Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Heatsink testing overview
http://www.bit-tech.net/hardware/200...ing-overview/1
Reliably testing CPU heatsinks can be a tricky business, with so many variables capable of jeopardising accurate results. For this reason, we've re-assessed our testing methodology, and put some of the most popular and high-performing heat sinks through their paces in our new standard test setup.
__________________
#2 |
Get On My Horse!!!
The vendetta did quite well under load. I thought it would perform worse.
__________________
Project: LEXA FINISHED 30/11/08 (16 months 14 days) MOTM Nominee October 08 Project: LEXA Revival FINISHED
#3 |
quad fuelled, GTX200 powered
oh yeah! TRUE is still the top one.
i bet it can drop a lot more degree if you use one or two high CFM fan. so what heatsink are you planning to test next? one of those newer direct contact heatpipe ones? many test sites say they are better than TRUE....... me wants a reliable source.
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#4 |
Minimodder
Nice review, as always.
Btw there's a Noctua instead of a Thermalright 120 on last page.
__________________
"The Christian god can be easily pictured as virtually the same as the many ancient gods of past civilisations. The Christian god is a three-headed monster; cruel, vengeful and capricious. If one wishes to know more of this raging, three headed beast-like god, one only needs to look at the calibre of the people who say they serve him. They are always of two classes: fools and hypocrites." John Adams |
| ViPPeR_666 |
| View Public Profile |
| Find More Posts by ViPPeR_666 |
#5 | |
Pewlius Caesar
bit-tech Staff
__________________
#6 |
Mini Love
typo error on the noctua title
dam i'm getting anal in my senility. surprised there's no bit-tech badges applied here to highlight the best of the punch, editors pic, recommended etc. i like those badges. makes reading a non-necessity. or was that the point?
__________________
Death to consolification !!! [size=1]Give me my Windforce! I'm coming back! |
#7 |
Multimodder
wth is a delta-t stand for?!?!
i use the Coolermaster CM Sphere and, i was blown away with it's performance, 22c idle and 43 on load. I am running the fan passively, as the fan that comes with it was to loud :P, with the fan is was 35 or so, but there are 2 fans blowing on to it :P :edit: mind you, i am only running a E6600.. Last edited by Sark.inc; 16th Jun 2008 at 12:00. |
#8 |
I feel your presents.
I should be receiving a Xigmatek HDT-S1283 from Scan in the next couple of days - from a couple of reviews, it looks to be pretty good, if not better than a TRU. See if it fits my mobo first though
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#9 |
Pewlius Caesar
bit-tech Staff
It's the difference in temperature (a delta) between two values (in this case the CPU and ambient temps).
__________________
#10 |
Multimodder
i think that's a miserable testing methodology. Ambient temps to the nearest whole number? if you're going to test coolers at differing ambient temps then you shouldn't even be displaying the temperatures. it's just misleading.
this, despite being very old, is the way to do it. http://www.dansdata.com/coolercomp.htm |
#11 |
Old git.
I know we aren't trying to compete with SPCR, but some sort of metric for noise would be good; perhaps as simple as marks out of 10. Subjective is better than nothing.
__________________
P180B, Q6600 [with Thermalright HR-01+/Noctua NF-P12], 8GB OCZ Reaper PC2-8500, EVGA GTX 260 SSC, 3.75TB worth of Samsung F1s, running on Windows 7 RC |
#12 | |
Live long & prosper!
Why do you think it's misleading anyway? Andy
__________________
New Rig : GA-X38-DS5, Q6600 (running at stock until I get everything installed), 8GB OCZ RAM (not sure on timings), Inno3D 8800 GTS 512, Noctua NH-U12P heat sink, Hiper Type M 580, 4 HDDs, 2 opticals, Saitek Eclipse II keyboard, Sharkoon Rush gaming mouse, Samsung 2220WM monitor, running XP SP2 (32-bit), Vista HP (x64) and Fedora 9 Beta (x86-64).
#13 |
Benchmarketeer
bit-tech Staff
Testing in the same ambient temperature is one of the very expensive options we just don't have. In an ideal world we'd test in an air conditioned, climate controlled room, where we can control the temperature to the nearest degree, but the sad fact is we can't, and so have to publish the ambient temps vs highest load temp as the key performance value.
For the same reason, we round to the nearest degree, as consistantly accurate thermometers are not cheap. While I admit it's not 100% accurate, I feel our test methodology is better than most, and gives a solid indication of real world performance, that you'd get if you fitted the heatsink in your own case, not just if you fit the heatsink on a test bench. Although if anyone wants to donate a laboratory grade thermometer, feel free
#14 | |
Just got a great book on tape
__________________
Gigabyte MA790FX, X4 9950 Black Edition, 8gb Geil Black Dragon, 2x4870 512mb, Antec TruePower Quattro 850w I game, Do you? |
#15 |
Air Cooled Fool
Good to see my TRUE120 is still king of the coolers.
One test I'd like to see is how the cheapest and most expensive coolers (say a TRUE120 and a Freezer 7) compare for different chips. Eg, test bother with a low power dual core, and both with a heavily overclocked quad. I'd image the TRUE120 would pull out well ahead for the quad and be much quieter, but there would be little difference between it and the Freezer 7 Pro for the low power chip. Some actual numbers to back this up would help people in choosing a cooler suitable to their CPU.
__________________
- Q6600 G0(9x333) -- Asus P5k Premium -- 2GB Ballistix DDR2-800 -- BFG 8800GT 512MB -- TRUE120 -- 500GB Samsung Spinpoint -- Antec Quattro 850W -- Samsung Syncmaster 206BW -- Razer Lycosa, DeathAdder, and Destructor -- Antec Nine Hundred --
Pistol Pete's Project Perspiration Project Log |
| pistol_pete |
| Find More Posts by pistol_pete |
#16 |
Minimodder
ohhhh hahaha! my bad
__________________
| ViPPeR_666 |
#17 |
Multimodder
#18 |
I Mod, Therefore I Own
Those load temps seem a good 10c under what most other reveiws of the TRU seem to achieve?! 44C LOAD is very low!
__________________
-Yesterday is History, Tomorrow is a Mystery, Take the Present as a Gift- |
#19 | |
2n-1
Greetings!
"All CPU temperatures are recorded from the MSI PC Alert 4 software in the operating system" Temperatures are not from CoreTemp or RealTemp. One needs to add another 10-15ēC to compare to other reviews.
__________________
The recruitment of Militia is illegal. Militia-recruiters will be prosecuted to the fullest extent of the applicable laws. |
#20 |
Supermodder
Water cooling cheesecake!
| ParaHelix.org |
| Find More Posts by ParaHelix.org |
| Thread Tools | |
