#1 |
Richard Swinburne
bit-tech Staff
OCZ Vendetta 2
http://www.bit-tech.net/hardware/200...z-vendetta-2/1
OCZ is back to settle the score with the Vendetta 2 heatsink. With a larger low noise 120mm fan, and even more cooling fins, it promises to improve on the original Vendetta and then some! We strap it into the bit-tech test rig and find out if the Vendetta 2 can settle its feud with the competition.
#2 |
Busy procrastinating
*cough cough* thermalTAKE ultra-120 extreme!?!
nice review though :-) |
#3 |
Dremedial
Could i ask exactly how difficult to install? I'm in the market for a new heatsink but if its going to break my motherboard installing the thing then i'll just get a Freezer 7 pro.
__________________
| Q6600 G0 @ 3.21ghz | ACF7P | GA-P31-DS3L | 4GB HyperX 857mhz | XFX GTX280 655/1210 | WD 160GB | Maxtor 250GB | Black Gigabyte Aurora | OCZ GameXStream 700W | HP LP2475w | AE Aego M 2.1 | Roccat Kone | Saitek Eclipse |
Steam: psycrompton |
#4 | |
Ultramodder
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#5 |
is true bit-techer!
that is a piss poor mount,
bindi dose the mount look as if it could be modified to be a bolt through, i can get a back plate made easy enough.
__________________
DFI P45-T2RS Plus, Q6600, 4GB Reaper HPC, GTX280 & FX3450, X-Fi Xtreme Music, 1570GB Storage |
#6 | ||
Dremedial
__________________
#7 |
Supermodder
...Just another heatsink.
| ParaHelix.org |
| View Public Profile |
| Find More Posts by ParaHelix.org |
#8 | |
Richard Swinburne
bit-tech Staff
#9 | |
quad fuelled, GTX200 powered
excellent performance for money though.
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#10 |
Licenced idiot.
"Lets just make it even a bit more like the Xigmatek HDT-S1823 and it'll be better.." -OCZ team
Nah, it's just OEM-manufacturers and branding, but just seems kinda funny every now and then
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#11 | ||
whatever
most cases (even with slideout mobotrays) require that you install the cooler inside the case since they are too high to slide the mob tray back in with the cooler installed (installing on mobo and then putting mobo is no option either since the access to one of the mainboard screws is not possible with the cooler installed). also, everything gets in the way of each other part. You have to put it on the mainboard without the fan installed, because otherwise you cant access the mounting mechanism. but then you have to go through the pain of attaching the fan, wich sucks because the nb heatsink will get in the way, then lets not forget that the fan and ram often creates spacing issues. and then those stupid pushpins... slicing fingers on fins guaranteed (thx god for modding). seriously, heatsinks are just too big for atx mainboards these days. watercooling cheesecake, ek supreme has none of those issues.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#12 |
Ex nihilo nihil fit
Hmm... What's the weight of this thing now? On the front page it's stated at 520g, which made me read the article in the first place, since I'm only interested in CPU coolers weighing a max. of about 500g. Then on the third page it's stated that the cooler weighs 746g, which makes sense since even the original Vendetta weighed about 600g. Confused I am...
__________________
''Trying is the first step towards failure.'' - Homer Simpson |
#13 | |
Richard Swinburne
bit-tech Staff
#14 | |
Ecky thump
Moderator
To ensure the push-pins are correctly locked the HS instructions are likely to advise fitting the sink with the motherboard outside the case, so you can inspect the reverse side. This makes fitting very easy, though to fit the motherboard you then need a 6" screwdriver. My Scythe Ninja 'B', used in thousands of systems, also relies on push-pins as-sold, and weighs 665g without fan. The
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. |
#15 |
Multimodder
Now all OCZ needs to do is try and get a fourth heatpipe in there and make It work correctly and have It support all AMD and Intel cpu sockets, Oh and a thermalright 775 bolt thru kit will work wonderfully and costs about $5 before ups here in the USA.
#16 | |
What's a Dremel?
Backplate available from Xigmatek
http://www.xigmatek.com/product/acce...-adk-i7751.php And it's only $10 (free ship) from newegg.com: http://www.newegg.com/Product/Produc...82E16835233027 cheers! |
| Thread Tools | |
