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Since replacing the cable did not work, I'd say it is the connector that is the problem.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 30th Apr 2008, 17:48   #5
reddragon105
Multimodder
As I feared
I will buy a new LCD screen for it. If that doesn't fix the problem, at least I'll be able to return/sell on the new LCD screen, so it's not like I'd lose much.
Suitable LCD screens (LG Philips 17" Widescreen) are going for around 100 on eBay. Even with that, the laptop is still a bargain as I only paid 200 for it (and it's a HPDV8372EA - Core2Duo 2.16ghz, 2gb RAM, 160gb HD, GeForce 7600). Just a shame it's a 100 screen problem rather than a 10 inverter. Of course it could be the connector on the mainboard, which would suck.
Old 30th Apr 2008, 18:21   #6
Smilodon
The Antagonist
Smilodon's Avatar
Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.Smilodon is a hoopy frood who really knows where their towel is.
That's a bloody shame. I had a display for one of those (if it's the glossy type), but I fried it.
You could try to run the motherboard without a chassis to see if that helps. (As in no bottom cover). To me it sounds like a faulty motherboard, but It could be anything in a case like this.
__________________
"You have to wonder about a business plan based on the notion that people want to interact with a soda can." -Jeff Salkowski abot the :CueCat
"City crematorium. You kill 'em, we grill 'em." -Rkiver
Smilodon is offline   Reply With Quote
Old 30th Apr 2008, 19:32   #7
reddragon105
Multimodder
I'm currently running it with the screen completely removed on my LCD monitor through a VGA cable - it's fine. So it's not the graphics card, could be the motherboard or the connector on it, but I'm hoping not. I just wish I had another laptop, or at least a spare screen lying around so that I could test to make sure it is the LCD panel before buying another.
Old 30th Apr 2008, 19:33   #8
ch424
Design Warrior
ch424's Avatar
Yeah, but the connector is built into the LCD and these days you can't unsolder/resolder stuff because it's too fiddly.
Old 8th May 2008, 13:21   #9
reddragon105
Multimodder
I bought a new LCD screen, but that hasn't made any difference - the display is still green.
So, if I can safely say it's not the screen because I've tried it with 2, it's not the inverter because the screen powers and lights up, it's not the cable because I've tried 2 of them and it's (probably) not the graphics card because it displays fine on a monitor and TV - then by process of elimination does this mean it's the actual connector on the motherboard?
How can I test and fix this? Am I going to end up getting a whole new motherboard?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
