RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Jul 2008, 10:55   #1
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
AMD to spin-off fabrication?
http://www.bit-tech.net/news/2008/07...-fabrication/1
Comments by AMD CEO Dirk Meyer and CFO Bob Rivet lead to rumours that the company is planning to spin-off its manufacturing ability into a wholly separate company.
__________________
CardJoe is online now   Reply With Quote
Old 24th Jul 2008, 11:21   #2
BlackMage23
RPG Loving Freak
BlackMage23's Avatar
BlackMage23 is on a distinguished road
There are going to be a lot of tough decisions to be made at AMD to keep it going.
Long term it is better to keep the fabs, but if they don't make it past the short term then long term does not matter.
__________________
I am the Black Mage. I cast the spells that makes the peoples fall down!
BlackMage23 is offline   Reply With Quote
Old 24th Jul 2008, 11:44   #3
Xir
Supermodder
Xir's Avatar
Xir will become famous soon enough
"the company relies on IBM to build and test chips based on a 300mm wafer size"
errr, it develops future technology together with IBM (east Fishkill)...before that with Motorola.
Production however (300mm) is in Dresden-Germany, also production development (APC).
http://www.amd.com/us-en/Corporate/A..._10000,00.html
Also some processors of lower complexity are (were?...sempron) built in Singapore (Chartered)
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C
Xir is offline   Reply With Quote
Old 24th Jul 2008, 11:51   #4
Gareth Halfacree
WIIGII!
Gareth Halfacree's Avatar
Gareth Halfacree is on a distinguished road
Sorry, I was a bit vague there - the important part was "and test", as AMD don't have the facility to run short 300mm runs for development and testing purposes, relying on IBM instead. At least, that's how I understand it.
__________________
gareth.halfacree.co.uk | twitter!
bit-tech news correspondent
Gareth Halfacree is offline   Reply With Quote
Old 24th Jul 2008, 22:00   #5
Goty
Supermodder
Goty is on a distinguished road
I see this as being a bad move for AMD. Having in-house fabs has numerous advantages, not the least of which being lower productions costs and better control over the development of the manufacturing process, both of which are things that AMD is going to need desperately in the future.
*EDIT* It seems that AMD is denying reports that it's going to sell off its fabs.
Source: http://www.eweek.com/c/a/Desktops-an...-Fab-Sell-Off/
Goty is offline   Reply With Quote
Old 25th Jul 2008, 12:16   #6
Xir
Supermodder
Xir's Avatar
...besides, the Fabs are de-facto companies of their own (for instance FAB36 is a Company founded on german (saxon) coroprate laws):
AMD Saxony LLC & Co. KG
Oh what a great eweek article:
Quote: In the chip business, manufacturing eats up a vast chunk of the revenue
yeah...it's also the only part that generates revenue in the first place...these people are selling hardware, not ideas.
Quate: AMD converted its Fab 25 in Austin, Texas, into a facility that is now making flash memory for Spansion, a company in which AMD holds a financial stake
Actually AMD founded Spansion, before AMD itself manufactured flash memory (helped it through the downturn before last) before separating the flash-business from the rest and merging it with Fujitsu's flash business to form spansion.
Consisting of AMD'S old microprocessor FAB in Austin (the people that brought you the first aluminum Athlon's, the copper ones coming from Dresden) and Fujitsu's I believe 3 Fabs in Japan.
(more precice, they've worked togethet with fujitsu for over a decade before as FASL)
Ah well...the history of Semiconductor companies is easily forgotten.
__________________
SN25P
Old 25th Jul 2008, 16:35   #7
Goty
Supermodder
Ok, and the point of your post was?
Old 25th Jul 2008, 23:32   #8
Amon
inch-perfect
Amon's Avatar
Amon is on a distinguished road
So the resulting bodies could have been AMD Semiconductor and AMD Microprocessors?
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals
Amon is offline   Reply With Quote
Old 26th Jul 2008, 14:39   #9
Sark.inc
Multimodder
Sark.inc's Avatar
Sark.inc is on a distinguished road
I don't think they will sell off the fabs, just change how they do it and how they are made.
Sark.inc is offline   Reply With Quote
Old 30th Jul 2008, 16:35   #10
Xir
Supermodder
Xir's Avatar
The point is: they could sell Fabs that are individual companies allready ;-)
__________________
SN25P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
