Thread Tools |
#1 |
Player Character
bit-tech Staff
Nvidia SLI will work on some X58 motherboards
http://www.bit-tech.net/news/2008/07...motherboards/1
Nvidia won't have it's own SLI chipset when Nehalem launches, but there will be some X58 boards that support SLI.
__________________
#2 |
Multimodder
Not sure if I even want these chips - according to reviews the chips on the ST are hot and the sole reason for the noisy SB cooler.
'Although the NF200 chipset simply bolts onto the PCI-Express lanes, given the political situation between the two companies it will no doubt again (in respect to Skulltrail) be like forcing two same poled magnets at each other. In fact, those manufacturers using the NF200 chipset won't get any Intel support what-so-ever - it won't gurantee X58 works with the NF200 and it won't help check or debug the circuitry or software either. Not unsurprising, but hardly the best situation from a consumer perspective.' Even less attractive. I'd prefer having no trace of Nvidia's dreadful chipsets at all on my board. Stick to graphics cards and keep your icky green chips off my motherboard!
#3 |
Ultramodder
SLI=fail and crossfire= fail. Both need extreme power, pockets of money for 2 to 4 cards, needs a expensive crossfire/sli motherboard and all that for 10 to 30fps more in a game. And the best yet, all that dual tri and quad videocard power is surpased within 2 years by one single videocart solution that probably has better stuff on it anyway. Not even mentioning the cost of power out of the wall and 90% idle time and minimalistic sli/crossfire support.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#4 |
Supermodder
SLI is not an option to go for at the moment, I agree, but its not just the hardware and cost, we need better programmers and better compatibility.
| ParaHelix.org |
| View Public Profile |
| Find More Posts by ParaHelix.org |
#5 | |
Supermodder
As for your second observation... You will never buy anything if your always waiting for the next best thing to come out. There will always be something more powerful on its way. That's why its a niche market. If you don't want to spend it you don't have to. One single card will play everything you need to. But if you want it to play better, two will give you that little bit of an edge over the other players. As new games come out you will have to pay to play. Its a hobby, they aren't usually cheep. I work on cars, play around with music, game... none of these are cheep. But if I enjoy doing them, I'm not gonna freak out when I know it's expensive. |
#6 |
Supermodder
Oops, Forgot to add my own commentary to the article.
It's not looking real good for nvidia right now. With the bad mobile chips, their bleeding edge card not nearly outperforming the competition as much as it should, and now they don't even have a chip set to support the latest from Intel... there might be some cheep stocks for nvidia right now. |
#7 |
International Man of Awesome
Agreed, SLI is a waste of money atm.
If a single GPU can run pretty much all games, where's the need for any more? Especially if you've got a single card which can (adequately) run Crysis.
__________________
Q6600 @ 2.40GHz w/G0|Gigabyte GA-G33M-DS2R|4GB OCZ Gold PC-6400 800MHz|Powercolor Radeon HD4850|Samsung Spinpoint F1 1TB|Scythe Ninja Mini|LG Blu-ray/HD DVD/DVD-RW Combo Drive|Corsair TX650W|Antec NSK2480
Pioneer VSX-417|2x Gale 3010|2x Yamaha NSP110| MS304W Centre | MS308 Subwoofer |
| Timmy_the_tortoise |
| Find More Posts by Timmy_the_tortoise |
#8 |
quad fuelled, GTX200 powered
any word on the cost of x58 platforms?
Intel 2.66Ghz Nehalem is said to be only going to cost $299, so at least the CPU is going to be affordable. but is Intel going to charge us in the motherboard area?
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#9 |
RPG Loving Freak
I tested out SLI with 2 GeForce 7800 GTX's back when they were the best. I got a nice 3D mark score, but it did not make a big difference in games. I'm sticking to a single card for now and I normally upgrade once a year.
I'm still happy with my GeForce 8800 GTS 512, but when it comes to upgrade time I am thinking of getting an ATI card again. Nvidia mobos used to be really good, but I have not been happy with the 680 chipset, and I don't think I'll bother with another nvida board again.
