Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
RV770: ATI Radeon HD 4850 & 4870 analysis
http://www.bit-tech.net/hardware/200...cture-review/1
We've seen the benchmarks and how ATI has comeback from nowhere to reclaim the mainstream performance crown, but what's behind this sudden change that makes the new HD 4000-series so compelling? We dive deep down inside to find out.
__________________
#2 |
Ultramodder
An incredible detailed article Tim, kudos!
The biggest shock for me, is the power consumption of the 4870x2. You would suspect it will be side by side with the Nvidia top card in idle power. Is this a design flaw? AMD said they made a power efficient 'something' on the cards to put power to a minimum with idle. I thought the cards would shut down the 3D hardware in a 2D environment and become active when a application required the need for raw 3D power. Also the power it needs when in performance mode is incredible. Is the 483watts at the socket or the card itself? Its almost 120w more the the GTX280. Makes you wonder what a "GTX280 x2" would suck out of the wall.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#3 |
Pewlius Caesar
bit-tech Staff
483W is full system load at the socket with a power supply that's about 80 percent efficient at that load.
__________________
#4 |
Multimodder
Great article, well worth waiting for. Thanks!
__________________
Phenom II X4 955 @ 3.2ghz | Asus Crosshair III Formula | Coolermaster V8 CPU Cooler |4Gb Corsair Dominator DDR3 at 1333mhz | Sapphire Radeon 5870 | Crucial M225 128Gb SSD | Samsung SyncMaster 226BW |
#5 |
Pie Eater
nice article Smalley, i'll be honest its all a bit too much to digest for me. 16 pages, i think i read 10 but alot of it just goes whooshhhhh over my head. nice article though and for your first major feature after your absence, its a testament to yourself and the support of the staff at bit-tech.
kudos fatman
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
#6 |
Hypermodder
in Canada here, the 260s is at the same price point at 4870......
__________________
Monita DFI NF4 Expert - X2 3800+ 2.925Ghz - 2x1Gb OCZ Gold XTC DDR500 - 2x eVGA 7900GT SLI - 2x80Gb Seagate 7200.9 [RAID-0 4k] - Enermax Liberty 500 - Vista Ultimate x86 - Silverstone Kublai [Modded] Keisha DFI BloodIron P35 - Q6600 3.6Ghz - 4x1Gb OCZ Gold XTC2 DDR2-800 - eVGA 8800GTS 640MB - 2x80Gb Seagate 7200.9 [RAID-0 4k] - OCZ GameXstream 700 - Vista Ultimate x86 - Silverstone TJ-06 [Modded] www.pecelayam.com |
#7 |
Multimodder
same thing in australia... which probably means ati is making quite a bit more than nvidia on a per card basis.
#8 | |
Dremel Worthy
#9 |
What's a Dremel?
Who will be the first to replace the Vitec 59PR9853 multi-phase by a bigger one ? (see page 5 about power suply of the 4750)
| Ontheronix |
| View Public Profile |
| Find More Posts by Ontheronix |
#10 |
hmmmm....
Great article Tim, like most of us here I didn't understand all of it. But it is still very informative and an interesting read. Thankyou.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#11 |
a.k.a KazeModz
well that was certainly the best article I have seen in a while from BT, great job, very nice details.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#12 |
Weekend Junkie
This makes me dizzy.. But kudos to Tim for the effort and for the dizzyness. I love BT for this. (Not to be taken up as any kind of physical effort. :-D )
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard. |
| Spaceraver |
| Find More Posts by Spaceraver |
#13 |
Supermodder
So what's next from ati and Nvidia and when?
Before or after the yule>? New or improved architecture>?
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs |
#14 | |
CPC hang out zone (i Fix pcs i do )
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947 |
#15 |
Pewlius Caesar
bit-tech Staff
Interesting, I will have to double check that one - thanks!
__________________
#16 |
was quite sure as some users was overclocking there 3870 cards and could get more by setting the option in bios on amd based boards that suported the setting to givemore power down the PCI-e slot (you can even pick witch slot gets more power)
__________________
#17 |
inch-perfect
Ctrl+D
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#18 | |
Pewlius Caesar
bit-tech Staff
__________________
| Thread Tools | |
