Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
BFG ES Series 800W PSU
http://www.bit-tech.net/hardware/200...ies-800w-psu/1
BFG is more a name associated with graphics cards, rather than power supplies, however the company has teamed up with industry expert, Johnny Guru, to create something that really might surprise you.
#2 |
Pie Eater
PSU's are such a pain to shop for, as you have to read more reviews than for other hardware as you need to find and weigh each their technical prowess, saying that the bfg unit doesnt look cool for those with windows in their pc's, however...
I wouldnt buy this psu but atleast it features in my mind as something I could by, rather than dismissing bfg psu's altogether as i would have with their previous models so well done to bfg for coming along so far in r and d. Nice article bindi, peace
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
#3 |
Banned
99% of the psu reviews on the net are plain useless. A good psu review is one that involves testing the unit on an ATE (SunMoon or Chroma) because you can see exactly how the unit performs and if it's up to spec. If a PSU can survive the torture test of a SunMoon or a Chroma at 100% and maintain the characteristics well within the ATX standard then the manufacturere did a good job on it. It would be better to looka deeper into this unit to find clues to its OEM.
#4 |
Multimodder
The latest issue of Custom PC issue 59 reviewed a series of PSU's and they were all tested on a Chroma 664
| deltaworld |
| View Public Profile |
| Find More Posts by deltaworld |
#5 | |
Richard Swinburne
bit-tech Staff
#6 |
What's a Dremel?
I'm curious that if you have a power supply that boasts such incredible efficiency numbers at low loads, even as low as 10%, and great efficiency at standby due to the completely separate standby PSU within the unit, why you would still only test the unit at 50% and up? That's rather a kin to Motor Trend checking out a Ferrari, only driving it through the city at no more than 40MPH and then saying "it's ok."
On another note: I can understand why one would feel "uncomfortable" with the unorthodox layout of the components in the ES-800. Sometimes it's hard to break away from a norm in PSU layout that's been used ever since the ATX form factor was put forth on us almost a decade ago, but the complaint that it's not the best suit for airflow is somewhat unwarranted. In fact, the reason behind the layout is because it provides better air-flow to components that need it most. It actually uses the same principle of cooling than keeps PC Power & Cooling from migrating away from 80MM fans (a principle that they adhere to for very good reason actually). Instead of blowing down on components and essentially only cooling the tops of caps, sinks, etc. you're pushing air down and across the components. By locating the +5VSB PSU PCB upside-down towards the rear, you're actually having it serve the purpose of the commonly used fan baffle by forcing air to concentrate towards the front of the unit and then move between it and the main PCB. FYI: "Globe Fan" (aka Zaward that's their retail brand) is the same company that makes Enermax's fans. |
#7 |
What's a Dremel?
"We do get the fact that the dangling connectors mean that you don't have to wire down a whole new cable, so SLI or high end graphics cards can be supplied by a single cable - that's a good idea in principle, but without being detachable it's messy and additionally stresses the three yellow 12V wires running down the single cable.
The 12V EPS connector is an even worse decision - you'll only ever need an 8-pin or 4-pin on a normal consumer motherboard, so you'll always be left with one dangling about. However if you did want to use the ES-800 for a server or workstation board which requires both connectors, you can't simply because there's not enough cable between them to reach." The way I did the cables was a conscious decision. Alternatives: Modular? Problem: Get sued. A separate cable? Problem: Now there's another cable to hide away. So the compromise was to increase the wire gage and add the second connector +150MM from the first. If you don't use the connector, we actually supplied zip ties (in addition to the Velcro straps) so you can fold back and zip up the extra wire and connector and it looks almost (just almost) as clean as if the second connector wasn't there at all. As for being able to use both 4-pin ATX12V and 8-pin EPS12V connectors on an EPS12V 2.9 and up motherboard, I haven't seen many boards that have the two CPU power connectors too far apart to require more than 150MM between the two. Perhaps you have and it's too bad I did not take those boards into consideration. On a side note: The dual proc Skulltrail has two 8-pin connectors adjacent to each other and using the 4-pin in the second 8-pin instead of a second 8-pin connector works great. Last edited by jonnyGURU; 16th Jul 2008 at 16:14. Reason: misspelled compromise |
#8 | |||
Richard Swinburne
bit-tech Staff
Firstly, Welcome Back, Jonny!
