Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd May 2008, 08:13   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Memristor: the fourth circuit element
http://www.bit-tech.net/news/2008/05...cuit-element/1
HP Labs has announced experimental proof of the existence of a building block for electronic circuits dubbed the 'memristor', which could lead to instant-on computing.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 2nd May 2008, 09:48   #2
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
I recommend anyone at uni with an Athens login gives it a go - it's a very interesting paper, which is well explained, even if you don't do semiconductor physics/electrical engineering.
I'd post up a diagram that explains the whole thing from the paper, but it's illegal...
The concept of the part is really revolutionary, but it's worth pointing out that the team haven't managed to make a large-numbered lattice of them yet, and that's the real test of whether we can use the technology yet.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 2nd May 2008, 12:42   #3
zero0ne
Multimodder
zero0ne has yet to learn the way of the Dremel
BAD!!!
there is no point in trying to extend the silicon computer format; they should instead be pushing more for quantum computing!
(don't take my bad seriously, its only a joke!)
zero0ne is offline   Reply With Quote
Old 2nd May 2008, 14:11   #4
Faulk_Wulf
Internet Addict
Faulk_Wulf's Avatar
Faulk_Wulf has yet to learn the way of the Dremel
Huh. Cool.
I'll take a petabyte hard drive now, plzkthxbai?
:P
__________________
-- Faulken S. Wulf
"Under the Willow, he sleeps and dreams, of Heaven."
Looking over my threads, I've come to realize that I have a ridiculous amount of bad luck with my electronics.
Faulk_Wulf is offline   Reply With Quote
Old 2nd May 2008, 18:15   #5
willyolio
Multimodder
willyolio's Avatar
willyolio has yet to learn the way of the Dremelwillyolio has yet to learn the way of the Dremel
sweet. i love being in university. full access to papers.
willyolio is offline   Reply With Quote
Old 2nd May 2008, 18:16   #6
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Awesome, isn't it.
__________________
Old 2nd May 2008, 21:03   #7
johnmustrule
Supermodder
johnmustrule has yet to learn the way of the Dremel
yes, tomorrow, probably.... ... ... .... .... ....
__________________
"Your belief, unfortunately, is no endorsement of truth"
johnmustrule is offline   Reply With Quote
Old 2nd May 2008, 23:41   #8
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
Originally Posted by Wikipedia
the memristor is popularly being referred to, accurately, as a flux capacitor due to memristance being a relation between charge and magnetic flux
But of more interest
They can also be fashioned into non-volatile solid-state memory, which would allow greater data density than hard drives with access times potentially similar to DRAM, replacing both components. HP prototyped a crossbar latch memory using the devices that can fit 100 gigabit in a square centimeter. The highest-density Flash memories store 16 gigabit in the same area, for comparison. HP has reported that its version of the memristor is about one tenth the speed of DRAM.
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 3rd May 2008, 01:22   #9
DXR_13KE
BananaModder
DXR_13KE's Avatar
DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.
what universities have access to this information?
__________________
Renegade X - Release Date Unveiled
Check it out!!
DXR_13KE is offline   Reply With Quote
Old 3rd May 2008, 23:56   #10
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 has yet to learn the way of the Dremel
I rearly would like to read the paper but it's very expensive. I guess I can do when I get to uni?
is it posible to imagine this as EEPROM on steroids?
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 4th May 2008, 00:34   #11
ChromeX
I *am* a Dremel
ChromeX's Avatar
ChromeX has yet to learn the way of the DremelChromeX has yet to learn the way of the DremelChromeX has yet to learn the way of the DremelChromeX has yet to learn the way of the DremelChromeX has yet to learn the way of the DremelChromeX has yet to learn the way of the Dremel
Everyone with an access to the athens system, unfortunatly i've forgot my logon details so i cant access it from home. If Anyone wants a copy PM me, i'll pop in on tuesday and access it from uni and forward it.
ChromeX is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
