RSS
Reply
Thread Tools View Mode
Old 15th Jun 2008, 20:49   #1
tomcatt
WoodWoodWood
tomcatt's Avatar
tomcatt is on a distinguished road
HELGHAN - a Killzone2 CM - FINISHED !!!!
Hello everybody
I am new on this forum, so first let me introduce myself
My name is Tom (aka Tomcatt) , I’m almost 17 years and I’m from Belgium. I am doing casemodding for almost a year now. My first case was a caseconstruction, made of wood, but it didn’t work out so good. In September 2007 I started a new casemod. Thanks to a Dutch casemodding website I met a seller from a casemodstore, And now he is my sponsor
I buy all my casemodding stuff @ it-service in Belgium because it’s a store where almost everything is available for a very good price
Well, now let me introduce you to my casemod.
HELGHAN is the name , and Killzone2™ is the game
Helghan is the name of the planet where the helghast live on (ingame= enemy).
The design of my case is from an art design screenshot: (the building on the right side)
The first thing I started was making sketches, after a while I began to work with google sketchup. These are some designs:
As you can see, these sketches are not very good, But you get the idea
I did a lot of research on the sites of killzone™ to get a better background view of the game, so my modding work will be easier
Material:
The case will be made of wood ( MDF). I like to work with wood but I didn’t have lessons for this at school or something, no this is my experience .
For cutting the wood I mostly use a jigsaw, and files, a scroll saw and some other equipment. I do not have a mill but hey, we can work it out like this
Making the gun
Before the case arrived I made some other stuff for designing the case.
Because Killzone™ is a shooting game I made a weapon for on top of the case. First I searched some pictures and printed them out… And I made a drawing myself on a large sheet of paper.
After that, I began to work it out.
It will be something in 3D as you can see :
This is the basic, I will use the dremel to give it a final finish.
I also made a controller of the FANs. There will be 4-5 FANs in my case and I am making a controller to create a silent/refrigeration choice :P
Here you can see the switches: (5V or 12V)
After a couple of days, The box arrived – Oléy !
And what was in it ? A nice case for modding. It is the MS-tech LC182 very cheap but that’s oke.
So it was time to strip the case :
Next, I made a basic ground plate (12mm MDF) where the case stands in.
There will be columns on the side panels so I made a piece of wood for the attaching.
And both sides: above and beneath:
The wood is made like that so the side panels still can be opened for later.
Then I made the columns …
In between the columns there is place for a window (3 small windows actually). But I think there needs to be something more special on the sidepanel so I think and think, and with a headache I found the solution .
Well… here you see the solution :P
Total picture : (you can see where the windows will come )
Well after that, I worked further on the columns:
To have a little break (with columns) I started on the intake in front
Then I cut it with the Dremel®
Then , to design the intake cooler, I made a “door” – it can’t move but is just for design
The door will get a nice texture afterwards
I also made some lightning for the backside of the motherboard, it is not good to see, but the details can make a difference
Then I already started on the top side of the case.
I ordered 2x 120mm FANs for the top … the case is small but it must work !
So I started to make 2 holes for the FANs.
For the security, there will be mesh …
A piece of wood where the mesh fits in …
The result:
The secret: Arctic cooling fans, they have standard rubber foots so they are silent
Well, as you can see … there is not a lot of place to get a power supply in the case (because of cooling);
So I thought again, and found an answer again . The PSU will be for a part outside the case, part inside.
This is an old PSU …
I ordered a new one @ it-service, again very satisfied from the store
It is a 500W , 140mm cooling FAN with nice cable sleeving.
__
Then for the inside, I found something new for the design . The Helghast (enemy = ingame) need also cooling to survive on the earth. – I don’t know how you call it, but it’s a part from the machine what you use to suck dust (xD) hehe, here an explanation. It has got an UV orange finishing.
This is the place in the case where I use it
After this, I made the front:
WOODWOODWOODWOOD
Some more @ the intake… there will come a controller for the light in front.
The light controller:
In the bottom of the case there will be some spectacular lightning, a plexi sheet with the logo of de developers of the game killzone.
Well, it would look like this when it is finished:
Back to the side !!
Here you see some improvement on the lights @ the side
But it won’t be as shiny because of coming details and paint inside the “cells” , details like these :
Then I was fully concentrated on the sidepanel again.
For the lights in the case I have a special way to connect them once the side panel is attached.
