Thread Tools |
#1 |
Player Character
bit-tech Staff
IDC: SSD performance gap 'small'
http://www.bit-tech.net/news/2008/07...ce-gap-small/1
Research house IDC has published results of a test demonstrating that the performance differential between SSDs and traditional drives is a lot smaller than previously thought.
__________________
#2 |
Supermodder
If the SSD's could match the performance of the faster (less energy efficient?) mechanical drives would we not be seeing SSD drives for desktops already?
__________________
If it isn’t broken, fix it. If it is broken, mod it till it looks like it's meant to be broken. |
| Dr. Strangelove |
| View Public Profile |
| Find More Posts by Dr. Strangelove |
#3 |
WIIGII!
The 2.5" SATA SSDs work fine in a desktop - but are much more expensive per gigabyte. If you're asking why there aren't any 3.5" SATA SSDs, it's because it's a relatively small market currently (the main advantage for SSDs, shock resistance, doesn't apply to desktop computing) and because there's no need to make a bigger unit that will only fit in a desktop when you can make a smaller unit that fits in both laptops and desktops.
#4 | |
Human programmer.. heh
SSD's are still as-good-as-theoretical while the price per gigabyte gap is so immense....
__________________
- Subverting reality since 1999 |
#5 |
Minimodder
One reason would be none of the current OS has optimization for SSD.
SSD has a future for much greater speed. Intel has said their SSD is going to be 200+ MB/s ... although it still hasn't appeared yet. |
#6 | |
quad fuelled, GTX200 powered
putting Vista on Raptor greatly increases Windows smoothness, so putting on a high performance SSD should increase it even more. the "small gap" is just saying in comparison to high speed HDD, it's not a large improvement. after-all, current high speed HDD (veloci-Raptor) is already very fast
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#7 |
WIIGII!
In no sense of the word is Windows 'optimised' for anything, much less SSDs. By default, Windows writes a large quantity of temporary files to the boot volume - along with a pagefile containing data swapped out of RAM. This constant read/write cycle impacts on the SSD due to the limited number of writes available to Flash memory. Basically, running an unmodified OS on an SSD will result in an expensive paperweight in a short length of time.
Now, you can turn the pagefile off and reduce the number of temporary files created (or move both to a mechanical volume), but that's something you have to do. Likewise, you can do the same in Linux and, I assume, MacOS. That doesn't make either of those 'optimised' for SSD use either - unless someone has already done so and released a special version, such as the SSD-optimised Eeebuntu Ubuntu variant designed for the Asus Eee PC. |
#8 |
Multimodder
All speed and lifecycle issues aside, has anyone ever tried to recover data from a damaged SSD?
If a controller chip burns out, can you still recover your data? Is there such a thing as a block-by-block clone of the SSD? How do software tools such as Data Rescue II cope with SSDs? |
| chicorasia |
| Find More Posts by chicorasia |
#9 |
Modder
The manufacturers specify 10s of years if you write the entire contents of the SSD each day, (ie if you have a 128GB device and write 128GB of data to it each day it will last 10+ years). The problem of flash wearing out is almost a non issue these days.
The wear levelling algorithms will ensure that individual sectors do not get prematurely destroyed by pagefiles etc. |
| desertstalker |
| Find More Posts by desertstalker |
| Thread Tools | |