__________________
I am the Black Mage. I cast the spells that makes the peoples fall down! |
| BlackMage23 |
| Find More Posts by BlackMage23 |
#10 |
Minimodder
SLI has been a waste of money since it came out. That's never going to change. The Tech, as it stands, does not yield a great enough improvement in performance so that that next gen, single card solution is performing less than doubling up on an older card. Getting a new one is probably also cheaper, and feature rich. I won't say cooler and quieter, because Graphics vendors don't seem to care for that. But yeah, I'd rather the focus be on cooler running chips than making them a percent or two faster for nearly double the power consumption.
#11 |
Spoon? What spoon?
actually, SLI combined with CUDA is oe of the best things that has happened to computers from an engineering standpoint.
the funny part of all the negativity surrounding SLI for gaming is that it was never meant for that in the first place. the original intent of SLI when it first appeared was to give those workstations lacking the necessary graphical horsepower for their applications with even a current generation card to be upgraded to the specs their function required, but also with the intent of bringing the power of the GPU as a parallel computation engine to bear on the number crunching side of things. we've finally reached the point where SLI is starting to show what it can really do for the professional community. |
| Bluephoenix |
| Find More Posts by Bluephoenix |
#12 |
Lethargic
Hm. The lack of aid from Intel for the manufacturers that choose to do this is disturbing, although not unexpected. It basically sounds like nVidia sent them all a quiet e-mail saying, "Y'know, you can use our bridge chips that are used on Skulltrail with X58 and have SLI compatibility as a selling point! (nudge nudge, wink wink)"
I keep meaning to try SLI or CrossFire... but each time I finally manage to get my act sorted, something crops up that puts me off. |
#13 | |
Like the sudden realisation that paying twice the price for 1.1 times the performance is a massive rip off?
__________________
#14 |
Hypermodder
not fussed, will be happy with plain intel chipset and ati's next dual gpu card
#15 |
Supermodder
and why havent I ever had the option to buy an AMD based bored that can do both?..................
__________________
(Phenom II 940)(Foxcon A7DA)(8gb OCZ DDR2 800 )(8800gt aka hair dryer)(Big yellow case, CPU, GPU)(Enermax Liberty 500w)(lite-on DVD-RW w/LightScribe)(Seagate 300gb sata)(Seagate 320gb x2)(WD 200gb)(Dell 3007WFP 30"LCD, 19" Samsung, Acer 1280x720 projector) |
#16 | |
Controlled by Eyebrow Powers™
I also don't understand why Nehalem doesn't allow motherboard design simplification as AMD CPUs do (ie, usage of only one chipset, or 2 very small chipsets). |
#17 | |
Can't mod my way out of a paper bag
My machine has a pair of 7800GTs in it and does just fine. I don't think a single 7800GT would still be working for me nearly as well two and a half years later.
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade. |
#18 |
Legomaniac
I think multiple graphics cards in a single case is good if you do a lot of high end graphics work, 3D-rendering and such. I'm not convinced of the cost v's benefit for games. Nor do I think multiple graphics cards will ever become mainstream, imho.
__________________
HP Pavilion Elite m9040n PC - Vista Home Premium
Intel Core 2 Quad Processor Q6600 @ 2.40ghz - 3G of RAM - Dual 320G HDs Upgrades/Add-ons: 22" Widescreen LCD, 700W RocketFish PSU, BFG GeForce 9800 GT 160G Ext USB HD, Logitech X-540 5.1 Surround Sound Speakers |
| LordPyrinc |
| Find More Posts by LordPyrinc |
#19 |
Multimodder
So SLi and Crossfire was never meant for gaming? haha.. yeah right. Just check the marketing then. Saying in retrospect that it is best suited for CUDA/GPGPU stuff just tells me that this is one big hack from the outset.
I think I'll go AMD this time around when it comes to graphics. I'm only interested in single cards because that just works (TM) or maybe one card with two graphics chips on it.
__________________
- I'm the troll who bumps page 2 topics - |
#20 |
Multimodder
| Thread Tools | |