A hole for connection:
And covered by my hand-made grill
Tadaaa !
Still to come: plexiglass for the windows and filling, scouring and painting the sides
That will be for September- October
Next: The backside
First I made a sheet of wood again (4mm MDF) to fit the back.
Then I made a hole for the 80mm FAN, and I jigsawed the rest of the connections.
For the Power supply I made a cover as well:
Then, I made some air holes to give the back a little bit more … more
Don’t mind the tape
________________________________
The other side (hey, that is a pub here in town “den TOS” :P )
There is no place for a window here, so I replace it with a logo of the Helghast.
Making a drawing (not in sketchup or autocad … just pencil and paper )
Making it possible in wood
Then I ordered another sheet of plexi, thank you again IT-Service
The intention is to make the logo glow – With LED lightning
The plexi still needs a finishing touch but here is a result of what it would look like.
And this is my final picture of the first, major intro- update.
I know These are a lot of info and pictures to watch, but I hope you enjoyed watching.
Comments and critics are very welcome !
Now I have exams, (math tomorrow ) but I hope to give you an answer if you have question.
___ KEEP ON MODD!NG ___
___ TOMCATT ___
tomcatt is offline   Reply With Quote
Old 15th Jun 2008, 20:56   #2
jhanlon303
6 decades of fun
jhanlon303's Avatar
jhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond reputejhanlon303 has a reputation beyond repute
An ambitious project and coming along well I really like all the lighted acrylic.
I'll be watching
John
__________________
Life is it's own answer. Live life for itself. Accept it and enjoy it day by day. Live as well as possible. Expect no more.
Destroy nothing, humble nothing, look for fault in nothing. Leave unsullied and untouched all that is beautiful. Hold that which lives in all reverence.
jhanlon303 is online now   Reply With Quote
Old 15th Jun 2008, 21:23   #3
Cheapskate
know-it-all b*stard...
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
An impressive start.
Cheapskate is online now   Reply With Quote
Old 15th Jun 2008, 21:35   #4
Rozzy
I'll get there :P
Rozzy's Avatar
Rozzy is on a distinguished road
<= enough said...
Rozzy is offline   Reply With Quote
Old 15th Jun 2008, 21:38   #5
Ashaman
M'hael
Ashaman's Avatar
Ashaman is on a distinguished road
I'm speechless!
This is one of the most impressive mods I've seen built out of wood/mdf! That design turned out really good!
I'm looking farward to see your progress on this one. keep it up!
Ashaman is offline   Reply With Quote
Old 15th Jun 2008, 22:08   #6
modgodtanvir
Prepare - for Mortal Bumbat!
modgodtanvir's Avatar
modgodtanvir is on a distinguished road
Welcome to the forums dude.
I am VERY impressed. Your idea is very interesting, and will make for a brilliant mod. Your planning and sketches very very impressive. Your building work so far has been to a very high standard, and looks brilliant. Your lighting so far looks very good, and your photography is spot-on and your project log is very well written.
No end of praise for what's been done so far, and I look forward to seeing more. Consider it *subscribed*!
__________________
Nexxo: Oh, and Relix is god, and ComputerKing is his prophet.
Mankz: Meh. So what am I?
dragon2309: Weak wristed...?
modgodtanvir is offline   Reply With Quote
Old 15th Jun 2008, 22:08   #7
charlesbeams
TRANCEFORMer
charlesbeams's Avatar
charlesbeams will become famous soon enough
wow, looks good so far
__________________
MyAnimeList
charlesbeams is offline   Reply With Quote
Old 15th Jun 2008, 22:09   #8
DaveVader
is just really nice
DaveVader's Avatar
DaveVader is a glorious beacon of lightDaveVader is a glorious beacon of lightDaveVader is a glorious beacon of lightDaveVader is a glorious beacon of lightDaveVader is a glorious beacon of lightDaveVader is a glorious beacon of light
Originally Posted by Rozzy View Post
<= enough said...
so amazing!
__________________
Current Rig: Gigabyte EP45 DS3L | E8400 | 4*1GB PC6400 | HD4850 | 80GB Seagate/1TB WD Element
Originally Posted by Gunsmith View Post
my friend, you would have far greater chance survival if you successfully fisted a Velociraptor.
