RSS
Old 12th Aug 2008, 12:24   #1
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
SATA SDHC RAID spotted
http://www.bit-tech.net/news/2008/08...raid-spotted/1
Gizmodo has spotted a device on Japanese tech site Impress which turns six SDHC cards into a RAID 0 SATA SSD drive the same size as a traditional notebook disk.
__________________
CardJoe is offline   Reply With Quote
Old 12th Aug 2008, 12:37   #2
Icy EyeG
Controlled by Eyebrow Powers™
Icy EyeG's Avatar
Icy EyeG is on a distinguished road
Originally Posted by Article
The PhotoFast CR-9000 device, spotted on Japanese website Impress by Gizmodo is a SATA-connected 2.5” device which takes up to 6 SDHC flash memory cards and presents them to the host PC as a single logical drive.
I think the "6" is missing...
Icy EyeG is offline   Reply With Quote
Old 12th Aug 2008, 12:38   #3
WildThing
Multimodder
WildThing's Avatar
WildThing will become famous soon enough
Cool nifty little gagdet, but nothing more I think. Like you say, RAID 0 with 6 SDHC cards, sounds dangerous!
__________________
Asus M2N-SLI DELUXE ¦ AMD Athlon64 6000 ¦ Gainward GS 4870 1GB ¦ 2x2GB OCZ DDR2-800 Reaper ¦ Seagate Barracuda 7200.11 500GB ¦ Auzentech XFI-Prelude + Creative T7700 7.1¦ Enermax Liberty 500W ¦ CM690 case ¦ Samsung 22" 226CW ¦ Vista x64 SP1
WildThing is offline   Reply With Quote
Old 12th Aug 2008, 12:54   #4
cjoyce1980
Supermodder
cjoyce1980 is on a distinguished road
hopefully you should be able to recover the data on the other cards if one does die on you.
nice concept though
cjoyce1980 is offline   Reply With Quote
Old 12th Aug 2008, 13:01   #5
Timmy_the_tortoise
International Man of Awesome
Timmy_the_tortoise is on a distinguished road
6 SDHC Cards?
So, we're talking a maximum of 48GB using 8GB cards.. It's roughly £15 per card, that makes it £90... Then £48 for the unit..
We're talking £138 for 48GB of SSD storage, here.
Is that really worth it? I can see pretty much no point to this.
__________________
Q6600 @ 2.40GHz w/G0|Gigabyte GA-G33M-DS2R|4GB OCZ Gold PC-6400 800MHz|Powercolor Radeon HD4850|Samsung Spinpoint F1 1TB|Scythe Ninja Mini|LG Blu-ray/HD DVD/DVD-RW Combo Drive|Corsair TX650W|Antec NSK2480
Pioneer VSX-417|2x Gale 3010|2x Yamaha NSP110| MS304W Centre | MS308 Subwoofer
Timmy_the_tortoise is offline   Reply With Quote
Old 12th Aug 2008, 13:04   #6
Tyrmot
Multimodder
Tyrmot's Avatar
Tyrmot is on a distinguished road
No option for anything else like RAID 5 then? That would certainly make it more tempting...
Tyrmot is offline   Reply With Quote
Old 12th Aug 2008, 13:11   #7
TreeDude
Multimodder
TreeDude is on a distinguished road
nice concept though
It is a RAID 0. The data is broken up and striped across the drives. If you save a file, no matter what the size, pieces of that file will be on all the drives. That is how you get the increased read/write speeds. Trust me, if one drive goes, that is it for everything. Even using heavy recovery tools you would only be able to recover small system files that were smaller than the stripe size.
TreeDude is offline   Reply With Quote
Old 12th Aug 2008, 15:40   #8
naokaji
whatever
naokaji's Avatar
naokaji will become famous soon enough
simply too slow to be worth it (ssd is faster, like for example ocz core) , besides, how reliable are SDHC cards? I doubt they have a very high mtbf if used 24/7.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S
Opportunity is like delivery by DHL, it does not come to you, you have to track it down and chase it
naokaji is offline   Reply With Quote
Old 12th Aug 2008, 15:54   #9
SixthEnigma
What's a Dremel?
SixthEnigma is on a distinguished road
Raid Data Integrity -- If it weren't for the limitations of laptops, you could always fit two of these drives and set up raid mirroring between them :-)
SixthEnigma is offline   Reply With Quote
Old 12th Aug 2008, 17:18   #10
p3n
Hypermodder
p3n is on a distinguished road
nice concept though
go lookup RAID 0
p3n is offline   Reply With Quote
Old 12th Aug 2008, 18:06   #11
identikit
Ultramodder
identikit's Avatar
identikit will become famous soon enough
nice concept though
go lookup RAID 0
Yep, people commonly refer to RAID 0 as "RAID 0; the number stands for how many files you'll get back if it fails"
identikit is offline   Reply With Quote
Old 12th Aug 2008, 18:53   #12
Cobalt
Multimodder
Cobalt is on a distinguished road
I'm not sure it should even be allowed to bear the "RAID" moniker. The R does stand for redundant y'know.
Cobalt is offline   Reply With Quote
Old 12th Aug 2008, 20:16   #13
Anakha
Supermodder
Anakha's Avatar
Anakha is on a distinguished road
nice concept though
And yes, you lose one "Disk", you lose everything. Just like a non-RAID1 or RAID5 system. Though if you can identify the bad "Disk", you only need replace that one "disk" to get back the capacity you had. Unlike an SSD, where if the SSD goes down, you have to replace the whole SSD. No data recovery option there, either.
Personally, I think this is a great idea, it's just a shame the cost for the SDHC cards isn't lower. Still, get some 133x (Or higher) cards in there and you'll have a "Drive" that has 0ms random-access time AND massive bandwidth, the holy grail of storage. Stick your Windows partition on that, and store all your media on a 1TB 5400 RPM drive, and your storage won't be the bottleneck anymore.
__________________
Robert "Anakha" Johnston
Going to Canada on Nov 28th! I'm going home!
Anakha is offline   Reply With Quote
Old 13th Aug 2008, 06:16   #14
Scottyman
What's a Dremel?
Scottyman is on a distinguished road
I'd be interested if it was in P2 presentation, as this isn't quite flexible enough yet... looks like it's taking steps toward it - ideal for broadcast media
Scottyman is offline   Reply With Quote
Old 13th Aug 2008, 06:37   #15
Xir
Supermodder
Xir's Avatar
Xir will become famous soon enough
"I'm afraid that you'll have to find another use for those hundreds of 512MB and 1GB cards that seem to accumulate every time you buy a new gadget."
Uhhh my Gadgets are officially limited to 1 GB ;-)
The three devices that do use SD cards (camera, car stereo and navigator) all state that they don't support more than one GB...never tested this though.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C
Xir is offline   Reply With Quote
Old 13th Aug 2008, 10:21   #16
Xir
Supermodder
Xir's Avatar
...so if you have hundreds of spare 512 and 1GB cards... I'd take them for the car stereo :-D
__________________
SN25P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
