| View Poll Results: What influences your PSU purchase? | |||
| Brand? |
76 | 66.09% |
| Weight? |
7 | 6.09% |
| Noise? (or, "claimed" noise levels) |
78 | 67.83% |
| Efficiency? |
79 | 68.70% |
| Solid Voltages? |
62 | 53.91% |
| No voltage ripple? |
38 | 33.04% |
| Design - colour/look/feel/finger print magnet? |
24 | 20.87% |
| Wattage? |
71 | 61.74% |
| Cost compared to other brands of same wattage? |
40 | 34.78% |
| Total cost - Inexpensive or cheap and cheerful? |
12 | 10.43% |
| Total cost - Expensive (percieved quality or extra features) |
24 | 20.87% |
| Additional bits in the box - Velcro ties etc? |
13 | 11.30% |
| Box design? |
2 | 1.74% |
| Size - if it's standard ATX or longer? |
19 | 16.52% |
| Cable design - braid/colour? |
28 | 24.35% |
| Cable length - different lengths/or at least a certain length? |
23 | 20.00% |
| Cable variety - PCIe/molex/SATA/floppy? |
38 | 33.04% |
| Modular? |
70 | 60.87% |
| UK (or local) RMA base? |
18 | 15.65% |
| Length of warranty? |
35 | 30.43% |
| A good/bad review on your favourite site(s)/mags? |
83 | 72.17% |
| Multiple Choice Poll. Voters: 115. You may not vote on this poll | |||
Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
What influences your choice of Power Supply purchase?
I'm constantly in heated discussions with PSU manufacturers about what the most important thing in a PSU purchase is, but I figure the best people to ask are you lot since you actually buy them!
So let us know, but only select stuff that you REALLY think is important in making a purchasing decision. By knowing this I can look for and write more according to your needs ^_^ Cheers
#2 |
quad fuelled, GTX200 powered
i look for the output ampage on 12v, is it quiet, its size (length is most important) and CPU power cable length. (last 2 are for Antec p182 really)
modular, number of SATA/molex connectors, are not really as important for me. as long as a PSU gets good reviews and recommendations, i'll consider it if price is right. that's really the reason i ended up with Corsair Hx620w.
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#3 |
Richard Swinburne
bit-tech Staff
Sorry, poll took a while to add
#4 |
Air Cooled Fool
I got an Antec TP Quattro 850. It got a very good review in Custom PC...
... and has racing stripes on it! In hindsight, I should have saved a few watts and spent a few more pounds on a 8800GTS. That said, I expect the PSU to be the longest lasting bit of kit I bought, unlike a GPU it shouldn't be obsolete in 6 months. So what's important? Price. Watts/£ is important, obviously modular costs xx% more. Comparing other units of the same wattage is useful. Getting a good review from a trusty hardware website is often the clincher though
__________________
- Q6600 G0(9x333) -- Asus P5k Premium -- 2GB Ballistix DDR2-800 -- BFG 8800GT 512MB -- TRUE120 -- 500GB Samsung Spinpoint -- Antec Quattro 850W -- Samsung Syncmaster 206BW -- Razer Lycosa, DeathAdder, and Destructor -- Antec Nine Hundred --
Pistol Pete's Project Perspiration Project Log Last edited by pistol_pete; 4th Sep 2008 at 11:28. |
| pistol_pete |
| View Public Profile |
| Find More Posts by pistol_pete |
#5 |
Do the funky chicken..
I want a PSU that is a good brand which means;
good efficiency braided cables long enough cables for a big case more wattage than what I need modular Brand wise my current PSU is a 500 watt Seasonic. For my next build I'm going for one of the Corsair 650 watt psu's.
