Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
Industry to start move to 450mm wafers in 2012
http://www.bit-tech.net/news/2008/05...fers-in-2012/1
Intel, Samsung Electronics and TSMC have collectively agreed to push forwards with plans to move to 450mm wafer production starting in 2012.
#2 |
intermediate selfbuilder
what does this mean in practice? that was a bit technical for me.
__________________
antec p180b, asus P5B, 2Gb DDR2, E6600, vista 32-bit sp1, SATA spinpoint hard disk, SATA spinpoint optical drive, Palit 8800gt 512mb |
#3 |
Resident frenchie
The thing held in the picture will be bigger (i think) so that you can manufacture more chips at once. Combined with the fact that chips are getting finer detail (the famous 90 or 45 nm) and as such smaller size, you fit more into one.
correct me if i'm wrong...
__________________
I also have a MTBF. |
#4 |
Minimodder
I've always wondered why the wafers are round. Would it not be more efficient and produce less waste if they made them rectangular?
Still, cheaper chips They'll hopefully be out buy the time I'm set for my next big upgrade
__________________
Q6600 | Asus P5KC | BFG 8800GT OC | 2gb GeiL DDR2-800 | HX620 | 500gb | P182 | Freezer 7 Pro
Samsung SM226CW | Creative T20s | Logitech MX518 & G15v2 Stunedge | DragonSlayers |
#5 | |
Linux cursed
#6 |
Bit-tech's Heffalump
the wafers are round because the silicon crystal the wafers a cut from is cylindrical (sp?). Back ontopic, woooo! cheaper chips here we come
EDIT: doh beaten to it |
| theevilelephant |
| View Public Profile |
| Find More Posts by theevilelephant |
#7 |
Minimodder
Thx guys, you learn something new everyday
__________________
#8 |
I *am* a Dremel
actually silicone crystals aren't round, which makes me wonder why they don't form them in the shape of the crystal ( believe the cross section is hexagonal but my books only list the crystal lattices of metals
#9 | ||
Minimodder
__________________
http://www.pardus.at/index.php |
#10 |
Supermodder
Standart 200 and 300mm (8" 12") wafers are round, smaller ones sometimes have one flat edge.
While it is possible to cast square blocks of silicon, you end up with polysilicon, while semicon manufacturers need monosilicon. Poly beeing many crystals, mono beeing one big crystal. Poly square blocks are used for solar panels for instance. Monosilicon is usually made round, by the pulling process described above (only still slower) Having a round wafer has many disadvantages, for instance losses at the corners...layout a grid on a cirkle and count the "incomplete" squares on the sides. Then notice that when you increase the circle, the amount of incomplete squares compared to the amount of complete squares goes down. So bigger wafers means less incomplete squares (one square usually being a chip) The good thing about round wafers however is that it is easier to deposit and remove even layers on them. (nitride, oxide, copper...you wouldn't believe how many layers a chip is actually made of...most beeing removed again during production) Xir
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C |
| Thread Tools | |
