RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Jun 2008, 09:11   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Gigabyte G45 board plays HD movies over VGA
http://www.bit-tech.net/news/2008/06...ies-over-vga/1
COMPUTEX 2008: Gigabyte showed us its new G45 mobo playing Blu ray movies on two popular players using a normal VGA connection.
Tim S is offline   Reply With Quote
Old 6th Jun 2008, 09:58   #2
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
HDCP drm is invented by morons and pushed into our mouths by money wolfs of 4 big companies that think they control the world of music and movies, its a useless peace of crap that nobody on this world needs or wants or has use for but we all have to pay for it.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 6th Jun 2008, 10:00   #3
Paradigm Shifter
Lethargic
Paradigm Shifter's Avatar
Paradigm Shifter will become famous soon enough
Watch this HD over VGA feature vanish as soon as the MPAA can get it's attack dogs (lawyers) ready...
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA
Paradigm Shifter is offline   Reply With Quote
Old 6th Jun 2008, 10:36   #4
[USRF]Obiwan
Ultramodder
ssssstt! (they can hear us you now)
p.s. we can always use the asus usb monitors...
__________________
Old 6th Jun 2008, 10:39   #5
Xtrafresh
Blame it on the Boogie
Xtrafresh's Avatar
Xtrafresh is a jewel in the roughXtrafresh is a jewel in the roughXtrafresh is a jewel in the rough
am i the only one that sees a pretty mint-looking LAN board in this one?
It's compact-ish, has sata-o-plenty, and leaves room for a good GPU + soundcard. Do we need more?
Xtrafresh is offline   Reply With Quote
Old 6th Jun 2008, 12:10   #6
shahidur
What's a Dremel?
shahidur is on a distinguished road
I was under the assumption that HD playback is possible over vga as it is an analogue connection. HDCP is only required over a digital connection.
shahidur is offline   Reply With Quote
Old 6th Jun 2008, 18:45   #7
Renoir
Multimodder
Renoir is on a distinguished road
Correct shahidur. The video should only get downrezzed over vga if the Image Constraint Token is set on the discs which AFAIK is not the case with any of the currently released discs.
Renoir is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
