RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th May 2008, 08:59   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
BFG Tech GeForce 9800 GTX OCX 512MB
http://www.bit-tech.net/hardware/200...tx-ocx-512mb/1
The GeForce 9800 GTX launched back at the start of April and today we look at one of the highest-clocked partner cards on the market. BFG Tech's GeForce 9800 GTX OCX comes with an impressive 755MHz core speed and a shader clock of almost 1,900MHz - is that enough for the card to win us over?
Tim S is offline   Reply With Quote
Old 15th May 2008, 09:21   #2
BioSniper
I Mod, Therefore I Own
BioSniper's Avatar
BioSniper has a spectacular aura aboutBioSniper has a spectacular aura about
How come there are no comparisons to the 8800GT?
I would have thought benching against that would be logical as it's a pretty common card.
__________________
My Flickr :: Bit-tech Flickr
Wii: 1792 1527 2926 7945 :: Xbox Live: BioSnipr :: PSN: Biosnipr
BioSniper is offline   Reply With Quote
Old 15th May 2008, 09:32   #3
kenco_uk
I feel your presents.
kenco_uk's Avatar
kenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to beholdkenco_uk is a splendid one to behold
I've recently bought a 'bog standard' 9800GTX for around the £180 mark and it clocks to 760core/2300mem, with no artifacts in ATITool.
I'd presume to get the mem as high as you did that BFG change the voltage that's supplied to the ram slightly (much like doing a 'pencil trick') which is probably why you managed to get it a little higher (2354/1177).
Cheapest 8800GTS I can see is around £150. 8800GTX is £172. 9800GTX is around £180.
Looking at the last 1920x1200 Crysis benchmark, going from 19fps minimum with the 8800GTX to 24fps minimum with the 9800GTX makes a fair amount of difference. I've noticed it's a fair bit smoother than than my old 8800GTS 640/G80 when I put some more of the graphics lubbliness on.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech
T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door."
kenco_uk is offline   Reply With Quote
Old 15th May 2008, 09:48   #4
Silver51
I cast flare!
Silver51's Avatar
Silver51 is a splendid one to beholdSilver51 is a splendid one to beholdSilver51 is a splendid one to beholdSilver51 is a splendid one to beholdSilver51 is a splendid one to beholdSilver51 is a splendid one to beholdSilver51 is a splendid one to behold
I think I'll stick with the 8800GTS for a little while longer. To be honest, nothing in nVidia's 9xxx line-up looks to be a big enough step up to warrant upgrading. If anything I’m a little concerned about escalating power consumption on newer boards.
Silver51 is offline   Reply With Quote
Old 15th May 2008, 10:39   #5
donnie
Moddin' my way out of a paper bag
donnie's Avatar
donnie is on a distinguished road
Tim can i ask why the newer graphics cards arn't testing on crysis's very high setting as these are the top of the line directX 10 cards so i would like to see if they are capable of running this years argueably most ambitious game with no story.
1280x1024 2xAA 0xAF, DX10, Texture/Shadows/Physics/Shaders/Water: High; All other settings: Medium
this really isn't showing the kind of information we need, we need to see if this card can handle the full might of VERY HIGH please could you explain to me why the high settings are still used?
__________________
780i - Q6600 - EVGA 8800GTS - 3GB GEIL - LIAN LI V2100 - SWIFTECH WC KIT
donnie is offline   Reply With Quote
Old 15th May 2008, 11:03   #6
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
The answer is quite simple: it's because the cards can't run the game at very high at 30fps. To me, getting 12 or 13 fps at very high tells the reader absolutely nothing - apart from the fact it cannot run it. It doesn't tell you which card is faster at settings that you can play the game at. The reason we are not running very high settings in Crysis is because today's cards cannot play the game with very high settings enabled at a frame rate that you can actually play the game at.
I'm in the process of running some numbers for you to prove the point.
Old 15th May 2008, 12:03   #7
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I wasn't far wrong... an overclocked 3870 X2:
1280x1024 2xAA 0xAF DX10/Very High - 16.5 fps avg / 6 fps min
1680x1050 0xAA 0xAF DX10/Very High - 15.3 fps avg / 5 fps min
1920x1200 0xAA 0xAF DX10/Very High - 13.8 fps avg / 3 fps min
Unplayable.
Old 15th May 2008, 12:11   #8
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
what is strange is that all non-pair generations of nvidia cards have been bad... or simply not up to the challenge....
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key!
DXR_13KE is offline   Reply With Quote
Old 15th May 2008, 12:36   #9
p3n
Hypermodder
p3n is on a distinguished road
Wow the gx2 scales so well in crysis...
weak 'upgrade'
p3n is offline   Reply With Quote
Old 15th May 2008, 12:38   #10
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is on a distinguished road
Is there any chance of an über multi-GPU comparison review?
