RSS
Go Back   bit-tech.net Forums > Recreation > Art & Photography
Reply
Thread Tools
Old 6th Aug 2008, 14:07   #1
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Nexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud of
POTM Entry August 2008: "Modern Farming"
Point of View entry. Or Culture. Or both...
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"There is no Real Life, only Away From Keyboard" --gpw111
"...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack
Nexxo is offline   Reply With Quote
Old 6th Aug 2008, 14:13   #2
yodasarmpit
The other Brett.
Moderator
yodasarmpit's Avatar
yodasarmpit is a jewel in the roughyodasarmpit is a jewel in the roughyodasarmpit is a jewel in the roughyodasarmpit is a jewel in the rough
This is a nice shot, and you have dealt with the exposure great.
__________________
The Rt. Hon. Alexander Boris de Pfeffel Johnson - "Ping Pong is coming home"
www.yodasarmpit.com
clickr my flickr
yodasarmpit is offline   Reply With Quote
Old 6th Aug 2008, 14:25   #3
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Thanks, means a lot coming from you who always takes impeccable landscape shots!
I was hoping the blades would blurr slightly to give a sense of motion. At some point I want to arm myself with a tripod and filters and do a series of Shutter Priority shots where the blades are blurred to full circles.
__________________
Old 6th Aug 2008, 14:35   #4
yodasarmpit
The other Brett.
Moderator
A tripod would be necessary, but if you caught it early or late enough in the day you could work without filters.
__________________
www.yodasarmpit.com
clickr my flickr
Old 6th Aug 2008, 14:59   #5
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
I love the theme and its unique interpretation. However, I think the picture could use a little bit of assistance for clarity with its post processing. The general exposure is NAILED but I actually lose the upper right blades in the clouds due to their color, making them almost a strain on the eyes.
I'd start with it in Photoshop, and probably apply the following:
0) slight crop to bring the windmill out of center for a more dramatic appearance - look to the lower right for a "hold" corner and shrink down til the tower is at about 1/3 from left. Will cut left and top down a bit for a nice shape.
1) Unsharp Mask (by the look of it, settings of about 200%, radius 1, Threshhold 10?)
2) Adjustment layer, Contrast - 10%
3) Clone the main image, blend mode multiply, opacity 30%
4) Apply "hide all" layer mask to that layer, then use a bar gradient on the layer mask. Center of the bar should be the middle of that light patch.
That will help even out the tone and eliminate that "bright spot" which makes it harder to distinguish details of the image. There's more I'd probably suggest, but it'd be having a play and hard to explain. Nothing that will change the look drastically, just "iron out" the wrinkles provided by natural light
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 6th Aug 2008, 15:25   #6
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
I've got Paint.Net here (can't afford Photoshop). It does not have some of the functions you describe... Sharpening is basic, and it does not have a "hide all" layer mask function with gradient bar so I had to cheat with a white-to-transparent gradient on the 30% opacity layer... but here's the result:
__________________
Old 6th Aug 2008, 15:37   #7
OleJ
Me!
OleJ's Avatar
OleJ will become famous soon enough
Wouldn't "Culture" be the category? Culture is the direct meaning of farming and it fits well as a descriptor of the taming of nature in the shot. Otherwise please hint at me to connect "Points of view" and a wind turbine.
Is it a hint at the different views on wind turbines? Whether they are pretty or not? I'm only seeing one point but not the view (relation)... Maybe I'm just dense...
Edit: Oh and good to see a submission from you again . Is it my lacking memory or has it not been a while?
__________________
Quickr! Clickr to my Flickr!
Canon camera stuff. Some aluminium PC, an HTPC and a MBP 17"..
OleJ is offline   Reply With Quote
Old 6th Aug 2008, 15:44   #8
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk will become famous soon enoughBlademrk will become famous soon enough
Well Nexxo called the shot "Modern Farming" so I guess the explanation would be that it's farming from a different point of view (i.e. not agriculture or livestock, which is the typical thought when someone mentions farming).
Nice shot Nexxo, I agree the top prop does get a bit lost in the clouds, but the sheep in the bottom half of the shot give it a nice sense of scale.