__________________
Main rig: i7 920, 6gb 1600mhz ram, Asus P6T Mobo, WD Raptor 70gb as OS disk, 1tb F1 as storage, Creative X-FI Fatality pro soundcard, 8800GTX Photography gear; Nikon D700, Nikon D80, Nikon 70-300VR, Nikon 24-70 AF-S, Nikon 35mm F2 D,Nikon 50mm 1.8D, Nikon 85mm 1.8D, Micro Nikkor 55mm f2.8 AI-S, Nikon 135mm f2.8 AI-S, Nikon SB-800, SB-900 Last edited by GregTheRotter; 4th Sep 2008 at 11:40. |
#6 | |
Neuken in de Keuken
Corsair VX550 - Cheap & Cheerful (ish), but less likely to blow up & take all my components with it than the no-name "ebuyer 500W special" :eek:
Good cables, good warranty, and nice and quiet too.
__________________
#7 |
Bit Tech Biker
Brand is important for two reasons; so you can search and find out other peoples experiences and second so that they have something to be concerned about if you need to drag their name through the mud because they've tried to avoid their responsibilities.
Wattage is important but more important to me is that it can actually deliver the claimed wattage consistently and reliably for a long period without sounding like an express train. Don't really give a damn about design but subtle and understated is best, shiny chrome with epilepsy inducing, sunburn causing lights will never get anywhere with me. Cable variety is great, being able to choose the cables that suit with the HX620 is great, I do wish that it were possible to buy an extra set of cables for it though with longer/shorter cables and maybe one for chained drives. Length of warranty, a longer warranty suggests that the company has faith in the product, even if you're going to void it that's important. Moriquendi
__________________
**** YOU TIM, two of my friends died clicking links like that. [Stickeh] |
| Moriquendi |
| Find More Posts by Moriquendi |
#8 |
I cast flare!
Reliability and efficiency are the two deciding factors when buying new PSUs for me. I don't want something that's going to last a year then pop, taking out hardware when it goes. I've stuck with Enermax in recent times with the Liberty and Infiniti units.
Colour doesn't matter, braided cables help but are not essential, modular design is preferable. |
#9 |
Multimodder
I wouldn't have even considered where I had to RMA my powersupply until my last one broke and I found out how expensive it was to RMA abroad.
What I don't understand though is how many W I need to power my computer depending on the hardware, I think I tend to overcompensate in fear of overloading the power supply.
__________________
Main Rig: Antec P182, E8400, 4gb RAM, 8800GTS 512mb, X-Fi, Windows 7 Ultimate 64, Dell 2405, Sidewinder X6, G9 Server: Dell PowerEdge SC440, 2gb RAM, 1.5tb storage, Windows Home Server Laptop: Macbook 2.2ghz dual core, 4gb RAM iPhone 3G |
#10 |
Stuck in the Mud
Brand and output. I've only ever bought Enermax PSUs and they've been absolutely fantastic.
Things like box design are irrelevant because I buy PC bits online.
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3| Gigabyte GA-EX58-UD5 WD640 AALS | POV 8800GT | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP |
#11 |
I feel your presents.
If two or three reviews say it's good and it has the connectors/wattage I need, I'm sold. The last thing I need is to be connecting adapter cables to power multiple sata devices or gfx card(s) - there's enough cable mess in there already!
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#12 |
pretty fing wonderful
i buy whatever powersupply bbq says to buy.
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian notatoad.net fdo eff |
#13 |
Thread Necromancer
What I tend to look for is a good quality PSU that is recommened alot by others, the main reason is the last thing I want is a lame PSU that is gonna blow up and take my PC with it. So basically what ever anyone else suggests is what I get :P
EDIT: Oh, and Modular is a must if at all possible, I love being able to keep cables down to a minimum.
