#1 |
The other Brett.
Moderator
[05/08] Which came first
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home" www.yodasarmpit.com clickr my flickr |
#2 |
Don't panic!
That's a really nice shot - the lighting is brilliant. Any chance of a big 'un?
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#3 |
Protograffer...but not really.
Did you diffuse at all? That hot spot kills it a bit...as does the negative space, but I guess thats just a taste thing.
__________________
1DIII, 5D+BG-E4, 40Dx2, Tamron 17-50, Canon EF-S 17-85, 16-35L, 70-200L f/2.8 IS, 100-400L IS, 35L, 50 f/1.4, 85 f/1.8, Sigma 150 Macro, 580EXIIx2, Giottos MT 9360+MH1001 Ballhead & MH658 QR system, Custom Brackets CB Jr. Flash Bracket flickr |
#4 |
The Antagonist
Aww! Dammit! I was going to do that!
![]() *admits that the picture is really nice, and heads of to a corner to cry* Seriously, though. The picture is really awesome. Good light and contrast.
__________________
"You have to wonder about a business plan based on the notion that people want to interact with a soda can." -Jeff Salkowski abot the :CueCat My Flickr |
#5 |
The other Brett.
Moderator
The negative space is entirely intentional, however as you say that's a personal taste thing.
I'm very partial to lots of negative space, unfortunately I sometimes feel alone in that respect
__________________
#6 |
Me!
I actually think the negative space tells a story of the chick having walked off leaving the shell. A very calm composition. But I agree that the hot spot is a bit large. I think further diffusion / more texture and color in the egg would lift this further. This IS nitpicking though
![]() How'd you punch that hole by the way? It looks rather authentic
__________________
Quickr! Clickr to my Flickr! Canon camera stuff. Some aluminium PC, an HTPC and a MBP 17".. |
#7 | |
The other Brett.
Moderator
__________________
#8 |
Its not so much the idea of negative space, rather the way in which it was used...In other words I feel the composition is a bit off leaving too much foreground (feel as though the shell is floating in a vat of empty space) If the shell was placed towards the bottom of the frame it would seem as though its grounded a bit. BTW, if your going for a realistic take-- when a chick hatches it breaks the egg shell in two, similar to when you crack it open to fry one up. Whether than matters or not is up to you
__________________
#9 |
I see a slit in the shell membrane...Happen to use a wire/fish hook? (poke a small hole with a pin, insert hook then pull punching a larger hole, then possibly using a prod to remove the rest of the shell for a desired shape/hole size) I've also used a corkscrew instead of a hook.
__________________
#10 | |
The other Brett.
Moderator
__________________
#11 |
The Antagonist
What did you use as a surface, BTW?
I'm looking for something to use as a background in "studio" photographing, but haven't found anything ideal yet.
__________________
#12 |
The other Brett.
Moderator
It's just a sheet of glass (from a photo frame) sitting on a black cloth material stretched out behind.
__________________
#13 |
Completely forgot to ask...did you shoot this with your Sigma?
__________________
#14 |
The other Brett.
Moderator
Yeah, first shot with it, didn't get a chance to get outside much today.
__________________
#15 |
Brett Thomas
I really love the negative space in this, actually. Like REALLY love it. I didn't even notice the hotspot on the shell until it was mentioned by OleJ and Vers.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#17 |
The other Brett.
Moderator
I'm thinking of updating it with this one.
__________________
#18 |
The Antagonist
TBH I like the first one better.
In the first one it looks like something have come out of the egg and wandered off (the negative space enhance this "feeling"). In the second one the egg looks just damaged. There is also a visible double reflection in the glass. Having that said, I think the second one looks good as well, but not as good as the first.
__________________
#19 |
While the egg in the first image may look cleaner (in a sense) the second image portrays what an actual hatch would look like. Seeing as though a chick fits inside the egg with absolutely no room between it and the shell, the first image reveals a bit of inconsistency...how exactly would a chick fit through a hole that is a fraction of its size? Unless it was comprised of Jello it couldn't. From another standpoint I see what smilodon means about the shell looking a bit sloppy...then again its a bit more realistic.
As for the second image...the composition is much better and the shell balances very well with the use of negative space, but there is still something thats bothering me that I just can't quite pin down...something to do with the shell, just don't know what. Maybe its the angle of lighting? I like the way you lit the first image (from the left), but the second I'm not too sure of.
__________________
#20 |
Kiteninja
^^^ **** it does seem twot with an a is censered
__________________
MY Flickr -- My Website
Canon 50D, 24-70L, 70-200L,1.4&2x TCs, 17-50, 10-17fish, Nifty, 580EXII, Lencarta Studio. |
| Tags |
potm ![]() |
| Thread Tools | |