__________________
The Bit-Tech.net X-Box Live! Leaderboard
My X-Box Live & X-Fire GamerTag: BladeMRK
WII#: 0379 8536 3210 2060
My Flikr albums
Twitter
Blademrk is offline   Reply With Quote
Old 6th Aug 2008, 15:45   #9
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
You're right: it would be as good an entry under "Culture". I was originally thinking about the controversy of wind farms: many people think they are ugly and pointless; I consider them beautiful and functional. As Blademrk says there is also a contrast with traditional ideas of farming (sheep). I think that sheep alongside electricity generating windmills are going to be a sign of the times. Farming ain't what it used to be.
It has not been a while. Been busy, and I've not photographed anything worth submitting for a while.
__________________
Old 6th Aug 2008, 16:06   #10
BlackMage23
RPG Loving Freak
BlackMage23's Avatar
BlackMage23 is on a distinguished road
Second pic does look better.
__________________
I am the Black Mage. I cast the spells that makes the peoples fall down!
BlackMage23 is offline   Reply With Quote
Old 6th Aug 2008, 16:19   #11
Hwulex
Freerider
Moderator
Hwulex's Avatar
Hwulex is on a distinguished road
Lovely shot, and nailed on colours and exp. Think I'd actually prefer a landscape crop with 'mill in left side of frame with downward slope to bottom right corner and lovely cloud colour space in top right. If that makes any sense.
__________________
Clickr my Flickr
Hwulex is offline   Reply With Quote
Old 6th Aug 2008, 16:29   #12
Da Dego
Brett Thomas
Da Dego's Avatar
The second shot helps quite a bit to me. Nexxo, if you want me to have a go at it sometime since you're sans Photoshop, I'll be happy to try. I really like the concept.
__________________
Old 6th Aug 2008, 17:31   #13
OleJ
Me!
OleJ's Avatar
I see. I still think the semantic impact would be greater having "culture" in mind though. I guess I'm still too dense to see it
Please to make to translate?
Oh and 2nd one is by far the best. Composition works a lot better.
__________________
Old 6th Aug 2008, 17:38   #14
akpoly
jobless architect
akpoly is on a distinguished road
I agree
Windmills are beautiful objects IMO. Although when they spin too fast and implode is another situation...
__________________
Nikon D300 | Nikkor 17-55 f2.8 | Nikkor 70-200 f2.8 VR | Nikkor 18-200 VRII | Nikon SB-600 | Nikon MB-D10
akpoly is offline   Reply With Quote
Old 6th Aug 2008, 19:06   #15
supermonkey
Space Monkey
supermonkey's Avatar
supermonkey is a glorious beacon of lightsupermonkey is a glorious beacon of lightsupermonkey is a glorious beacon of lightsupermonkey is a glorious beacon of lightsupermonkey is a glorious beacon of light
I love how calm this image is. The warm colors and soft edges throughout all lend to a serene feeling. It kind of creates a visual paradox of cold science vs the warmth of the natural landscape. Windmills are the new trees, it seems - when I think of this type of shot I almost always imagine a giant oak tree dominating the scene
As others have said, the exposure is well handled, and the composition in the second version is great. Although I'm completely fine with the first composition, placing the turbine in the left portion of the frame provides a stronger visual impression of the invisible wind. If the turbine had been rotated slightly to face the camera, and if the blades had more motion blur, I think the first composition would have had a greater impact. Still, this is a wonderful shot as it is.
-monkey
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song.
-J.R.R. Tolkien, The Silmarillion
supermonkey is offline   Reply With Quote
Old 6th Aug 2008, 20:03   #16
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Go for it.
__________________
Old 6th Aug 2008, 20:44   #17
Da Dego
Brett Thomas
Da Dego's Avatar
Go for it.
Email me the RAW, I need it if at all possible.
__________________
Old 6th Aug 2008, 21:06   #18
Shadowed_fury
Natural Born Chaos
Shadowed_fury's Avatar
Shadowed_fury is on a distinguished road
Very nice Nexxo
__________________
Steam: kev_fury New Frag Video
- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston -
- Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA -
Shadowed_fury is online now   Reply With Quote
Old 7th Aug 2008, 01:07   #19
OleJ
Me!
OleJ's Avatar
At which altitude did you shoot this? I'm asking since you have the clouds hiding the top... I know the UK can get cloudy but this must have been shot rather high up?
__________________
Old 7th Aug 2008, 04:36   #20
TNash
Supermodder
TNash is on a distinguished road
Really nice. I love the look of wind power...I will never understand why people think those beautiful towers are hideous.
TNash is offline   Reply With Quote
Reply
Tags
potm
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