3-way 9800GTX
3-way 8800GTX
2 x 9800 GX2
2 x 3870 X2
4-way CrossfireX
Would be interested to see how the results turn out, especially the Quad SLi vs CrossfireX
__________________
Current setup: Hiper Osiris | Core i7 920 (Cooled by Noctua NH-U12P) | Foxconn Renaissance | 2x GTX280 | Cooler Master UCP | Corsair Dominator 3GB (soon to be 9GB) | Creative X-Fi Titanium | Vista Home Premium x64 | OS Drive: WD Velociraptor 300GB. Storage: 1x 160GB, 1x 250GB, 1x 300GB, 1x500GB (incremental additions over the years! All Maxtor) | Monitor: Dell 2709W
ChaosDefinesOrder is offline   Reply With Quote
Old 15th May 2008, 12:44   #11
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
I still fail to see the point of these OC-cards that use the reference cooler...
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 15th May 2008, 13:03   #12
Gunsmith
my supersonic radar will help me!
Gunsmith's Avatar
Gunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant future
another reason to stick with the 88xx series
__________________
People who optimise code are wimps. My code knows it's awesome, so it'll take all the time it needs. You can wait in awe
Gunsmith is offline   Reply With Quote
Old 15th May 2008, 13:18   #13
djDEATH
gert rubbish or summat
djDEATH's Avatar
djDEATH is on a distinguished road
3-way 9800GTX
3-way 8800GTX
2 x 9800 GX2
2 x 3870 X2
4-way CrossfireX
Yep - thats what buying these high end cards is all about, if the gx2 scales well in quad sli, then i might buy one, with the option of doubling it up later...
__________________
BEASTIE Lian-Li PC-07b ASUS M2N-E nForce 570 Ultra OCZ StealthXtreme 600W PSU
Phenom X3 8750 BLACK EDITION @ 3.103 Ghz (14.5 x 214 FSB, HTT @ 1070 Mhz) Gainward 8800GT Golden Sample @ 730/1825/1000 Mhz
4GB (2x2GB) OCZ Blade PC8500 CL5 Samsung Spinpoint F3 1TB WD Caviar SE 250GB
djDEATH is offline   Reply With Quote
Old 15th May 2008, 13:38   #14
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
3-way 9800GTX
3-way 8800GTX
2 x 9800 GX2
2 x 3870 X2
4-way CrossfireX
It's something I've been working on (and am still working on) - it's in the balance at the moment given the amount of time it's taken.
Old 15th May 2008, 15:23   #15
Denis_iii
Hypermodder
Denis_iii's Avatar
Denis_iii will become famous soon enoughDenis_iii will become famous soon enough
the addition of the sound passthrew so can output sound over hdmi cable is sweet, but to rich for my blood for that one bonus, would rather pick up 8800GT and if you require more performance get another and go sli
Denis_iii is offline   Reply With Quote
Old 15th May 2008, 16:03   #16
Panos
Multimodder
Panos is on a distinguished road
There are few cards missing from there.
At £260 we should be able to see different combos up to that money.
I bet 2x 9600GT SLI (£170 total both) will be close to the most expensive monsters at 1680x1050.
Panos is offline   Reply With Quote
Old 15th May 2008, 16:03   #17
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
Encouragement +1
Would be awesome to see
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 15th May 2008, 18:27   #18
Brett89
Ultramodder
Brett89's Avatar
Brett89 is on a distinguished road
Before I read the review, I must say that it's shiny and I want it.
__________________
C2D e6700 @ 3.25 Asus P5n-e SLi, 4GB of OCZ Platinum, Xonar D2, 320 and 160 GB Seagate, eVGA 8800 GTX and an Antec P182.
C2D T7500 2.2ghz, 2GB DDR2, Quadro NVS 135M 14.1in screen
Brett89 is offline   Reply With Quote
Old 15th May 2008, 19:41   #19
donnie
donnie's Avatar
Tim cheers for explaining it to me, strangely i've seen this guy called maxishine on youtube who gets some interesting scores but on a second look you were absolutely correct but i still think that the very high test should be run if only to show how it preforms.
Crysis is an odd beast as it doesn't require 30+ frames to run smoothly and has been seen running at 20's fairly nice but i agree that is far from ideal.
Thank you again for explaining it me.
__________________
Old 15th May 2008, 21:54   #20
kempez
modding again!
kempez's Avatar
kempez is on a distinguished road
Agreed with Tim in that running Crysis at below at least 25FPS is just not worth it, even if 'Very high' looks lush. Nothing can do it, even Tri-SLI fails and dips down
Quad SLI: I'm trying to find out, but again I am thinking no
__________________
I don't like streets of rage - make fun of me!
My Main PC: Intel Q6600 D0 @ 3.6GHz | abit IP35 Pro | 8gb OCZ ReaperX PC6400 @ 1000MHz | MSI 8800GTX | OS Drive: Hitachi Deskstar 250gb | Tagan 1100w | Silverstone TJ09S | Noctua NH-U12P
Project Aqua Vitae Project <<| Black3d |>>
kempez is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
