RSS
Reply
Thread Tools View Mode
Old 12th May 2008, 21:09   #1
thechoozen
Supermodder
thechoozen's Avatar
thechoozen will become famous soon enough
[Storm] - 040809 - Rebuild /GC Online
This is another new project we build, up to now we call it STORM.
We started a few days ago with this unspectacular big tower case (its not spectacular, but it has a removeable mainboard tray) which we got from ebay
Because its huge like a stacker we decided to build in some kickass hardware (we didnīt decide which hardware exactly up to now) with a big watercooling loop, 2 or 3 radiators (3x120 + 2x120 + maybe another 3x120) and 2 optical drives.
So at first we stripped the case down to its raw body to see how everything would fit and in which way we are gonna make the one or other thing....
then we made 2 small mounting brackets out of some alloy stripes which we use to mount the radiator on the bottom of the frame. This was necessary to prevent the radiator from falling down on the next image and it prevents that the radiator could be shaked out of its position when moving the case.....
as next we bend some alloy stripes into the right angles so that we could mount the 2 optical drives with them on the outside of the case....
beside that we also bended some of those stripes to hold another radiator in front of the case, then we painted everything inside white except the radiators they get a fresh black paintjob...
The Top of the case also gets a first cutout
one of the last things we could do up to now was to build a first water reservoir which will be attached directly to the pump to prevent it from sucking air....and to make the filling process a little bit easier....
thechoozen is online now   Reply With Quote
Old 12th May 2008, 22:33   #2
Farmboy UK
Hungry for knowledge
Farmboy UK's Avatar
Farmboy UK is on a distinguished road
Plenty of room in that beast!
__________________
Warning: I am new and comparatively unknowledgeable however I am here to learn. So please bless me with your kind donations of wisdom.
Farmboy UK is offline   Reply With Quote
Old 12th May 2008, 23:58   #3
beesbees
Multimodder
beesbees is on a distinguished road
That case is huge!
beesbees is offline   Reply With Quote
Old 13th May 2008, 01:07   #4
nikeunltd
Epic destruction around machinary
nikeunltd's Avatar
nikeunltd is on a distinguished road
this is a massive case!
nikeunltd is offline   Reply With Quote
Old 15th May 2008, 20:25   #5
thechoozen
Supermodder
thechoozen's Avatar
yeah your absolute right, itīs really a BIG Tower Case, but you can see that the free space is shrinking with every hour we put in
today we cut the sidepanels....first we cut the complete panel in 2 pieces
Then the both upper parts got their cutouts and holes so that we can mount a 2x120 mm radiator on each sidepanel. One of the sidepanels additionaly gets a few more cutouts which will be used as small windows....
beside the cutouts we also cut out some acrylic parts in shape of the small windows which will be placed on the other sidepanel....
For the inside we prepared a first cover which will be placed in the front part of the case, it will cover the pump, the small water reservoir and nearly all cables which will be needed for hdds and opt. drives....(atm its not fixed in its position that will follow later)
As last step we prepared a frame of alloy stripes which is screwed to the radiator on the front of the case
Old 15th May 2008, 21:10   #6
Angleus
Hypermodder
Angleus's Avatar
Angleus is on a distinguished road
Woah thats looking really cool man
__________________
C2D E6550 / ASUS P5KC / 4gb Corsair XMS2 6400 / XFX 8800 GTX / 2 x WD 160GB SATA 1 x 250GB WD SATA / X-Fi Xtreme
I need a Mac! PM me please if you have one available
Angleus is offline   Reply With Quote
Old 15th May 2008, 21:57   #7
Farmboy UK
Farmboy UK's Avatar
Loving the 'grill' on the rad
__________________
Old 16th May 2008, 20:13   #8
thechoozen
Supermodder
thechoozen's Avatar
thanks a lot!!! itīs always nice to hear when others like your own work
today we build another radgrill for the radiator which will be placed on top of the case (another 2x120mm), after that we painted both in a plain black so that they will bring in some contrast to the white.
For the inside we build another acrylic cover which will be placed on the floor of the top part. Then we drilled a lot of holes in it to guarantee that the PSU can pull air through it.
Old 17th May 2008, 10:15   #9
modgodtanvir
Prepare - for Mortal Bumbat!
modgodtanvir's Avatar
modgodtanvir is on a distinguished road
Wow. I'm really liking the grille! Really professionally executed. Subscribed.
__________________
Nexxo: Oh, and Relix is god, and ComputerKing is his prophet.
