#1 |
Multimodder
Project: Plexius
Casemod Sponsered By:
![]() Hello Bittech Casemodders and readers! The name: Plexius Acryl names in Belgium plexi. Since the case is made out plexi,(acryl) I decided to give him the name Plexius.(acrylius) Here you have me again. (airpress from the small country Belgium) I don't know if you know me anymore, but I have made a mod called "GreenPoison" a few months ago. Also posted here on bit-tech. Today I'm back with a total new project called "Plexius". This casebuild will be construct just out plexi panels.(acryl panels) A few weeks ago, I was drawing the hole concept on PC. Drawed with Autocad 2008. After everything was drawed, I gave all the pieces off the case a material. So if they will be rendered with Autocad , it will look like plexiglass. Here you have the case rendered. ![]() front ![]() back Dimensions are: Hight: 385mm width: 360mm Depth: 360mm Such as your probably sees is that the case (bolted) will be constructed entirely from plexiglas. To glue the acyrl panels together, I have bought glue for acyrlic made by Pattex. The glue has a tensil strength of 170kg/cm ². The glue I'm talking about is epoxy. The fans are not 120mm' s but 92mm. Something about the harddisks. The harddisk will be placed inside a slit. Don't know if its the correct word. The next drawing will make it clear. ![]() Airpress. PS: Later this evening I will post the first progress! Last edited by airpress; 22nd Jul 2008 at 18:34. |
#2 |
Multimodder
This afternoon I maked the front panel off the case.
I did the most saw and drill work. ![]() all the pieces that must be sawed out ![]() i use the jigsaw as first and then a file ![]() with the file against the line ![]() bottom saving sawed out with the file, not yet filled ![]() ![]() bell drill for sawing out a hole for 92mm fans ![]() holes drilled ![]() method for the edges first sandpaper 180, 320, 600 en after that with the gas burner ![]() ![]() fan hole sanded also the bottem saving (edges) ![]() result front panel Keep in mind, the edges of this panel are sanded only with 150! This was it for today. I should say, stay tuned! |
#3 |
Or u can call me Ian
great start airpress!! cant wait to see the finished product!!
| [xXx] ãÇè_ƒr€áK |
| View Public Profile |
| Find More Posts by [xXx] ãÇè_ƒr€áK |
#4 |
Multimodder
Any comments on the design?
#5 |
6 decades of fun
I like it a lot. Thecut outs on the front and side bottom are nice. Not the flat edge sit on a desk look. They look more like a finished furniture or manufactured product.
Subscribed John
__________________
Life is it's own answer. Live life for itself. Accept it and enjoy it day by day. Live as well as possible. Expect no more. Destroy nothing, humble nothing, look for fault in nothing. Leave unsullied and untouched all that is beautiful. Hold that which lives in all reverence. |
| jhanlon303 |
| Find More Posts by jhanlon303 |
#6 |
Multimodder
Today i've worked on the sidepanels en back panel.
![]() in the middle comes the powersupply, on the left en right side a 80mm fan will fit there ![]() i have still to cut the i/o shield hole en hole for expansions slots I've searched and I found this, what is very helpfull to know the dimensions. ![]() ![]() here you see the left and right panel ![]() on the front panel, i need to drill two holes for a 92mm fan one for intake cool air for cpu cooler and the other to intake cool air for videocards Airpress |
#7 |
Multimodder
This afternoon i've sawed 1cm strokes.
On this comes an acrylpanel for the harddisk, motherboard, power supply,... ![]() 1 cm strokes, also the edges are sanded and "burned" (gas burner) ![]() I have shortened it in pieces on 3cm, edges must still be sanded an "burned". btw: i've made more pieces than you see on the pic ![]() Sanded the two arcs from the sidepanels. I've sanded and "burned" them because the sidepanels are finished. ![]() After "burning". Airpress |
#8 |
Vice Benelux Champion Casemodding
The edges look nice 'n smooth, tried a gasburner myself; ended up bending the acrylic
![]() Keep it up!
__________________
»My website: SteveSalens.com V2.0 Project: Xionized Powered by IT-service.be -next project comin' up!- |
#9 |
I *am* a Dremel
Looking nice but I prefer a dremmel and polish to burning edges.
![]() Anyway, nice start.
