RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Aug 2008, 11:02   #1
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
Nvidia denies planned MCP exit
http://www.bit-tech.net/news/2008/08...ned-mcp-exit/1
Nvidia has denied rumours started by Digitimes that it is to quit the motherboard chipset market in favour of concentrating on its graphics card technologies.
__________________
CardJoe is offline   Reply With Quote
Old 4th Aug 2008, 11:19   #2
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
I said it before and again. SLI and CrossFire setups are useless because within a year there is a new single card that out weights the expensive SLI / CF setup. Secondly the consumer choice is very restrictive, you either choose a mobo with SLI support or CF support. A better way is no SLI/CF controller on the motherboard at all and let two or more cards work with each other another way. Remember the 3DFX voodoo cards you could link up. You did not need any special motherboard for those.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 4th Aug 2008, 12:19   #3
kylew
Multimodder
kylew is on a distinguished road
Originally Posted by [USRF
Obiwan]I said it before and again. SLI and CrossFire setups are useless because within a year there is a new single card that out weights the expensive SLI / CF setup. Secondly the consumer choice is very restrictive, you either choose a mobo with SLI support or CF support. A better way is no SLI/CF controller on the motherboard at all and let two or more cards work with each other another way. Remember the 3DFX voodoo cards you could link up. You did not need any special motherboard for those.
You don't need 'special' boards for crossfire to run, the only requirement is to have the right PCI-E slots. It's nVidia that want to make people buy their own SLi boards to run SLi.
While I disagree that dual GPUs are pointless, I think that when some one buys the top end graphics cards and runs them in crossfire/SLI modes, that is pointless as you'd be paying a huge amount for something you don't really need and wouldn't see the benefits of until way down the line, when a single card comes out that's faster or at least just as fast.
Midrange cards though? Definately. I think the 4850s have been some of the best cards to come out since I got into computers.
They're cheap but very fast, and when combined in crossfire, blow away nVidia's cards for even less of the cost. Or the 9600GTs, they worked very well in SLi, and were fairly cheap to buy two of too.
kylew is offline   Reply With Quote
Old 4th Aug 2008, 12:20   #4
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is on a distinguished road
Obiwan]...the consumer choice is very restrictive, you either choose a mobo with SLI support or CF support. A better way is no SLI/CF controller on the motherboard at all and let two or more cards work with each other another way....
There is no SLI/CF controller on motherboards - the PCI-E standard is used for communications between cards on both dual/multi-GPU implementations. The trouble is a driver issue - nVidia artificially prohibits the nForce drivers from enabling SLi on non-nVidia chipsets. I'm sure I've heard of Crossfire running on nVidia boards, but why would you spend the extra for a SLi board if you didn't plan to run SLi? - better just to get e.g. an Intel P45 or X48 or whatever.
__________________
Demand Naked DSL in the UK!
mclean007 is offline   Reply With Quote
Old 4th Aug 2008, 12:29   #5
azrael-
Ex nihilo nihil fit
azrael-'s Avatar
azrael- has a spectacular aura aboutazrael- has a spectacular aura aboutazrael- has a spectacular aura about
As far as I know a special "controller" isn't really necessary, either for CrossFire or SLI. That's one of the reasons that Intel chipsets can do CrossFire. I believe EPoX even managed to make both CrossFire and SLI run on a i945 chipset some time back. HP/Voodoo have done something similar with the Blackbird 02 system (although I believe it's based around a custom version of the ASUS Striker mobo).
That being said I find that nVidia chipsets have been quite innovative in the past. However, this innovation has always come with a number of bugs, which nVidia usually can't be bothered fixing. The prime example for that would be the NV firewall. Great idea, bad execution. How they ever got it certified by ICSA Labs with all those obvious flaws is beyond me. I, personally, have also had other problems with my nForce3 and nForce4 mobos (malfunctioning USB ports for instance). Never had similar problems with Intel chipsets. I have no first-hand experience with AMD chipsets, although I'm bound to get some, since I've recently built a HTPC around a 780G mobo for a friend.
__________________
''Trying is the first step towards failure.'' - Homer Simpson
azrael- is offline   Reply With Quote
Old 4th Aug 2008, 13:05   #6
Gunsmith
my supersonic radar will help me!
Gunsmith's Avatar
Gunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant futureGunsmith has a brilliant future
bullshit bingo!
__________________
People who optimise code are wimps. My code knows it's awesome, so it'll take all the time it needs. You can wait in awe
Gunsmith is online now   Reply With Quote
Old 4th Aug 2008, 19:27   #7
ParaHelix.org
Supermodder
ParaHelix.org is on a distinguished road
Buy what you want, keep it to yourself, and shut the **** up about it.
ParaHelix.org is offline   Reply With Quote
Old 4th Aug 2008, 20:34   #8
Amon
inch-perfect
Amon's Avatar
Amon is on a distinguished road
Hmm, I never suspected that nVidia was planning on evacuating the MCP before Tron arrived.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals
Amon is offline   Reply With Quote
Old 5th Aug 2008, 05:51   #9
ZERO <ibis>
Supermodder
ZERO <ibis>'s Avatar
ZERO <ibis> is on a distinguished road
So Tron is coming!
I like the nvidia chipsets not just because of the sli but also other advancements such as ESA which I think is very useful for overclocking and overall system integration.
__________________
965 @ 4.26GHz-P6T DELUXE-GTX 280@750&1307-DDR3 Triple Channel@1001 MHz-RAID 0 Cheta 15.6k SAS-All Water cooled
IBIS GAMING
ZERO <ibis> is offline   Reply With Quote
Old 5th Aug 2008, 15:02   #10
Redbeaver
Hypermodder
Redbeaver's Avatar
Redbeaver will become famous soon enough
i love nforce. not only for SLI but for other things too.
but no, i dont use ntune.
__________________
Monita DFI NF4 Expert - X2 3800+ 2.925Ghz - 2x1Gb OCZ Gold XTC DDR500 - 2x eVGA 7900GT SLI - 2x80Gb Seagate 7200.9 [RAID-0 4k] - Enermax Liberty 500 - Vista Ultimate x86 - Silverstone Kublai [Modded]
Keisha DFI BloodIron P35 - Q6600 3.6Ghz - 4x1Gb OCZ Gold XTC2 DDR2-800 - eVGA 8800GTS 640MB - 2x80Gb Seagate 7200.9 [RAID-0 4k] - OCZ GameXstream 700 - Vista Ultimate x86 - Silverstone TJ-06 [Modded]
www.pecelayam.com
Redbeaver is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
