Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
Samsung SyncMaster XL30 LED Backlit LCD
http://www.bit-tech.net/hardware/200...cmaster-xl30/1
We test Samsung's latest and greatest LED backlit 30" professional monitor to see if it can top the cables and better our current favourite - the 30" NEC.
#2 |
ITS OVER 8000!
I'd rather have 2x Dell 3008's please.
K thanks. |
#3 |
Lazy Lurker
Sounds like fun. Call me back when they decide to add extra connection options and a faster switching panel. Once they have that combination, they will have the must have product.
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#4 |
Supermodder
The inclusion of the X-Rite calibrator and software is kind of cool, but I've had trouble getting mine to finish the calibration process in Vista.
#5 | |
Supermodder
But in any case, point of order - sRGB primaries are supposed to be Rec. 709, not 601, so it's pretty meaningless to compare it to NTSC. P |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
#6 | |
Supermodder
However I agree, NTSC percentages are meaningless too me. I would have rather Samsung had quoted specs in sRGB and Adobe RGB gamut percentages, both which the XL30 supports. Mind you it does have a 14-bit LUT. A bit concerned by the evident inverse ghosting and whether the overdrive is really performing at 6ms and not something a bit higher like some recent top end NEC monitors have (spec'd as 6ms, but behaved more like 8ms). So I wonder what's its true On/Off responce time? 12ms probably? Perhaps BeHardware.com will get their hands one of these and give a good "test" thrashing. Would love to see it put up against the Eizo ColorEdge CG301W which has very similar specs though with a CCFL lit panel, HD support, and 12-bit LUT, but £400 more expensive than the XL30. I would like to know how sturdy the stand is and the level of build quality of the XL30 too? Last thing I'd want is one of these getting all wobbly on its stand. Eizo build quality is top notch and their UK support is phenominal; how's being leased an identical replacement monitor for free whilst yours is being repaired? And is the Eye-One Display profiling device a rebranded Display LT or Display 2 by chance? Samsung could have ditched it and shaved £100 off the price tag.
__________________
MONSTRI MIHI NON STERCORUM --------------- ~ ---------------
| Darth Joules |
| Find More Posts by Darth Joules |
#7 | |
Supermodder
I thought the default setup for computer monitors was always supposed to be sRGB, ergo 709 primaries with a different gamma ramp. |
| Phil Rhodes |
#8 |
Hypermodder
any good for gaming?
__________________
My Main Rig:|AMD 64 FX60 @ Stock|DFI LanParty SLI-DR | PC Power & Cooling 510 SLI EXTREME |2 GB Crucial Ballistix Tracer | 8800GTS | X-Fi Titanium Fatality®™ | Logitech® Z-5500 5.1|Hitachi 250GB x 3, 400GB, 160Gb, 120GB, SATA|Pioneer DVD-Rewriter Drive Black x 2 |
#9 |
inch-perfect
what the fukk....
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#10 |
What's a Dremel?
Pretty soon, I'm going to be buying either the Samsung XL30 or NEC 3090WQXi.
Since bit-tech has reviewed both of these monitors, I was wondering if you could provide some invaluable insight. Price aside, which would you recommend for someone that mostly does photo editing with occasional gaming (with extensive document reading/general things). For me, colour accuracy and viewing angles are most important. In particular, how does the XL30 compare to the 3090WXQi when viewing from angles "off centre"? Which monitor retains more of the colour and contrast accuracy when viewed from the side? Really hope you can respond, as I'm about to put down quite a chunk of change. Many thanks!! |
| Thread Tools | |
