RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Aug 2008, 23:51   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Nehalem derivatives detailed
http://www.bit-tech.net/news/2008/08...ves-detailed/1
We've got the skinnies on the various Nehalem derivatives that'll be released over the next six-or-so months.
Tim S is offline   Reply With Quote
Old 20th Aug 2008, 09:08   #2
wuyanxu
quad fuelled, GTX200 powered
wuyanxu's Avatar
wuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura about
what about sockets?
i heard there will be different sockets for different market segment, so if one buys mid-range motherboard, one may not be able to use higher end Bloomfield (currently named i7)
__________________
Death to consolification !!!
Core i7 860 @ 4Ghz Cooled by Corsair H50 // Asus P7P55D Deluxe // 8GB of Corsair Dominators @ 1528Mhz 8-8-8-24 //
BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240
wuyanxu is offline   Reply With Quote
Old 20th Aug 2008, 12:06   #3
Timmy_the_tortoise
International Man of Awesome
Timmy_the_tortoise is on a distinguished road
Yeah, I heard that too.. The different socket types weren't discussed?
__________________
Q6600 @ 2.40GHz w/G0|Gigabyte GA-G33M-DS2R|4GB OCZ Gold PC-6400 800MHz|Powercolor Radeon HD4850|Samsung Spinpoint F1 1TB|Scythe Ninja Mini|LG Blu-ray/HD DVD/DVD-RW Combo Drive|Corsair TX650W|Antec NSK2480
Pioneer VSX-417|2x Gale 3010|2x Yamaha NSP110| MS304W Centre | MS308 Subwoofer
Timmy_the_tortoise is offline   Reply With Quote
Old 20th Aug 2008, 14:55   #4
M4RTIN
Ultramodder
M4RTIN's Avatar
M4RTIN will become famous soon enough
so you can only go quad core if you go super high end, if the sockets for i7 and whatever the dual core one is called is different that could be a real pain, having to buy a new board and start again with windows jsut to swap cpu's
M4RTIN is offline   Reply With Quote
Old 20th Aug 2008, 18:09   #5
bowman
Multimodder
bowman will become famous soon enough
LGA1366 = Bloomfield ('i7') quad cores. QPI, triple-channel DDR3. Both high-end desktop and dual-socket workstation and server platforms.
LGA1160 = Lynnfield ('isomethingorother' I guess they'll be, not i7) quads and Havendale duals. DMI, dual-channel DDR3. Mainstream desktop platforms, different socket but same CPUs for laptops I guess.
bowman is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
