Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Nehalem and X58 show up in Taipei
http://www.bit-tech.net/news/2008/05...up-in-taipei/1
COMPUTEX 2008: We're out in Taipei visiting companies ahead of next week's Computex 2008 tradeshow. We've snagged some pics of baby Nehalem and a very early MSI X58 board.
__________________
#2 |
CK is God!!!
ditch the legacy already (apart from PS2!!)
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7 Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7 Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7 server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2 |
#3 |
glourious bacon?
Strange that, if the main chipset chip runs so much hotter, that there's not a crazy heatpipe configuration bolted on.. or even a fan.
And what's the deal with the heatsink in a box? Looks kooky, but if it's what to expect.. hmm! Exciting though
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#4 |
Pewlius Caesar
bit-tech Staff
I'm pretty sure the blue box is the space they have to leave around the socket (for installing 3rd party heatsinks). It'll be Intel's minimum spec for free space around the socket.
__________________
#5 |
Richard Swinburne
bit-tech Staff
Don't read into the cooling too much it's very much a "test board" - those DrMOS power phases need cooling too I'd think.
It's a shame I couldn't see one fired up though apparently the CPUs are very, very scarce on a per-company basis and are in constant use.It was surprised at the chipset too - but it makes sense given its size (it looked significantly bigger than P45 which is 65nm too) and the tons of super-fast frequency links it has to cope with. Yea, the big blue block is the reference motherboard manuf. (and case etc) need to adhere to to leave completely free - so capacitors and other components don't get in the way. |
#6 |
Blame it on the Boogie
clever thing that
![]() It would be a nice stunt to get a hold of one of those and build a pico-ITX system inside of it
#7 | |
whatever
big keepout area = good, no more trouble with big aftermarket coolers, wooot.
I dont get it why they dont want to drop the legacy crap though, I mean seriously, you cant even buy devices anymore that use them for several years now (talking consumer market here, servers are a different thing, but they get different mainboards as well so it doesnt matter).
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#8 |
quad fuelled, GTX200 powered
nice backplate
i hope Thermalright's Ultra 120 Extreme is just a bracket away from this new socket.
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#9 |
what is the cheesecake?
uh, triple channel memory? what's the deal with that?
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D." I'm a pretentious git with a camera. ISPs want to spy on you. Join the fight against phorm XBL/PSN/Steam ID: FodT |
#10 |
Hypermodder
hmmm to get p35 and wolfdale now or wait till nehalem and x58 are affordable
#11 |
Bwahahahahaha
2+1?
As for legacy ports, you'll always have some prat that doesn't want to sell his Parallel-based printer. At the end of the day, if it works well, then fair enough. But if it really does work that well then buy a cheap Parallel print server, OR spend a similar amount of money on a PCI/PCI-E Parallel card. Fortunately (in most cases, though quite the opposite here) it doesn't matter if you're a tiny minority when you're complaining to companies. "Oh noes, angry users!"
#12 |
Hypermodder
@Denis iii
buy now, wait until the second generations of Nehalem and motherboards come out and some of the issues have been ironed out. Otherwise you'll end up stuck with another Socket 754 (the first gen of Athlon64's which were pretty soon superseded by 939), and trust me, that's annoying. |
#13 |
a.k.a KazeModz
ya I agree with MSI, they should drop at least the floppy seeing how you can use USB floppy drives, I also think the ps2 ports should be dropped as well, I think IDE should probably stick around a little longer maybe just one of then even though I havent used it in a few years.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#14 |
Supermodder
Ditch parallel, floppy, but keep PS2 ports
#15 | |
Beef Potato Wheelman
Tim, are you sure the mounting is different?
__________________
No, I don't have a worthy signature. Fact is, I don't know why you're reading this. |
| Multiplectic |
| View Public Profile |
| Find More Posts by Multiplectic |
#16 |
What's a Dremel?
Great early look at the Nehalem platform!
They need a third color of DIMM slot for the third channel... Right now it looks like dual channel with three slots per channel rather than the other way around. Also, aren't the extra 4x PCIe lanes in the X58 used for the link to the ICH10 SB? Traditionally, the DMI link from NB to SB is 4x PCIe... More info on Nehalem and X58 here... http://www.nehalemnews.com/2008/04/nehalem-faq.html |
| virtualrain |
| Find More Posts by virtualrain |
#17 |
What's a Dremel?
"MSI also includes six memory slots because the CPU has triple channel DDR3, and exclusively DDR3, so you’ll have to buy at least three DIMMs to make the most of the new upper-tier Intel platform."
I think you'll find that's because it is. Except It's not dual channel with three sticks, it's triple channel. It's the performance advantage DDR3 has been needing to ensure uptake, now if only it drops to semi-decent levels. It doesn't need to be awesomely cheap considering the performance advantage triple channel memory would have over dual channel, since enthusiasts would be more than willing to pay a price premium. |
#18 |
VGChartz PR Manager
Windows Vista doesnt have a floppy drive standard in the OS does it? If I remember it doesn't so drop it since even M$ dropped it.
__________________
http://thebladeclan.com |
#19 |
Controlled by Eyebrow Powers™
This may be a bit retro, but triple channel can be a good thing for 32-bit Windows users, as you can put 3 Gb of RAM on the system, instead of 2 or 4 Gb.
#20 |
Multimodder
32bit OS and Nehalem is like a black-and-white 1080p television.
Really, 64bit Vista is mature now. Time to let go. |
| Thread Tools | |
