RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th May 2008, 11:17   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Homeplug AV II tech announced
http://www.bit-tech.net/news/2008/05...ch-announced/1
The Homeplug Powerline Alliance has announced the latest revision of its Homeplug AV standard, promising greater speeds for networking over mains cabling.
Tim S is offline   Reply With Quote
Old 28th May 2008, 11:41   #2
sandys
Hypermodder
sandys is on a distinguished road
Yup using it at home after a sucession of failures at getting a robust wireless solution despite trying all sort of routers and aerials, this Homeplug stuff works a treat. I never see anywhere near the claimed speed but get approx 50Mbits a second which is not too shabby and nothing phases it, its great stuff, my HTPC distributes the DTV streams and other video etc over it to other terminals in the house, wireless couldn't cope with that reliably as the badwidth was never solid enough.
sandys is online now   Reply With Quote
Old 28th May 2008, 11:45   #3
Fod
what is the cheesecake?
Fod's Avatar
Fod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of lightFod is a glorious beacon of light
our new house is getting pretty much gutted and remodelled, so i'm just going to wire up cat6 to every room.
it's cheaper and better!
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D."
I'm a pretentious git with a camera.
ISPs want to spy on you. Join the fight against phorm
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Old 28th May 2008, 12:32   #4
andyp06
What's a Dremel?
andyp06 is on a distinguished road
Have had a 3 plug system of the latest 200Mb/s spec after failing to get my 54G wireless system to live with the 8+ other 54G WiFi systems in my neighbourhood. One runs at @86Mb/s & the other at @100Mb/s, so suits the 100Mb/s network it connects to. Overall it is so much better than WiFi, giving a consistent signal & no dropout or range problems. Keeps Wifey happy with her Second Life addiction, so pays for itself with that alone.
andyp06 is offline   Reply With Quote
Old 28th May 2008, 12:45   #5
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
Anyone rewiring a house would be insane NOT to wire for ethernet. I'd imagine it adds several times its cost to the value of a property. However, it's a pretty big job if you're not remodelling anyway - lifting floors and chasing out channels in walls is hardly a small task. That's the situation I'm in - my flat is quite modern and not in need of refurbishment, but isn't wired for ethernet, so I'm using Homeplug. It is faster and more reliable than trying to use a wireless solution in a block of flats with about 5 others, and it's more than fast enough for sharing ADSL broadband, which is all I (and probably 95%+ of home users) really need it to do. If anyone ever decides to roll out fibre to the home here, then I'll rewire for gigabit ethernet because the Homeplug would become a bottleneck, but until then (or, more realistically, until the sky falls in) I'm set.
__________________
Demand Naked DSL in the UK!
mclean007 is offline   Reply With Quote
Old 28th May 2008, 15:44   #6
yakyb
CK is God!!!
yakyb's Avatar
yakyb is on a distinguished road
i think im going to try these out need to get files into my living room and fiance's office but the cost scares me i.e £70 for two just seems extorsionate to me
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7
Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7
Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7
server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2
yakyb is offline   Reply With Quote
Old 28th May 2008, 18:16   #7
AcidJiles
Multimodder
AcidJiles is on a distinguished road
http://www.hotukdeals.com/item/19110...work-kit-85mb/ only 40 quid here
AcidJiles is offline   Reply With Quote
Old 28th May 2008, 18:57   #8
talladega
Don't Ban Me Bro!!!
talladega's Avatar
talladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant future
i just relocated our modem and router to the basement outside my room and i ran two Cat6 cables to my room. we dont have a gigabit router but when we do i will be ready as i have 2 more cat6 cables for the other computers.
luckily its not too hard to run cables through our house.
__________________
THIS IS NOT PATRICK
How to Create Watercooling Tubing in Sketchup
Originally Posted by Krikkit View Post
Big cannons like that make me wet
talladega is offline   Reply With Quote
Old 28th May 2008, 22:57   #9
superseagull
If it aint broke, fix it ;-)
superseagull's Avatar
superseagull is on a distinguished road
i recently bought ZyXEL's PLA 400 200Mbps Desktop Homeplug kit (2 units) for just £70 from scan and have them running at 90-100 mbps and ditched the wi-fi cooking my brain! tis the way to go that's for sure ;-)
superseagull is offline   Reply With Quote
Old 28th May 2008, 23:22   #10
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
think ill keep my cat5 and gigabit switch, (run one cable from flamates room where the router is to the switch)
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 28th May 2008, 23:52   #11
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
i wonder if i could bridge 2 switches with this.....
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 29th May 2008, 01:19   #12
sandys
Hypermodder
Yes you can thats what I do, a switch upstairs and one downstairs linked via my Netgear plugin jobbies.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
