RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 20th Aug 2008, 18:52   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Small form factor Penryn chips announced
http://www.bit-tech.net/news/2008/08...ps-announced/1
IDF FALL 2008: Intel announces small form factor Montevina/Penryn chips... looks like we'll be seeing an updated Macbook Air soon.
Tim S is offline   Reply With Quote
Old 20th Aug 2008, 19:02   #2
p3n
Hypermodder
p3n is on a distinguished road
Wonder if they were making it for Apple anyway so everyone can join in this time </apple fanboi>
p3n is offline   Reply With Quote
Old 20th Aug 2008, 19:48   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Well, the IBM X300 was based on the same tech as the Macbook Air, so it wasn't specifically designed for just Apple. Apple was just the first to implement it...
Old 20th Aug 2008, 21:00   #4
p3n
Hypermodder
Well im just glad they have finished releasing stuff so Apple can finally refresh the MacBookPro .. if they aren't too busy making the iPhone slower and breaking mobile me!
Old 22nd Aug 2008, 09:28   #5
ParaHelix.org
Supermodder
ParaHelix.org is on a distinguished road
Apple, Apple, Apple, just when will you learn. While we are on the unfortunate topic of Apple I might as well note the problems in which its software is creating in the Windows Vista enviroment. I know a lot of people out there are getting the "Multiple Netowrks" bug when ever they start up Vista, this stops you from accessing the internet and the only quick fix in Vista is to disable and then re-enable your network connection...every time you reboot. However I have finally found the source of this "bug" and it lays deeply in the heart of Apples sneekily installed "Bonjoir" networking software which gets installed with iTunes (without user permission I must add, Apple). So, if you are getting this bug all you have to do is uninstall the Bonjoir software from "Windows Add/Remove software" and WALLAR! no more messing with your network connection.
Hope this helped some of you guys,
many thanks, ParaHelix.org
ParaHelix.org is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
