Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 12th Aug 2008, 11:36   #1
bigc90210
Teh C
bigc90210's Avatar
bigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for presidentbigc90210 should be considered for president
Best 3rd Party Air 8800GTX Cooler?
I seem to have high temparatures on my 2 8800GTX's, i get crashes when trying to run COD4 and System Lockups when i try playing other games too (UT3, Crysis, Gears of War).
What should my temparatures be for idle and load? il post what they are when i get home, but im sure they are a bit high (i use nvtemp i think it is, and the temps are in the red section of the monitor
anyways iv been looking at 3rd party coolers, as iv read online that the standard ones are crap. Im not looking to watercool, just a better heatsink n fan cooler would do. The best iv seen so far is http://www.kustompcs.co.uk/acatalog/info_2887.html
Does anyone have any similar experiences or suggestions for me?
BTW my cards are XFX 8800GTX XXX Editions (in sli) with a physx card in between.
Cheers
__________________
Asus Gene-Z, i5 2500k @ 4.6GHz, Intel RTS2011LC CPU WC, 16GB (4x4gb) Corsair Ballistix Sport 1600Mhz 1.5v, 2x MSI 7970 OC 3GB, Sandisk Readycache 30GB, 500GB Hitachi Desktar, 500GB Seagate Barracuda, Corsair Carbide 300r, Logitech G19, Razer Naga Molten, Asus ROG ed Steelseries Siberia 2, QNIX 27" 2560x1440p, 2x Iiyama 22" 1080p
bigc90210 is online now   Reply With Quote
Old 12th Aug 2008, 13:11   #2
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpit
8800GTX with stock cooler should fetch around 60 idle, 80 load. but since it's 2 cards, my guess is 65 idel, 90 load should be what we are looking at.
the BEST heatsink is Thermalright HR-03-PLUS . but you'd be having problem fitting a fan to it. so make sure you have goot airflow.
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 12th Aug 2008, 13:22   #3
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Arctic Cooling's Accelero Xtreme 8800 has been getting some praise lately too. I have one, I just haven't installed it yet on my 8800GTS G80. You may have issues getting two of them fit in SLi with the Physx card though.
__________________
Latest Builds:
LilyPC - in progressBIO-A10 - MotM Jul. '12 Nominee Loser!"Movie Sign!" - in progressCheckMate - MotM May '09 Nominee Loser!BluBawx I - MotY '09 Nominee Loser!Lumière Noire - MotM Apr. '08 Nominee Loser!NOTalis w/ MNPCTech"Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 12th Aug 2008, 20:02   #4
sheninat0r
What's a Dremel?
sheninat0r has yet to learn the way of the Dremel
I think the HR-03 [or one of its variants] would be your best choice, mostly because of the PhysX card you've got in between - most other coolers won't fit, since they often take up more slots than the stock cooler, but the HR-03 can be mounted so that the fin stack is facing away from the PhysX card so it won't interfere.
__________________
...with a crowbar.
sheninat0r is offline   Reply With Quote
Old 14th Aug 2008, 09:02   #5
Hazardous
Mod Master
Hazardous's Avatar
Hazardous has yet to learn the way of the Dremel
If you've got the room for it... Arctic Cooling's Accelero Twin Turbo is available for just a little over £20
You'd need to double-check it's suitability for the 8800GTX though, since it's not among the cards mentioned on the website?
If it's not... and you have room for it, then the one above would be the one to go for
__________________
Beauty is in the eye of the beer-holder
Hazardous is offline   Reply With Quote
Reply
Tags
graphics, graphics card
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