Mankz: Meh. So what am I?
dragon2309: Weak wristed...?
modgodtanvir is offline   Reply With Quote
Old 17th May 2008, 11:57   #10
JAxen
Multimodder
JAxen's Avatar
JAxen is on a distinguished road
very cool grills!
"full-tower" will never mean the same
__________________
http://www.zeitgeistmovie.com/
A must-see movie! Gets you thinking, seeing things thru another perspective for sure.
"When the power of love overcomes the love of power, the world will know peace."
JAxen is offline   Reply With Quote
Old 17th May 2008, 12:55   #11
mr_carl
Multimodder
mr_carl's Avatar
mr_carl is on a distinguished road
Sweet stuff, I like the stripes in the case
__________________
Twitter
On hold CircleButterfly Project
mr_carl is offline   Reply With Quote
Old 17th May 2008, 13:36   #12
modgodtanvir
I really like this piece:
I was intending to put something similar in my next mod, except coming from a bottom compartment, to the main one.
Just love the acrylic. Its surprising how good it can look. And that's my favourite combination of colours.
__________________
Old 18th May 2008, 02:27   #13
B[x]
Supermodder
B[x] is on a distinguished road
I'll definitely be watching this one. Love the work so far.
__________________
Negative Space - Thread - Website
Project S (On Hiatus) - Thread - Website
B[x] is offline   Reply With Quote
Old 18th May 2008, 06:17   #14
nickhelton
Multimodder
nickhelton's Avatar
nickhelton is on a distinguished road
oh man this is looking to be epic. subscribed!
__________________
Project 'No Direction'
Powered by MNPCTech
nickhelton is offline   Reply With Quote
Old 18th May 2008, 10:37   #15
Farmboy UK
Farmboy UK's Avatar
Looking real good. Can't wait to see what you are going to do with the rest of all that space
__________________
Old 21st May 2008, 05:56   #16
thechoozen
Supermodder
thechoozen's Avatar
thanks a lot !!!!
in the last few days we couldīt work much on this project because of the marriage of my brother (he is working with me on this project)
but yesterday we made a little progress so here it is
at first we cut some Plexi Pipes (100mm + 60 mm diameter) so that we can use them for the real water resevoir which we will put in the lower part of the case, beside that we also made a top and bottom for it
then we made a side part for the inner cover
we also made 2 covers for the DVD Drives which we will mount later
Old 22nd May 2008, 20:18   #17
thechoozen
Supermodder
thechoozen's Avatar
in the last days we made some progress.....
first we made the last radiator / Fan Grill which we will use later, after building them, we put them in place to see if they fit in the way we want....
then we cut a small plexi stripe and drilled in 20 holes for LEDīs, later we build more of them....
after that we cut out the first part of the water reservoir stand, i think tomorrow we cut the second one....
as last we prepared a part of the outer skin of the mod....therefore we cutted 32 plexirods in 25cm length so that we can use them later.....
Old 25th May 2008, 19:05   #18
thechoozen
Supermodder
thechoozen's Avatar
today we made the 2nd holder for the water reservoir and put it in place for a quick test....
after that we made a plexi circle which will surround the fillport of the rez...
then we also made the first parts of the case feets...
after that we started to build the upper part of the front, therefore we cuttet a thin piece of wood in its raw shape and then we put a thick layer of building foam on it.......after everything dryed out we begin to give it a better shape...but itīs only the base for everything what will come later on.....
Old 25th May 2008, 19:16   #19
Darkened
Oh, the monstrosity...
Darkened's Avatar
Darkened is on a distinguished road
Damn, this must be one of the craziest designs I've seen for a computer case. If you pull this off (and I don't see why you wouldn't), it's going to look amazing.
Only thing I'm not so sure about is the urethane foam you are using, I'd go with a solid polystyrene block. It's probably manufactured all over the world, but I don't know anything else besides Finnfoam.
I know that people use it for making bodykits for cars, model airplanes, so it should be just the thing for this mod.
Darkened
__________________
I have spread my dreams under your feet, tread softly because you tread on my dreams.
Project: Orange Monster
Project: Phantom Black
Project: Red October
Darkened is offline   Reply With Quote
Old 25th May 2008, 19:25   #20
Farmboy UK
Farmboy UK's Avatar
Amazing and original, i agree that solid closed cell foam would be a better base for the case than the expanded stuff but I'm sure you can make it work. Keep up the great work.
__________________
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
