RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Jul 2008, 08:45   #1
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
OCZ SSD vs. VelociRaptor
http://www.bit-tech.net/news/2008/07...velociraptor/1
HotHardware has shared the results of a performance test between the OCZ Core SSD and the high-end WD VelociRaptor mechanical drive - and the results may surprise you.
__________________
CardJoe is offline   Reply With Quote
Old 21st Jul 2008, 09:04   #2
knyghtryda
Multimodder
knyghtryda is on a distinguished road
space is still too small and price is still too high for SSD to be considered even at enthusiast level. I think once they can reach $1/GB levels (like the raptor), they'll have something that many people would want to pick up. Considering most storage is at $.25/GB or less at this point, I would seriously have to consider whether spending $300 on 300GB is worth it whereas I could get 2TB for the same price in a "standard" 7200rpm drive.
__________________
| Opteron 165 @ 2.6GHz [watercooled] | 2GB PC3200 | BFG 8800GT @ 756/2000 [watercooled] | Raptor 150GB + WD 1TB + Seagate 250GB + WD 250GB |
knyghtryda is offline   Reply With Quote
Old 21st Jul 2008, 09:09   #3
wuyanxu
quad fuelled, GTX200 powered
wuyanxu's Avatar
wuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura about
apart from speed, CPU and memory performance will also bottleneck you system. eg. i've experienced about the same loading speed on TM Nations Forever when i put it on RAMdisk. me thinks it's the other parts.
for desktop use, you really want a 32GB SSD for Windows, 150GB Veloci-Raptor (they are making one) for page file and games, 1TB drive for data.
__________________
Death to consolification !!!
Core i7 860 @ 4Ghz Cooled by Corsair H50 // Asus P7P55D Deluxe // 8GB of Corsair Dominators @ 1528Mhz 8-8-8-24 //
BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240
wuyanxu is offline   Reply With Quote
Old 21st Jul 2008, 09:18   #4
alexandros1313
Minimodder
alexandros1313 is on a distinguished road
I really like SSDs (in theory of course, I don't have one). Using an SSD promises smooth gameplay without stuttering (due to speedy access times) which would be excellent. I'd like for Bit-Tech to include a section in their SSD reviews, where they describe the subjective experience of playing games with an SSD. I really want to know if having an SSD improves smoothness of gameplay. Could someone from the bit-tech staff tell us about it?
alexandros1313 is offline   Reply With Quote
Old 21st Jul 2008, 09:26   #5
BlackMage23
RPG Loving Freak
BlackMage23's Avatar
BlackMage23 is on a distinguished road
nice performance gains if you have the dosh to spend on one and want to wait the hours that it would probably take to install windows on one.
__________________
I am the Black Mage. I cast the spells that makes the peoples fall down!
BlackMage23 is offline   Reply With Quote
Old 21st Jul 2008, 09:33   #6
TheCherub
Supermodder
TheCherub's Avatar
TheCherub is on a distinguished road
I think that is actually a more tempting proposition than people have so far mentioned. The only issue with these things is their size / value. However, most people that run something like a Raptor for their primary hard drive then run a 500Gb / 1Tb hard drive for data. This makes the size of the primary hard drive much less of an issue, and it reduces it down to a pure speed / value ratio. Given that Scan have the OCZ drive at about £10 cheaper than the Raptor, it doesn't look quite so expensive.
TheCherub is offline   Reply With Quote
Old 21st Jul 2008, 09:35   #7
Dr. Strangelove
Supermodder
Dr. Strangelove's Avatar
Dr. Strangelove is on a distinguished road
Is it just me or is it a bit odd to compare a 64Gb disk to a 300Gb disk? Does the size of the mechanical disk not give it a disadvantage, as in would a lower capacity VelociRaptor (if such exists) not perform better than the big one?
__________________
If it isn’t broken, fix it.
If it is broken, mod it till it looks like it's meant to be broken.
Dr. Strangelove is offline   Reply With Quote
Old 21st Jul 2008, 09:47   #8
iwod
Minimodder
iwod is on a distinguished road
For people who dont know the OCZ core series is now very affordable. Most people buy the Raptor not because of its capacity but its speed. While 64Gb is only slightly faster. Two 32GB SSD Raid 0 would only be slightly more expensive but a huge gain in performance. Not to mention the price will drop much faster then HDD.
Intel has promised a 200MB/s Read SSD this year. Although we have yet seen any news from it.
iwod is offline   Reply With Quote
Old 21st Jul 2008, 10:18   #9
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
Not at all - all other things being equal, a higher capacity disk will outperform a lower capacity disk, because of the difference in data density. Think of it like this - the read / write heads on a 7,200 rpm drive "see" one track of the disk platter(s) in 1/7,200 minutes (1/120 seconds), so the more data you pack into that track, the more data you can read or write in 1/120 seconds, so the faster the drive will perform.
__________________
Demand Naked DSL in the UK!
mclean007 is offline   Reply With Quote
Old 21st Jul 2008, 10:27   #10
impar
2n-1
impar's Avatar
impar will become famous soon enough
Greetings!
Agree with you.
The sinthetic tests that make for the bulk of HDD reviews usually dont represent the actual drive performance in real tests.
