Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
Gigabyte G-Power 2 Pro Cooler Review
http://www.bit-tech.net/hardware/200...ooler-review/1
Gigabtye re-enters the after market CPU cooler race with the G-Power 2 Pro heatsink. Promising silent operation combined with high thermal performance, can the G-Power deliver more than a bucket load of chrome? Read on to find out!
#2 |
Made in Canada
Hmm,
Definitely an interesting design, it's a love-or-hate at first sight kind of design. Personally I sorta like it, though maybe a deep jet-black (or carbon fiber?) instead of the bling-bling might have made it look more sexy. It's good to see that Gigabyte is at least making an effort to try and develop a product that provides some level of performance and attempts to make up for the failures of their previous cooler. I dunno, I'm still a Noctua fan (no pun intended) though :P Interesting read, nevertheless.
__________________
[[Asus P6T | Intel Core i7 920 @ 2.67Ghz cooled by Noctua UH-P12 Push-Pull Config | 6GB DDR3-1600 Patriot Viper Xtreme XMP C8 | nVidia GeForce 280 GTX 1GB | Corsair HX620 620 Watt PSU | Antec P182 Case]] |
#3 |
Supermodder? Well tnx :)
That's a nice cooler. Is it possible to rotate the heatsink 90 degrees? That, with a little modding, would make it perfect for my next casemod
__________________
Find out what's in my avatar: Phase 2 Casemodding My casemod in progress: Cubeleon |
#4 |
Heathen
Is it me or do all these heatpipe heatsinks look like they are designed to work best on a horizontal mounted motherboard. I always thought that the way heatpipes worked was the heat rose along their length then the fluid condensed and ran back down under gravity, doesn't seem the most efficient way if they have to be mounted horizontally due to the motherboard being vertical in 99% of PCs now.
On topic though, I agree about the black or carbon shroud idea being a better one, the chrome looks a little cheap.
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever. |
| Almightyrastus |
| View Public Profile |
| Find More Posts by Almightyrastus |
#5 |
quad fuelled, GTX200 powered
wow, better than TRUE? i bet with a higher CFM fan, or using push-pull config, TRUE is still better.
how is the RAM going to the airflow though, with the CPU heatsink fan sucking air from the vicinity way higher than any RAM will every be. but i really like its design, the way it will also cool PWM heatsink. shame TRUE doesn't bend like that. just a thought, why didn't you guys use Abit iP35 Pro as testing board? Abit have sensors on PWM, which can easily tell whether if the CPU heatsink is pushing air flow over PWM to cool them. cos IMHO, that's one of the jobs on CPU heatsink, and i think TRUE isn't doing a good job
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#6 | |
__________________
#7 |
Whooolapoook
Yep again...it's irrelevant which way you mount heatpipes these days because they use wicking. The first heatpipes used on motherboards were however very fussy, upside down mounting resulted in a number of dead chipsets.
__________________
0ptimizm :PC under review
#8 |
Hypermodder
Looks like a decent HS - chrome + white background = blargh tho
#9 | |
Vapourmodder
__________________
Current setup: Hiper Osiris | Core i7 920 (Cooled by Noctua NH-U12P) | Foxconn Renaissance | 2x GTX280 | Cooler Master UCP | Corsair Dominator 3GB (soon to be 9GB) | Creative X-Fi Titanium | Vista Home Premium x64 | OS Drive: WD Velociraptor 300GB. Storage: 1x 160GB, 1x 250GB, 1x 300GB, 1x500GB (incremental additions over the years! All Maxtor) | Monitor: Dell 2709W |
| ChaosDefinesOrder |
| Find More Posts by ChaosDefinesOrder |
#10 | ||
Multimodder
| Bionic-Blob |
| Find More Posts by Bionic-Blob |
#11 | |
Licenced idiot.
If they were solid bars, they might be called heatBARS instead of piped dontchathink? So many wild guesses, yet so few of them get it right...
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#12 |
Ex nihilo nihil fit
Did I miss something or isn't the weight of the cooler listed anywhere? The only thing mentioned regarding the weight seems to be "heavy".
__________________
''Trying is the first step towards failure.'' - Homer Simpson |
#13 | |
Benchmarketeer
bit-tech Staff
#14 | |
Benchmarketeer
bit-tech Staff
#15 | ||
Ex nihilo nihil fit
__________________
#16 |
inch-perfect
FINALLY a company has understood that flaying the heatsink fins instead of stacking higher densities of fins is more efficient (as far as weight is concerned). That way, air is pressed against the fins to resist effects of laminar flow that flat-stacked heatsinks suffer. I'd like to see this principle continued in an evolution of this heatink with flayed fins in front of and behind the fan. It's smart on them that the bottom-most fins flow air over the base.
The ridiculous-looking fan shroud would look better in a smoked aluminum finish (aka black chrome) IMHO.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
| Thread Tools | |