__________________
4 Men went to mow, Went to mow a meadow, 4 Men went to mow, Went to mow a meadow, ![]() ![]()
#10 |
Multimodder
This afternoon, I made a wood construction for glueing the case together.
You will see what I mean in the pictures. ![]() Offcourse the corners must be glued perfectely in 90 degrees. Well it was no problem... ![]() ![]() Keep in mind; i'm not glueing yet. I've just made it. Last edited by airpress; 29th Jul 2008 at 22:20. |
#11 |
Multimodder
Hello everyone, I'm back here!
This morning my homemade woodenframe has proved its service. I've glued the first corner off the case. Frontpanel and lefsidepanel glued together. ![]() the used glue, its very strong ![]() here you see the 2 acryl panels laying down in the perfect 90° wooden mal (glue is drying) ![]() first floor sawed out + hole for sucking(right word?) fresh air in for powersupply ![]() panel in full glory without tape ![]() Around 16h these afternoon I have taken the angle from the wooden mal and taked a picture of it. ![]() The adhesive on that connection only is incredibly strong! ![]() other sight ![]() Then glued the first floor onto/into the corner. Airpress |
#12 |
Will-Mod-for-Food
Excellent. As was already said, the raised design with the curved feet is a nice, practical way for airflow and style. Good design all around as well. I'm loving the acrylic tint you chose.
__________________
e8400 3.0ghz || EVGA 260gtx 896mb || 4gb OCZ Reaper 1066 DDR2 || ASUS P5K-VM || Dual 640gb HDD
Current Scratch Build: Metal Gear Mk IV Case |
#13 | |
Multimodder
![]() I have a question to you people. Before I will construct the hdd racs(stands), I have a question about it. Here you see a pic what i'm will be making. ![]() How high must it be? Where the harddisk will sit in? With other words, what will be the ideal hight? Thanx in advance, Airpress. |
#14 |
Multimodder
Initially, I thought only 3/8 to 1/2 and inch. But I'm worried that you're going to need to dampen the vibration of the hdd's, with only one side affixed. So the higher the better. Were it me, I'd shoot for between 1/3 and 1/2 the width of the drive.
__________________
Careful. We don't want to learn anything from this. |
#15 |
Case Modder
This is looking good. Great work.
| wastedtime |
| Find More Posts by wastedtime |
#16 |
Multimodder
Thanx for your help Snafu-X-. I'll keep it in mind!
Now I was searching in a online webshop. I encountered this. ![]() When I'll buy some materials needed for this casebuild I will order two of them. In case if the home made stands don't work. I mean with don't work, if there to much noise(vibrations) or something. |
#17 |
Multimodder
I'm back!
Always before start working, a good cup of coffee and a biscuit. ![]() After a delicious coffee and the biscuit, I sawed out the hole for the i/o shield. Also drawed a hole for the expansion slots. When the hole for the expansion slots and i/o shield a sawed out, it's not finished yet. I have to make another (little) construction where the motherboard comes 15 away from the edge. If you don't know what I mean, see the second picture below. Er moet dan nog iets gebeuren. Dit is voor later. ![]() ![]() I need to make it what is indicated in red. I glued the other sidepanel to the existed construction. The part which is glued, can recognise you by the red ball placed in paint. :P The panels are greasy (fat fingers) such as you can see. ![]() Other sight. ![]() Airpress |
#18 |
I knew it. This is WOW and Plexi summer to
every one is using Plexi, Buddy I really like the idea, The intakes holes look good, The front look hot can't wait to see more work from you. You are doing good job so far, well done
__________________
GigaByte Triton 180|GigaByte EP45-UD3LR|Intel Q9450|Transcend 4GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|3TB WD Green The King Of CK Appreciation Society Group
| ComputerKing |
| Find More Posts by ComputerKing |
#19 |
Multimodder
The right sidepanel was glued without problems yesterday.
Here are some pic with the case taken out the wooden stand. ![]() ![]() Today I've sawed a panel for the second floor. Here will sit the motherboard on. This panel will be removable. Must there be a harddisk failure, I can take out the panel and place another harddisk in. ![]() ![]() ![]() This was it for today. Tomorrow more. Ps: tomorrow I will receive my order (parcel) with fans ![]() Airpress |
#20 |
THis start to look good
Keep it going. I like the idea that you Guy them not add screws, Good luck
__________________
| ComputerKing |
| Tags |
scratch build ![]() |
| Thread Tools | |
| View Mode | |
