#1 |
Multimodder
Which 4850?
I have a quick question. I am buying a Radeon HD 4850 512mb card and was wondering which exactly should I get? On the website I'm buying it there are 4 different types, and I have no clue about computers so I don't know what the difference is. The options are:
MSI R4850-T2D512E, 512MB, PCI-Express Club3D HD4850 512MB, ATI Radeon HD4850, PCI-Express Sapphire Radeon HD 4850 512MB GDDR3, PCI-Express HIS HD 4850, GDDR3 512MB, ATI Radeon HD4850, PCIe For some reason the Sapphire one is about €10 more expensive than the others. Is it just because of the name? Thanks in advance. |
#2 |
Ginger Nut
There will be virtually no difference, they're all the same design, same frequencies, etc.
Sapphire probably ship their own cooler with the card, that's why it's more expensive.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back. |
#3 |
Multimodder
And would it be worthwhile getting the Sapphire for the cooler, or should I just stick with the cheapest one, and possible get an aftermarket cooler?
#4 |
Ginger Nut
Personally I'd go for the aftermarket cooler (and I did). It might be more expensive, but you'll get better cooling for it.
__________________
#5 |
I don't trust myself with a Dremel!
What warranties the manufacturers offer might be something to consider, if they're at all different that is. Even with a stock cooler, do the 4850s get that hot?
#6 |
100% Gamer
there is also the toxic eddition now from sapphire http://www.hexus.net/content/item.ph...=14560&page=12
it features an aftermarket cooler and can be overclocked to 750MHz/750MHz/2,600MHz according to the review which nearly reaches the same clocks as the HD 4870! although, its a bit more expensive at £150
__________________
CPU: Q6600 GO @3Ghz - 4Gb DDR2 PC6400 - HD 4850 - corsair VX550 - Mobo: MSI P45 Neo - 320 Gb HDD ![]() |
#7 |
Freed on Probation
id go for whichever one has the longest warranty tbh (especially as cards seem to die on me just after 12 months!)
Ive already RMA'ed my evga 8800gts twice!
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson |
#8 |
Banned
So expect the cooler and the warranty, there is little differecne for those cards. But still I saw their prices are quite different.
| Thread Tools | |