![]() Quote:
![]() OK, so PCPC don't move away from 80mm fans because having a straight through flow provides more precise cooling like you explain. It's also less stressful on the fans because it doesn't put weight in the axel like bottom mounted 120mm do. They accept this is nosier, but would rather quality (like never doing a modular design) over a customer's whims. The thing is they force air front to back and pass it straight out, but a top down passes it into the fins and down towards the PCB. However I did acknowledge that the unit did not feel that hot even under extended load - it wasn't a criticism it was an observation. I do understand what you've done with the capacitors but they're also very flexible now compared to every other PSU I've seen. Why do you need 105C caps when you're passing more air over them, and a top down cooled cap is 85C? Quote:
The 6-pin PCI-Express cables, fair enough, but an 800W unit exists in workstation territory, so not having a separate EPS 12V to use means I can't use this on my Asus Z7S WS Xeon board because one plug is at the top and one down the bottom. Niche - perhaps, but it's meant to be a leading edge product. You can't win every heart and from a modding site if you zip tied it back it would still look quite ugly I'm afraid, but add it on a modular plug and you have the problem of there being a potential voltage drop. It's a very difficult call and we personally don't like dangly cables. If you buy non-modular, you have tons of cables - that's the deal. |
#9 |
Supermodder
Personally I have ALWAYS used modular Tagan PSU's and they have always worked perfectly, the latest one which I purchased in the UK is the 900W Tagan TG900-BZ "Quad Rail" Gold Plated PipeRock Modular Cable Management, +80% Efficiency. Perfect for every need of my very expensive gaming rig, and modular so no unnecessary wires, those wires which are there can but neatly tucked down the back of the motherboard tray so no big deal.
| ParaHelix.org |
| Find More Posts by ParaHelix.org |
#10 |
What's a Dremel?
I'm on my 3rd BFG 1000 watt PSU. First one exploded, second one just died for no apparent reason. Luckily their RMA department is fast/nice.
#11 | |||||||
What's a Dremel?
I really do respect you.. you know that, right? I think there's some rumor floating around that we hate each other or something.
I'm just a sucker for good banter.Quote:
![]() I'm using my gaming rig right now... but I'm only pulling 150W from the wall. It's easy to tax an 800W when I'm running a pair of GTX-280's on a Quad FX board, but if I'm only surfing the net, I'm well below even 20% load. Once we start seeing Hybrid Power on a number of boards (this is where the board actually shuts off all power to the PCIe card and relies completely on an integrated GPU for day to day tasks, for those who don't know) then power consumption while surfing the web, doing a spreadsheet, etc. is even less. So if I had a gaming PC that was only used for gaming, sure.. the only time I'd be at a low load is when I'm at the desktop ready to click on the COD4 icon. But even if that were the case, when I turn the PC off I'm still in standby and that's consuming power too. Quote:
![]() Quote:
Thanks for the heads up. Quote:
#12 |
Richard Swinburne
bit-tech Staff
We really appreciate the feedback, Jonny! |
#13 |
Ultramodder
yeah! me like the chit chat between 'procucer' and 'reviewer'
![]() One question: What about the picture of the exposed coper wire bundle almost touching the heatsink. Isn't this dangerous?
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#14 | ||
What's a Dremel?
#15 |
Veteran Modder
I'll stick with Antec, OCZ, etc
__________________
R2-M5 PC - Foxconn P45A-S, Intel Q9400, 8GB DDR2-800, Radeon HD 3870 X2 1GB
#16 |
inch-perfect
As tested, it seems okay. I can't take your word for it, but, through its tests, it's fared well. I'm also just in the market for a replacement power supply for my dead PC.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#17 | ||
Richard Swinburne
bit-tech Staff
You use a slightly different transformer then. EDIT: Tell a lie - they've always been sleeved before.Quote:
#18 |
What's a Dremel?
The transformer is different, sure. The whole PSU is different if you think about it.
There are no other PSU's on the market made the way this one was made. That's why I feel comparing it to cheaper, conventional units is unfair. But that's water under the bridge as far as I'm concerned.Yes, they are typically sleeved. If you had the chance to pull the PCB though, you would see where it says GND right where that cable solders down with the heatsink. I don't blame you for not taking it apart though. Only about 50% of the time when I do that do they work when I put them back together. Even my buddy Jeremy (Oklahoma Wolf) only gets about 75% working again. We have one ES-800 that was disassembled/reassembled where all the parts test good individually, it's assembled correctly, but the darn thing just doesn't turn on anymore.
| Thread Tools | |