PS:
But, if you only factor the initial 64GB of the HDD, you get a better perfromance average than from the entire HDD.
__________________
The recruitment of Militia is illegal.
Militia-recruiters will be prosecuted to the fullest extent of the applicable laws.
impar is offline   Reply With Quote
Old 21st Jul 2008, 10:47   #11
TheCherub
Supermodder
TheCherub's Avatar
Surely, given that solid state drives work in a completely different fashion to conventional drives, this isn't really relevant? I would still argue that there is a worthwhile comparison to make, as you are effectively comparing two system disks (as opposed to data disks).
Old 21st Jul 2008, 11:33   #12
Denis_iii
Hypermodder
Denis_iii's Avatar
Denis_iii will become famous soon enoughDenis_iii will become famous soon enough
once 64GB SSD is sub 100quid I'll def get one, faster boot times and load times well worth the cost. If WD did a 65GB Raptor I'd consider it as want a small fast system drive for windows apps n games and 64GB is plenty as I never had more then 3games installed.
Denis_iii is offline   Reply With Quote
Old 21st Jul 2008, 13:42   #13
Omnituens
Supermodder
Omnituens is on a distinguished road
Currently I have a 74GB Raptor OS+apps drive, the velociraptor as my games drive and a 1TB lollerdrive.
I was thinking of having the OS on a SSD, but I forgot that you can change the location of the pagefile. Price is the only thing stopping me now really.
__________________
Current Rig: i7 D0 2.66GHz, 6GB 1066MHz Corsair "Dominator", 285 GTX.
Omnituens is offline   Reply With Quote
Old 21st Jul 2008, 13:52   #14
mclean007
Officious Bystander
mclean007's Avatar
Yes, absolutely. The original question to which I responded was "would a lower capacity VelociRaptor (if such exists) not perform better than the big one?" so I was just clearing that up, but of course with SSD the concept of platter density doesn't exist.
__________________
Old 21st Jul 2008, 16:30   #15
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
File copy times really don't mean a whole lot. The biggest advantages to SSDs over spinning platters are (effectively) zero seek time and greatly improved physical durability. You can't set up a clean system and just do file copying benchmarks and come to a conclusion - the improvements should really start to manifest themselves after several months of use when you start to get some heavy disk fragmentation.
Give me some useful benchmarks in areas that I actually care about and we'll talk. You know - how fast apps open, how snappy my day-to-day interaction is, etc. It's certainly more subjective overall, but so is my experience with using the computer so that's what I really care about.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 21st Jul 2008, 16:58   #16
ParaHelix.org
Supermodder
ParaHelix.org is on a distinguished road
I agree with you
ParaHelix.org is offline   Reply With Quote
Old 21st Jul 2008, 18:50   #17
leexgx
CPC hang out zone (i Fix pcs i do )
leexgx's Avatar
leexgx is on a distinguished road
SSD would not suffer slow downs like hdds do after time
speaking of page file if you got 4gb of ram its very unlikey the page file is ever going to be used
its Vista auto Defrag and system restore that do more to the drive
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947
leexgx is offline   Reply With Quote
Old 21st Jul 2008, 19:03   #18
crompers
Dremedial
crompers's Avatar
crompers has a spectacular aura aboutcrompers has a spectacular aura about
The technology is great, but i think i'll wait for the market to level out a bit before i spend. Also i view anything below 120GB as useless in this day and age.
__________________
| Q6600 G0 @ 3.21ghz | ACF7P | GA-P31-DS3L | 4GB HyperX 857mhz | XFX GTX280 655/1210 | WD 160GB | Maxtor 250GB | Black Gigabyte Aurora | OCZ GameXStream 700W | HP LP2475w | AE Aego M 2.1 | Roccat Kone | Saitek Eclipse |
Steam: psycrompton PSN: crompers85
crompers is offline   Reply With Quote
Old 21st Jul 2008, 23:31   #19
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
magnetic hard drives have been with us for how much time? how much was that amazing fast 10GB hard drive at the time?
give this technology time and it will ass rape current magnetic data storage with.... something long and wide.... either in speed, either in survivability.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 22nd Jul 2008, 00:32   #20
airchie
Mod Master
airchie's Avatar
airchie is on a distinguished road
I would have to disagree with that.
Enthusiast will spend out on SLi 280s just cos they can.
Why would they not spend out on raided SSDs?
Cost is obviously no major concern for them.
Plus, I'm a student and I'm getting an SSD into my laptop ASAFP.
I think that would make it worse.
I'm not 100% but drives fill from the inside tracks outwards.
Since the outer edges of the disk pass the head faster then the inner rings the performance is greater.
But your theory is right, only use the last 64GB of a mechanical HDD and the performance average would be better.
Hang on, now I think of it, HD-Tach's graphs show the drive getting slower and tailing off so I'm probably speaking rubbish above.
It depends really. If its your primary drive and you have no external storage then yeah.
If you have a 2TB raid5 NAS then not so much.
I can't wait to get an SSD (or two raided) into a gaming laptop in the future (once I start working).
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64
Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF.
Originally Posted by astralwandrer
Being a legitimate customer of the games industry is increasingly like being in a relationship with an abusive spouse.
airchie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
