Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Asus CrossHair II Formula and Hybrid SLI
http://www.bit-tech.net/hardware/200...r-ii-formula/1
Asus takes Nvidia's nForce 780a to the next level with its second generation CrossHair motherboard. Does Hybrid Graphics cut the mustard? Does Asus make another Republic of Gamer masterpiece? We went off to find out.
__________________
#2 |
I feel your presents.
Is the 'hybrid' 8200 able to be used as a Physx 'card'?
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#3 |
The Burgerman Can
yum
| Nuffenburger |
| View Public Profile |
| Find More Posts by Nuffenburger |
#4 | |
whatever
I'd rather see hybrid sli on a no thrills matx board than this feature loaded beast, sure, the mainboard has "everything", but if you are going for an amd cpu it wont be a attempt to build a high end gaming system anyway.
good job on the review though.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#5 |
Richard Swinburne
bit-tech Staff
Hmm, nice idea. I'm not sure actually, it eats up a lot of memory bandwidth so it could be too slow.
#6 |
Vapourmodder
anyone else find it slightly amusing that crosshair motherboards aren't crossfire compatible?
__________________
Current setup: Hiper Osiris | Core i7 920 (Cooled by Noctua NH-U12P) | Foxconn Renaissance | 2x GTX280 | Cooler Master UCP | Corsair Dominator 3GB (soon to be 9GB) | Creative X-Fi Titanium | Vista Home Premium x64 | OS Drive: WD Velociraptor 300GB. Storage: 1x 160GB, 1x 250GB, 1x 300GB, 1x500GB (incremental additions over the years! All Maxtor) | Monitor: Dell 2709W |
| ChaosDefinesOrder |
| Find More Posts by ChaosDefinesOrder |
#7 | |
Enginerd!
__________________
Athlon X2 4000+ @ 19.7GHz ¦ Saphire 4850 ¦ MSI K9A2 CF
Bit-Tech Folding@Home Team (33346) Join us The Folding thread flickr? |
#8 |
HOT HOT! Freaking HOT!
Guys Asus are the sexist thing you can get in this planet. Very dam cool . I can't wait for x58 :P
__________________
GigaByte Triton 180|GigaByte EP45-UD3LR|Intel Q9450|Transcend 4GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|3TB WD Green The King Of CK Appreciation Society Group
| ComputerKing |
| Find More Posts by ComputerKing |
#9 |
Multimodder
ever mobo just looks the dogs gonards nower days dunnit i think its a pritty gd mobo not 2 steep on the £cedits either id still go with a p45 tho for tha price..
#10 |
Ultramodder
looks for once like its the same price in the uk as the us
#11 | |
Richard Swinburne
bit-tech Staff
#12 | |
Multimodder
#13 |
__________________
| ComputerKing |
#14 |
Richard Swinburne
bit-tech Staff
Ah, I can understand Mancunian, but Scouse and Jordie is beyond me
#15 |
Multimodder
I had that board for a while, and could run dual monitors with Hybrid SLI
Was nicer than dual monitors with normal SLI because the change between SLI / Hybrid worked 99% of the time instead of 80% of the time.Unfortunately the Phenom CPU (which I got to 2.9Ghz too) is hopelessly slow. It was slower (actual playing wise, not benchies) than my Intel Quad (3.4Ghz - I know not a 'fair' comparison) with a single GPU. Not a little slower either, the difference was staggering since the Intel system was smooth, while the Phenom though it had the FPS, had constant stutters. Mini-stutters very often, and a big stutter/pause every 10 seconds or so. It made games unplayable if you value great accuracy, such as MOH:Airborne when using a rifle. Incidentally I never had a stutter problem when I ran dual P4 Xeons with SLI. Can't fault the board though, I thoroughly enjoyed using it and shall remain one of the favourite boards I've ever had. It's not perfect, but it has plenty of character and just keeps on giving. If the AMD Phenom was a great deal faster, there is no question I would be running Phenom with that board. |
#16 |
Refugee of CPC
Have had the board for a while now with a Phenom II 940 and found it to be simply superb.
On air I can get the Northbridge up to 2640Mhz with a 264Mhz FSB and 10 mulit The HT link is running at 2112Mhz and is Rock Stable Also is 100% stable with a 14x Multi and 3.7Ghz. Memory Bandwidth and benchmarks are superb this board really does make sense when paired with a Black Edition 9** series
__________________
XFXScorpio911 ¦ PHENOM II X4 940 @ 3.92Ghz ¦ XFX GTX 260 XXX 896MB¦ ASUS CROSSHAIR II FORMULA ¦ 4GB OCZ REAPER 1066 5-5-4-8 2T¦ SAMSUNG 1000GB F1 ¦ Windows XP 32bit ¦ |
| Madness_3d |
| Find More Posts by Madness_3d |
| Thread Tools | |
