Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 27th Jun 2008, 18:40   #21
keef247
That'd Get Ruined
keef247's Avatar
keef247 has yet to learn the way of the Dremel
nioceee. 3.6@1.48=37-42c antec nine hundred for you mate 200mm top blower and 3 120mm's and a 120mm scythe silent 1600rpm with a 120mm eXtreme hs
keef247 is offline   Reply With Quote
Old 27th Jun 2008, 18:48   #22
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysis
Originally Posted by AndrewJ View Post
I run at 3.4ghz with 1.4v on a Abit Ip35 Pro, after 3hours Crysis highest temps reported is 60c. very happy since I am on stock intel air.
what program are you checking your temps with? you know that some can be off by 15 degrees right? you could be running at 75
chrisb2e9 is offline   Reply With Quote
Reply
Tags
overclock
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
