Thread Tools |
#1 |
Player Character
bit-tech Staff
Image-based search with TinEye
http://www.bit-tech.net/news/2008/05...-with-tineye/1
Idée Incorporated have launched a closed beta of an image-based search engine which allows you to upload pictures from your computer and search for similar images on the web.
__________________
#2 |
Madeira's banana is the best!!!
this has some uses in finding copyright material similar to yours....
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#3 |
Supermodder
Well thats a coincidence, I was just playing around with image-based searching algorithms to try and build something.
__________________
Current Rig: Shuttle ST20G5 | AMD Athlon64 4000+ San Diego | X1950Pro | 200Gb Samsung SpinPoint P120S SATA | 1GB OCZ Performance | NEC ND3540A | 7-in-1 Floppy |
#4 |
Supermodder
*shiver*
just what I've been waiting for, the possibility to RECOGNIZE every idiot that ever had their picture anywhere in the web....so i can use it against them! *HARHARHAR* So this is something I'm not happy about. (future) Employers are going to love it though. ![]() So now what, I go through life with a black bar over my eyes?
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C |
#5 |
Supermodder
I bet google will copy this idea or buy it out.
| freedom810 |
| View Public Profile |
| Find More Posts by freedom810 |
#6 |
Supermodder
Actually site owners should be able to block the spider from using the site. As a result anyone that is trying to hide copyrighted material would just do that. Also some sites might start doing that as an option on some pages to protect the identities of people in the images.
I can only imagine the possible government uses for this software...
__________________
965 @ 4.26GHz-P6T DELUXE-GTX 280@750&1307-DDR3 Triple Channel@1001 MHz-RAID 0 Cheta 15.6k SAS-All Water cooled IBIS GAMING |
#7 |
WIIGII!
The very nice CEO of Idée has pulled some strings and got me into the beta. Which is nice.
We've also got twenty invites to give away to loyal bit-tech readers, so if you'd like an account check out this thread. |
#8 |
What's a Dremel?
Very nice. Having options its better.
| Thread Tools | |
