#61 |
What's a Dremel?
![]() ![]() to many killer hardware pieces just begging to be modded and overclocked ready to frag ![]() , nice project you got here bro keep going!
#62 |
Coolermaster Legend
Its a bit of a headache choosing which blocks to go for CPU's and NB due to hose routing but after much head scratching it looks like D-Tek FuZions for CPU's and a DD MC-Chipset block with a modded mounting bracket will be best.
So, decided to make myself a nice little mounting bracket for the MPC-Chipset block..... Started by scribing the shape onto a 3mm piece of aluminium then took the original MPC mount to mark hole alignment. Not sure if there's time to get it anodised black or whether i'll just have to paint it but either way it looks OK and fits like a glove ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#63 |
Project: Elegant-Li
Awesome work on the plate, you should polish that up lol.
__________________
Project: Elegant-Li *NEW* Project: Alpha FINISHED Project: LEXA Revival FINISHED Project: LEXA FINISHED MOTM Nominee October 08 |
#64 |
Supermodder
Stunning.
__________________
Gigabyte P35-DS3L | Intel E2220 @ 3.0GHz | AC Freezer 7 Pro | eVGA 8800GT 512MB | 2GB Crucial Ballistix DDR2-800 | 1 x Seagate 250GB SATA | 1 x WD Raptor 74GB SATA | X-Fi Extreme Gamer | Silverstone Strider 600 Modular | Modded Antec Nine Hundred
#65 |
Epic destruction around machinary
wuu pretty
#66 |
Coolermaster Legend
Yeah, cheers i think i might polish it
![]() Got the side panels back from powder coat today which is a great way of flattening down the standard brushed aluminium and a great flat base for primer so its time to start attaching the vents. Had to use that 2 part metal stuff to attach a couple of bolts to the back side of the vent to enable it to be screwed down. I also got hold of this Terotape and Primer which gives the vent a nice cushion to sit on which hopefully eliminates paint cracking when the side panel flexes. So anyway, this is how it looks and now i've got a night of bodging and wet sanding ahead to blend the vent into the panel then get it into primer ready for paint. Just did a test fit with the chrome bits on to see what the whole thing looks like in black ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#67 |
The meaning of life is to MOD
Nice work on the Block and vent. love it
#68 |
CHEA BRO!
HOLY $!@# a skulltrail! Nice! I can see this will be ine mother of a PC, im sure it will be great!
__________________
Rigless. |
#69 |
Multimodder
WOW...this rig sounds absolutely intense!!!!
#70 |
Project: Elegant-Li
This is looking sweet.
__________________
#71 |
heyy coolmiester!! come back!! =]
updates please! good job so far |
#72 |
Coolermaster Legend
A long day of filler - sanding - wet sanding - more filler - more wet sanding and not much more tbh but all ready for primer, paint and clear coat so see what tomorrow brings
![]() Oh yeah and i polished the NB block mount (cheers The boy 4rm oz) ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
#73 |
________
What colour are the panels going Paul?
Also, how are you going to pain them? |
#74 | |
Coolermaster Legend
__________________
#75 |
The Mod Zoo Podcast Host
looking great Paul! Personally would have left the block brushed but it looks cool polished too. Are you not sick of polishing? lol
Kyle van der Merwe
__________________
Kyle van der Merwe host at www.TheModZoo.com Podcasts!
Project: Codename C :: LANBOY APOCALYPSE (built with MNPCTECH!) :: Project: Deadline :: Project: MNU Projects supported by EK Waterblocks, MNPCTECH, Fractal Design, NZXT, ENERMAX, and TM3 Connections Core i7 920 D0 :: Asus P6T Deluxe v2 :: 6GB Crucial BalistiX :: Asus GTX 570 :: ENERMAX Platimax 850W :: OCZ Agility 3 120GB :: 4x Samsung SpinPoint F3 1TB |
#76 |
________
#77 | |
Coolermaster Legend
LOL no not really but you're right, i may get it anodised black time permitting.
__________________
#78 |
Multimodder
First off, I'm am so impressed with your mod and gave me a few ideas of what I might do with my old computer. Where did you get the sheet metal and bolts for the front of your case.
__________________
Asus p5k Core2duo E 6750 4gb Cosair XMS Windows 7 64-bit HX520 Cosair PSU 8800 GTS, 500gb Seagate |
#79 |
Supermodder
The block looks super nice polished. As far as I'm concerned you can never have too much polished aluminum.
![]() ...I still go back and drool over your ShinyMaster project at least once a month. I'd kill someone to get ahold of one of those cases...
__________________
#80 |
Multimodder
Gotta love that case, was playing with a customer's. Especially the sensor off/on button
| Tags |
| case mod |
| Thread Tools | |
| View Mode | |