DaveVader is offline   Reply With Quote
Old 15th Jun 2008, 22:20   #9
MrWizard
Still Wrenching
MrWizard's Avatar
MrWizard is on a distinguished road
You have my attention, tomcatt.
__________________
Gigabyte P35-DS3L | Intel E2220 @ 3.0GHz | AC Freezer 7 Pro | eVGA 8800GT 512MB | 2GB Crucial Ballistix DDR2-800 | 1 x Seagate 250GB SATA | 1 x WD Raptor 74GB SATA | X-Fi Extreme Gamer | Silverstone Strider 600 Modular | Modded Antec Nine Hundred
MrWizard is offline   Reply With Quote
Old 15th Jun 2008, 22:22   #10
Nolimited
Supermodder
Nolimited's Avatar
Nolimited is on a distinguished road
Very impressive and the work on the wood are realy nice
it will be an amazing mod
Nolimited is offline   Reply With Quote
Old 15th Jun 2008, 22:54   #11
Shadowed_fury
Natural Born Chaos
Shadowed_fury's Avatar
Shadowed_fury is on a distinguished road
Stunning!
__________________
Steam: kev_fury New Frag Video
- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston -
- Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA -
Shadowed_fury is offline   Reply With Quote
Old 15th Jun 2008, 23:05   #12
Kenny_McCormick
Play hard, go pr0n
Kenny_McCormick's Avatar
Kenny_McCormick is on a distinguished road
Great work dude, I like it. Please, keep going.
PD: The machine wich sucks the dust it's called "vacuum cleaner"
__________________
Planet Express Klan (modding & gaming clan) --> www.pekweb.es
Sorry for my bad english
Kenny_McCormick is offline   Reply With Quote
Old 15th Jun 2008, 23:47   #13
Xtrafresh
Blame it on the Boogie
Xtrafresh's Avatar
Xtrafresh is a jewel in the roughXtrafresh is a jewel in the roughXtrafresh is a jewel in the rough
very nice, welcome on the forums tom
Xtrafresh is online now   Reply With Quote
Old 15th Jun 2008, 23:47   #14
Stievius
Vice Benelux Champion Casemodding
Stievius's Avatar
Stievius is on a distinguished road
One of the better Belgian MDF mods around these days
__________________
»My website: SteveSalens.com V2.0
Project: Xionized
Powered by IT-service.be
-next project comin' up!-
Stievius is offline   Reply With Quote
Old 16th Jun 2008, 00:49   #15
MShort
putting the "i" in team
MShort's Avatar
MShort is on a distinguished road
wow, your workmanship is very good, welcome to bit-tech
MShort is offline   Reply With Quote
Old 16th Jun 2008, 01:51   #16
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has a spectacular aura about500mph has a spectacular aura about500mph has a spectacular aura about
That was an amazing intro. The case looks amazing already.
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 16th Jun 2008, 02:14   #17
airchie
Mod Master
airchie's Avatar
airchie is on a distinguished road
Yeah, good work for having no experience in woodworking!
Keep it up.
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64
Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF.
Originally Posted by astralwandrer
Being a legitimate customer of the games industry is increasingly like being in a relationship with an abusive spouse.
airchie is offline   Reply With Quote
Old 16th Jun 2008, 03:30   #18
Oreon_237
Lawrence
Oreon_237 is on a distinguished road
impressive! to say the least!
you have got some serious skill in wood working, for no woodworking classes!
I have a math exam tomorrow too! LOL
__________________
E8400, P5Q pro, corsair PC 6500 2x2GB, Galaxy GTX 260+, Samsung F1 750GB
Oreon_237 is offline   Reply With Quote
Old 16th Jun 2008, 03:42   #19
Aceanuu
Will-Mod-for-Food
Aceanuu's Avatar
Aceanuu is on a distinguished road
*claps*
Wow, I am really taken aback by this. Seriously impressive. Its a great inspiration for me to see that this kind of stuff is possible by just normal people (I'm dying to make a casemod myself... but gotta start small I keep sayin').
Consider this a subscription, I can't wait to see where this goes.
Aceanuu is offline   Reply With Quote
Old 16th Jun 2008, 04:26   #20
tomcatt
WoodWoodWood
tomcatt's Avatar
Thank you very much for the responds , I try to make the best of it offcourse
Kenny_McCormick: The machine wich sucks the dust it's called "vacuum cleaner"
Thank you , now I know the word again
thanks again all, I really like bit-tech oewyeah
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