__________________
#14 |
CPC hang out zone (i Fix pcs i do )
i been useing thermalright toughpower PSUs for quite some time now (got an 1200w one here) apart form the heat when you use high end video cards in them thay are rock solid,
i used to use ernmax untill i had problems with 3 of them not wanting to Post in some intel motherboards and i blow one up, UPS was makeing the PSU (i asume PFC part of it) buzz after 11am at night {UPS was reporting strange mhz+voltage mhz would drop to 59hz from 60 and voltage would go to 245v} i could time it as well when it was going to happen i any PSU that is norm +80%/85% efficient is norm good but prefer to stick to brand names, i was temptend to get the ernmax 1000w one as i realy did like the protection stuff on that PSU but the price and the Noise of that 80cm fan put me way off it (thay need to remove that 80cm fan) the thermal right has an 86-87% efficiency as well as i have 2 pcs pulling, mine 600w other one 720w i norm should be getting 87% with these PSUs at that load still for low end jobs i do its norm an some cheap 400w £10 PSU (that most likey cant handle any more then 200W but the total load of pcs is norm 120W any way)
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947 |
#15 |
Made in Canada
Rails rails rails. Gimme a whooping big, single rail that's solid and consistent and I'll love you forever more.
__________________
[[Asus P6T | Intel Core i7 920 @ 2.67Ghz cooled by Noctua UH-P12 Push-Pull Config | 6GB DDR3-1600 Patriot Viper Xtreme XMP C8 | nVidia GeForce 280 GTX 1GB | Corsair HX620 620 Watt PSU | Antec P182 Case]] |
#16 |
Disgruntled kumquat
One thing you don't have listed is familiarity - I work for a PC shop over the summers, so I get to see first hand what works and what dies. Obviously, not everyone has contacts in PC shops, but it would be nice if you could establish some, and share the info.
__________________
The intellitxt demon fell dead, Sir Tim's lance embedded in its heart. The fair land of Bit-Tech was free from its influence once more. And there was much rejoicing. |
| Techno-Dann |
| Find More Posts by Techno-Dann |
#17 |
Custom User Title
Buy a powmax 450.
![]() ![]() ![]() I like a power supply that's well made, with good voltage stability, low ripple, and preferably quiet. I don't care at all about aesthetics, or modular cables. Sleeving is useful but not required.
__________________
Wowomg!! |
| Bbq.of.DooM |
| Find More Posts by Bbq.of.DooM |
#18 |
Weekend Junkie
Value for money.
Low ripple and noise. Efficient. Modular. Braided if possible or a supplier that does not give a damn if i braided it myself. (PC&C does not mind) The box can come as plain brown cardboard, with just a sticker on. I dont give a damn. As long as it does it's intended job. Laing DCC box springs to mind. Cheap and inobtrusive yet you know what it's contents is, because of a plain white sticker that says so. I actually hate the boxes that scream in my face "BUY ME". For one it's a waste of colours and the box is now slippery because they coat the box after they give it colour to protect it. I work in a warehouse. Any and all of our vacuum cleaners is in that kind of box. And i hate them. Because: You cannot drive around with a pallet full of them on a forklift. Turn at a greater speed than turtle and all boxes fall off because they are slippery. And that is even when they are wrapped in film. They slide around on the pallet, between layers and all over the place. Did i mention that i hate colourful slippery boxes?
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard. |
| Spaceraver |
| Find More Posts by Spaceraver |
#19 |
Yehehehessss!
Noise, solid voltages, efficiency, wattage and reviews are the most important. Most PSUs seem to be modular now a days so I don't really consider that a main selling point. Besides I've been getting along with my non-modular Antec 480 for almost 5 years now.
#20 |
Brand For sure
Like Enermax Then I look for wattage.
__________________
GigaByte Triton 180|GigaByte EP45-UD3LR|Intel Q9450|Transcend 4GB 1066Mhz|Sapphire 3870X2|Creative X-FI ExtremeGamer|Enermax Galaxy DXX 1KW|Samsung 2220WM|Thermalright Ultra-120 eXtreme|3TB WD Green The King Of CK Appreciation Society Group
| ComputerKing |
| Find More Posts by ComputerKing |
| Thread Tools | |
