Old 24th Jun 2008, 09:14   #1
Daniel114
Supermodder
Daniel114's Avatar
Daniel114 has yet to learn the way of the Dremel
Cable management
I've always tried to keep cables tidy when building a new PC, although sometimes I'm just eager to make sure everything works alright so put it off for a while. Anyhow last night I spent a good few hours cleaning my PC and trying to sort the cable's out, howver at the end of it all (due in part to a SATA connection problem arrising) I looked at what I'd done afterwards, and in all honesty it just looked abysmal, hardly any change.
So what I was wondering is how long on average you guys spend trying to sort cables out, and if you had any useful suggestions, I'll try and post a pic when I get home, but at the moment I just seem to be pushing all the slack cables into the 5.25" rack, and occasionally getting some behind the mobo.
Cheers for the help, vague question I know
Daniel114 is offline   Reply With Quote
Old 24th Jun 2008, 09:32   #2
mushky
gimme snails
mushky's Avatar
mushky has yet to learn the way of the Dremel
5 mins tops, good enough to help the airflow.
mushky is offline   Reply With Quote
Old 24th Jun 2008, 10:15   #3
CobraMods
Gettin there slowly
CobraMods's Avatar
CobraMods has yet to learn the way of the Dremel
depends on the effect you are after as it will directly relate the the amount of time spent running wires.
for a totally clean look you can expect to spend upwards of an hour and a half to snake the wires behind the mobo, along edges,behind various components sometimes even cutting and extending wires so they can be totally hidden from view.
if your going for a basic air flow increase and not too worried about the visual aspects too much then the 5-10 min rule would apply.
nice little touch i do even when just improving airflow is to color match the wiring to the case interior with spray paint. that way even if you cant hide them all behind this and that they dont stick out like a sore thumb when you look in the box.
CobraMods is offline   Reply With Quote
Old 24th Jun 2008, 11:27   #4
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpit
due to my choice of case (Antec p182, with space behind mobo tray for routing cables). i spent about an hour putting inside the case after making sure it works outside the case. now, apart from fan cables and PCI-e cables, there are no visible cable.
IMHO, the case is most important, a bad case will see you spend hours without any improvement.
what case have you got?
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is online now   Reply With Quote
Old 24th Jun 2008, 12:17   #5
Ryu_ookami
Mod Master
Ryu_ookami's Avatar
Ryu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for president
About twenty minutes- sort of sleeving ever cable in the PC as I use a spiral type cable sleeving that doesn't require the connectors to be removed then about 10 minutes cable tying them and placing them along the path I want them to follow.
Ryu_ookami is offline   Reply With Quote
Old 24th Jun 2008, 12:19   #6
pistol_pete
Air Cooled Fool
pistol_pete's Avatar
pistol_pete has yet to learn the way of the Dremelpistol_pete has yet to learn the way of the Dremelpistol_pete has yet to learn the way of the Dremelpistol_pete has yet to learn the way of the Dremel
I spent a weekend cutting holes in my Antec Nine Hundred to hide the cables behind the motherboard - though much of that was just waiting for my 12V drill to recharge!
Same case, but compare the difference between the old system and the new one with the holes cut!
So really it depends on your case. If you have messy old multi-wire cables you could wrap them in spiral-wrap or cable sleeving. Use cable-ties to hold coils of slack wires.
__________________
- Q6600 G0(9x333) -- Asus P5k Premium -- 4GB Ballistix DDR2-800 -- EVGA GTX570 -- OCZ Vertex 2E 128GB -- 500GB Samsung F2 -- Antec Truepower New 650W -- Samsung Syncmaster 206BW -- Razer Lycosa, DeathAdder, and Destructor -- Custom Buitl Watercooled Case --
Pistol Pete's Project Perspiration Project Log
pistol_pete is offline   Reply With Quote
Old 24th Jun 2008, 12:21   #7
Daniel114
Supermodder
Daniel114's Avatar
Same as you, Antec P182 with a Corsair 620 PSU, I can get some of the wires running behind the case but even after that, there's still SATA cables for DVD and Hot Swap, and ribbon cable for Soundcard etc
Old 24th Jun 2008, 12:41   #8
wuyanxu
wuyanxu's Avatar
WOW, very nice job pistol_pete.
hum.... strange...... cannot access photobucket. was going to show you my cable tiding in p182.
SATA cables can also go around the back, and do you REALLY need the sound card? i dumped a molex cable to motherboard for supporting PCIe power, because found out it's stable even without it. hot-swap? for which component?
edit: photobucket is back up now.
see i hid all of my cable on the back
and to get around 8800GTX being too long, i had to put a smaller than 120mm fan inside the drive cage, instead of the usual clipping on.
as you can see: generally no wiring will obstruct the airflow.
__________________
Old 24th Jun 2008, 19:43   #9
Gryzor
What's a Dremel?
Gryzor has yet to learn the way of the Dremel
If it aint in the fan making a noise and the PC doesnt turn itself off its all WIN WIN!
Gryzor is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
