#1 |
Ex-Modder
getting windows to automate actions...
hey guys,
is there a way of getting windows xp to automate actions, and maybe at certain times? Like you can with Apple script? cheers guys
__________________
wc206 on Steam and bawnslippy1 on Origin. |
#2 |
/dev/null
You can write batch scripts and have them called at regular intervals. But from my experience, batch scripts are very limited in functionality.
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't |
#3 |
Ex-Modder
hmm...i was hoping there might be something that would just copy my mouse and keyboard inputs....i've never done scripting and wouldn't know where to start!
__________________
#4 |
____
control panel > scheduled tasks
it can run programmes, so may not be the 'actions' you're looking for.
__________________
Have you seen The SketchUp Components Collection's latest items?
Interested in a DXF Blueprints Collection? Discuss it here. |
#5 |
Ex-Modder
no, schedule tasks is far too basic, all it does is run a programme. my priority action is this:
pc turns on at a certain time (optional) pc runs outlook express exports all e-mails pc turns off at a certain time. (optional)
__________________
#6 |
The cheesecake is a lie
There's no way to turn a PC on from Windows.
It is possible to run OE. It is (propably) possible to export the email. It is possible to shut down again. So, basically, everything will work as long as you leave your PC on. Take a look at AutoIt. It might be the answer for you. |
#7 |
Ex-Modder
i've figured out how to back up the emails, i'm gonna use everyday auto back up, free app i found on the net. looks like it'll do the job. just gonna back up the dbx files simple as.
is there a way to auto turn off the pc automatically, that autoIT looks good, but like i said, i can't script!
__________________
#8 |
Supermodder
AutoIT looks like a very handy tool. Do not need one at the moment but will download and have a play
#9 |
ReliXmas time!
You could check the BIOS and look for the wakeup timer. My old mobo had one and i used my pc as an alarm clock with winamp playing full force at startup
#10 |
AutoIt is a really easy script language
eg. this will launch Outlook Express:Code:
Run("msimn.exe")
And you can shutdown Windows at any time by using the shutdown.exe tool included in Windows. The run box is very useful, you can execute single commands from it. You can get to it by opening the start menu and selecting the Run option, or by pressing the Windows key + R. Eg. this will shut down Windows in 60 seconds and it uses the shutdown.exe tool. Code:
shutdown -s -t 60 Code:
shutdown -a |
#11 | |
Minimodder
Use the Windows shutdown command Freeware utility - Amp WinOff. I'm sure there are many other ways as well
| Tags |
| windows |
| Thread Tools | |
