Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
Cyberlink, Realtek, Gigabyte fix HD audio problems
http://www.bit-tech.net/news/2008/06...udio-problem/1
Cyberlink and Realtek have now fixed the audio downsampling problem that means you'll finally get full HD quality sound from Blu-ray discs.
#2 |
International Man of Awesome
I bloody well hope the Realtek ALC885 is included, my HTPC is going to have an ASUS Mobo as opposed to Gigabyte, since I needed Digital Coax-out.
__________________
Q6600 @ 2.40GHz w/G0|Gigabyte GA-G33M-DS2R|4GB OCZ Gold PC-6400 800MHz|Powercolor Radeon HD4850|Samsung Spinpoint F1 1TB|Scythe Ninja Mini|LG Blu-ray/HD DVD/DVD-RW Combo Drive|Corsair TX650W|Antec NSK2480
Pioneer VSX-417|2x Gale 3010|2x Yamaha NSP110| MS304W Centre | MS308 Subwoofer |
| Timmy_the_tortoise |
| View Public Profile |
| Find More Posts by Timmy_the_tortoise |
#3 |
Freed on Probation
took them long enough!!!
snazzy,i dont even have to upgrade my gigabyte 690g board... very good news this as i was worried i was going to have to fork out the auzentech prelude and the hdmi expansion board to get this working in the long run! Think its now coming time to upgrade my aging pioneer amp to a snazzy truehd capable jobby ![]() edit: bindi i take it this only for powerdvd 8 ultra then? :@ and how will this work if youre using a seperate graphics card? im using a 2600xt at the mo, will the sound be able to be passed through that or will it only be able to come out of the motherboards hdmi out?
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson Last edited by fathazza; 12th Jun 2008 at 12:35. |
#4 | |
Ultramodder
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#5 |
Freed on Probation
i thought that the reason other than DRM why the hd audio wasnt implemented before is that spdif didnt have the bandwidth to carry the bitrate required for five+ channels. And that the only way to do it would be via analogue or over hdmi
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson |
#6 | |
I'm pretty sure S/PDIF would be able to carry the signal, otherwise it's stupid because not everyone has HDMI... and a HD A/V Receiver with S/PDIF and no HDMI would then be useless.
__________________
#7 | |
Freed on Probation
just because it isnt digital doesnt mean it isnt hi-def, analogue is obviously capable of transmitting uncompressed signals... and given that an amp without hdmi inputs can have hd sound transmitted to its pre-outs. tis all pretty well explained here... http://www.dolby.com/consumer/techno...HD_avrs_2.html
__________________
#8 |
I think you've misunderstood something... somewhere.
Dolby TrueHD IS digital. It is not analogue, and therefore it cannot be sent over an analogue connection. The only way (other than HDMI) that this signal can therefore be sent is over S/PDIF...
__________________
#9 |
Freed on Probation
as long as you have a good DAC then the difference between a digital and analogue connection is minimal. As i said previously you can transmit uncompressed audio for 5 channels over analogue whereas you cannot over spdif due to bandwidth contraints. If you read the link in the post above if you try to transmit TrueHD over spdif it has to be down mixed to dolby digital.
__________________
#10 | ||
Multimodder
S/PDIF does not have the bandwidth to carry multi channel high def audio. The options are 1) analogue connection to either pc speakers or to a receivers pre-outs 2) converted to LPCM and then transmitted over hdmi 3) send the raw bitstream over hdmi 1.3 e.g. dolby truehd. It will be interesting to see when amd and nvidia release gpus that will fully support hd audio transfer over hdmi. Quote:
Renoir |
#11 |
I stand firmly corrected, with my masculine pride hanging despairingly from the sharp, fierce hands of personal research.
I shall retreat.
__________________
#12 |
Freed on Probation
thanks for the info renoir,
my motherboard does have the Realtek ALC889a chipset mentioned in the original news post. but it doesnt have any onboard video processing for bluray/hdvd, which is what i bought the 2600xt for... So i guess right now i have a graphics card that does video and a mobo that might be able to do the audio if cyberlink release this patch. I understand the point about dummy signals but it seems a little complicated and surely there might be some syncing problems to go with it. I think my best bet might be to sell on the 690g board and 2600xt and get myself a 780g board instead which has onboard Hd video acceleration, and the added benefit of requiring lower power than my current combo. Tho i guess its a bit of a moot point until this patch is released and proved to be working. Still i guess the time it takes for that to happen will give me time to save up for a nice onkyo 606 receiver
__________________
#13 | |||
Richard Swinburne
bit-tech Staff
/looks at past bite marks
#14 |
Multimodder
sorry timmy I had just posted a rebuttal to your earlier post but did so after I saw your retraction and so have edited this post.
#15 |
I just realised how embarrassingly bad my choice of metaphor was.
My pride drops ever lower. I at least have the comforting excuse of my relative newcomer status in the enthusiast arena.
__________________
#16 | |
Freed on Probation
how very un-cyberlink-like of them, they usually quite like to force people to pay for features they should have included in previous versions and even for downgrades... (like powerdvd 8 removing full hd-dvd support!) any further news on how this is all going to work would be most welcome
__________________
#17 |
Richard Swinburne
bit-tech Staff
Actually they've been offering free upgrades for stuff for quite a while when you purchase the Deluxe and Ultra versions - stuff like BD Live and BD 1.1 updates were free. It's only the OEM stuff that requires upgrading copiously, usually.
PDVD 8 was introduced after HD DVD died, it's hardly surprising tbh. :/ |
#18 | |
Freed on Probation
I just meant that functionally powerdvd didnt really change that much from version 3 to 6... im sure there were changes but in practice i doubt youd really notice them... while hd-dvd may have died why remove it as a feature? they could have just let it be...
__________________
#19 | |
Richard Swinburne
bit-tech Staff
I agree with the removal of HD DVD, but if you include it you have to support it - I suppose it was just easier to concentrate on getting one standard right. |
#20 |
Wait.. PowerDVD Ultra 8.0 DOESN'T support HD DVD? Oh man... I was gonna buy a combo drive for my HTPC and get some cheap HD DVDs from gamestation.
I'm gonna have to see if I can get 7.0 instead.. Maybe the drive will come with 7.0 anyway.
__________________
| Thread Tools | |
