Thread Tools | View Mode |
#1 |
Multimodder
Project: C&C GDI War Factory (*New Video*)+ Ion Cannon (August MOTM)
This is my first from scratch case mod and with the encouragement of the hubby, I decided to post a worklog. This is my attempt to recreate and bring to life the GDI War Factory from the Command and Conquer 3 game series.
I have some screen shots for me to analyze and stare at all day…. Not sure how this will all come together. Posts should come pretty quickly, I want to be done by August. ![]() I had some leftover cardboard and thought I would do a test run of what it would look like. It is going to be bigger then I thought. ![]() Okay… I have to admit, this is harder then it looks…who knew a straight line could be so difficult. I was transferring some measurements to plexi and ooooops… measure twice, cut once right guys… ![]() LOL I couldn’t see what I was cutting, so a piece of paper under the plexi made it easier to see. I had to readjust the saw several time in order to get the small openings on the top. ![]() J Last edited by milotic858; 3rd Nov 2008 at 16:38. |
| milotic858 |
| View Public Profile |
| Find More Posts by milotic858 |
#2 |
IRONMODS
Awesome!! I am a big fan of C&C series. I can't wait to see you bring this thing to life.
- Ton |
#3 | |
I am, therefore I mod.
Cool build! Are you just doing the trapezoidal building, or are you going to include the hexagon cannisters and overhead crane thing too?
__________________
www.bods-mods.com Quote:
#4 | |
Still Wrenching
__________________
Gigabyte P35-DS3L | Intel E2220 @ 3.0GHz | AC Freezer 7 Pro | eVGA 8800GT 512MB | 2GB Crucial Ballistix DDR2-800 | 1 x Seagate 250GB SATA | 1 x WD Raptor 74GB SATA | X-Fi Extreme Gamer | Silverstone Strider 600 Modular | Modded Antec Nine Hundred
#5 | |
Multimodder
Check back soon to see how I totally messed up :PJ |
| milotic858 |
#6 |
Multimodder
| milotic858 |
#7 |
What's a Dremel?
Great start. Can't wait to see more
#8 |
Multimodder
| milotic858 |
#9 |
Multimodder
A good idea gone horrible wrong
![]() Okay…from the screen shot you can see there are crates on the side of the factory. Each time you make a vehicle it takes a crate and drops it in. Then poof out comes a tank or whatever you wanted… I made a template for the shape of the crate, and then glued it to the end. Following the lines on the template, I traced it all the way down so that I could cut each side. ![]() ![]() I even tried to turn the base of the scroll saw in order to try and get an angled cut. ![]() The final hideous product… yes I know they look terrible, but it is all part of the process. Don’t think there is any way to save these. ![]() ![]()
| milotic858 |
#10 | |
Well, I think your cuts were pretty accurate, it's your template that is off. What you have is not a true hexagon, it's stretched in some way. Unfortunately, I forget my geometry and how to make a perfect hexagon. Something about having 120° angles all the way around and the centerlines have to be equal lengths, and go from point to point. But I would just save yourself the trouble and grab the shape off the internet and size it to your needs.
__________________
#11 |
Multimodder
Thanks Boddaker, I think your right. So, I went online and found a pattern for a hexagonal prism that will work. I won’t be able to cut them from wood, but at least I have a pattern that I can work with.
Now the kids have some fun wood shapes to play with .
| milotic858 |
#12 |
Multimodder
:O cant wait to see this one... any electronics?
@boddaker: you still modding mate? |
#13 |
Multimodder
| milotic858 |
#14 |
Multimodder
you can probably get a base at the bottom of the building, sorta raise it higher and as a mobo tray then psu goes into the back of the.. uh.. garage or where the tanks come out in the game.
#15 |
Multimodder
The power supply that I was going to use was too big. So, I think your idea of raising it higher is right on. I will try to raise it higher and make it a two level structure. That way I can place a small shuttle power supply under the motherboard. I still need to look for the exact one that will fit my specifications.
| milotic858 |
#16 |
Multimodder
Scraped the idea of making crates from wood.
I am making crates from paper. Used a basic hexagonal prism pattern and added graphic to resemble the crates. This works out so much better. Special thanks to TiTON from IRONMODS.com! He helped me create the pattern on the crates. If you have seen his mods you would agree with me that he has a great talent for realism. http://www.ironmods.com/ I like this much better. Just had to print, cut, and glue together. ![]() ![]() They stack really nice. I will make ten total. ![]() ![]() J |
| milotic858 |
#17 |
The meaning of life is to MOD
Nice finger nail varnish.
oh what this is a PC modding site nice modding the green ones look cool pretty cool design for a mod.
__________________
Hope no one see's me modding this ![]() |
| icutebluezone |
| Find More Posts by icutebluezone |
#18 |
What's a Dremel?
hey, cool mod-idea and start, I love command and conquer
![]() good luck with this one |
#19 | ||
Multimodder
The green one does look better.Quote:
| milotic858 |
#20 |
Modder
WOW, You're a girl?!
I'm sorry it's just rare to me to find a girl (or woman) into gaming, let alone, modding. Well, you do your sex proud by knowing your place in the gaming world...to show that even a woman can show a guy up....lol, it's really refreshing to see that this craft is practicd by many from all walks of life. If there is ever a time that a guy tries to cut you short, not respect you because your ability as a woman, always remember that is how much power you have over them, they feel threatened and to make it worse on them...by a girl who knows exactly what she's doing enough to stir them out of their comfort zone. Nice project build.
| praetor coda |
| Find More Posts by praetor coda |
| Tags |
scratch build ![]() |
| Thread Tools | |
| View Mode | |
