Thread Tools | View Mode |
#1 |
da ginger monkey!!!!
[Project] Modularis Evolution... updated alot!!! nearing completion!
Ok guys my long awaited project is finally here, but I must say I'm still not sure on the name so if anyone has any better suggestions please go ahead and reveal them.
This all started out as a design to try and really push my skills and the ideas behind a computer case and also as a way of promoting my shop. The design started off as quite a simple modular idea ![]() But then it quickly evolved into Modularis Evolution ![]() ![]() So as I have got my workshop all sorted out and ready to mod I grabbed one of my sheets of 2'x4' aluminium and marked it ready for cutting (please excuse the blur i didnt have my tripod to hand) ![]() I quickly got that cut up with my trusty jigsaw and moved onto the bending with my amazing 30" manual sheet metal brake. ![]() ![]() So thats one side done on to the next ![]() I then cut a piece for the top - this will be the removable section for access to the mobo tray. ![]() I then grabbed one of my spare motherboard trays and put it in for a very rough test fit - note it is not going to be that low down when it is mounted. ![]() ![]() So unfortunately that is all I had time for today but dont worry I will be doing some more to it on Monday. Plan for Monday is to get the window in the top section cut and maybe the front and back panels cut. Until next time Josh Last edited by x06jsp; 10th Oct 2008 at 13:32. |
#2 |
Blame it on the Boogie
looking mint there
how about Project OverFlow? It would nicely describe the watercooling flowing over into other modules
#3 |
Thats quite cool i think for now i will keep the name and put together the names suggested and do a poll.
And thanks |
#4 |
ITS OVER 8000!
Nice bending so far.
#5 |
Thanks mankz.
It comes from being very patient |
#6 |
It's a mod mod world
Good job and a quick start. Could you show a little more as to how you are getting the bends so precisely? I suppose you are using a break of some sort but I'm missing that somewhere.
__________________
_________________________ my karma ran over your dogma see Phase III at www.tccook.com |
#7 |
geeky modder
Josh is using a 30" bending brake
__________________
Project: Shiny Destiny :: Project: Tri-box Supported by DangerDen and MNPCTECH :: Project: Deadline
Cosmos S, Asus P6T Deluxe V2, i7 920, 6GB Crucial Balistix Tracers, 2x Samsung F1 1TB Twitter :: Kyle van der Merwe:: The Mod Brothers |
#8 |
i will post up a more detailed demo of what i go through for each bend when i get onto the next module
#9 |
Modder
wonderfull begining.
mod on!!!
| angelorus2000 |
| View Public Profile |
| Find More Posts by angelorus2000 |
#10 |
Minimodder
Are you staying with the black and green theme? I've always loved a combination of those two colours together
![]() Is that little green dot at the front of the large module the power switch? Are you going for a bulgin type switch or coming up with one of your own design? Which module will the power supply be housed in? I can't see any room for it in the main module unless it goes under the motherboard tray, as you said it would be mounted higher in the final version. Would it be possible to label what is going in each module? will be much easier for the rest of us onlookers to see where you are going with the design
#11 |
Thanks guys
Yes im going with green and black and there will be a twist to show later on in the mod... The green dot will be a vandal resistant switch like the bulgins The psu will be in the lower right hand side module. i will add a labeled diagram on my next update. Josh |
#12 |
Ultramodder
can't wait to see the outcome
![]() *Subscribed*
__________________
{Q6600}-{HD4850 512Mb}-{Hiper M 630W}-{Samsung F1 640Gb}-{Antec 300}-{4Gb Team Elite PC6400}-{ECS P35T-A}
{Nikon D80 w/ 18-55 and 50mm f/1.8}-{Lomo Smena 8m} {LandRover G4 Challenge}-{MonsterRoller No Animal} |
#13 |
thanks bigsharn
I will have another update this afternoon this is moving along quite quickly thankfully. Josh |
#14 |
Well I'm back for another update, Unfortunately i didn't get quite as much as i was hoping done today but nether the less i have an update anyway.
Firstly here is the top panel marked for cutting out the window. ![]() And after a short session on the scroll saw before filing we get this ![]() And after a bit of filing we are left with this ![]() But im not too sure on this i think it may be a bit small for this case and i also havent rounded off the corners so i think i will enlarge the hole and round off the corners aswell. And mounted to the rest of the case ![]() Now is the time to move on to the front and back panels so here you go front panel cut out ![]() Front and back panels cut out ![]() And then onto the back panel i/o cutout (sorry didnt get any pics of marking out etc etc But here it is in the vice being filed ![]() And unfortunately that's all for today more tomorrow. Hope you enjoy Josh |
#15 |
Ultramodder
Looking good looks nice and tidy mounted on the rest of the motherbard compartment:thumb
__________________
#16 |
Multimodder
looking great
__________________
Sorry for my bad English and typos... |
#17 |
Thanks guys
#18 |
Belgian beer modder
promising start.
I have been playing around with a similar idea...but not that many 'pods', just two or three. I'm interested how it'll turn out.
__________________
Der_Meister: 100% completed, again... project log here. |
#19 |
Thanks for the comment jokkos
#20 |
Budget mods
aint you the guy who ripped off a compay sponsoring you on the aqua pc threads???
| Tags |
scratch build ![]() |
| Thread Tools | |
| View Mode | |
