#1 |
Richard Swinburne
bit-tech Staff
Akasa Blue Aurora
http://www.bit-tech.net/hardware/200...-blue-aurora/1
Today we look at the "Blue Aurora," the new high performance aftermarket heatsink from Akasa. With an exclusively LGA 775 mount and an included 120mm blue LED fan, can the Aurora light up our skies, or will it leave them overcast? Read on to find out!
#2 |
Get On My Horse!!!
Looks to be a good cooler. I may pick one up for my brother's PC.
__________________
Project: LEXA FINISHED 30/11/08 (16 months 14 days) MOTM Nominee October 08 Project: LEXA Revival FINISHED
#3 |
Hypermodder
I was going to get the noctua_NH-U12 but this looks sweet though I'd prefer a black fan with no glowy bits
#4 |
Get On My Horse!!!
It's easy to replace a fan.
__________________
#5 |
Made in Canada
Very nice review... it's been awhile since you folks recommended a cooler over the Thermalright of Noctua so Akasa is definitely on the right track. For those who want a quieter system, they can always pickup Noctua fans and mount them on the Akasa if the Noctua is too expensive (it's not that expensive here in Canada, and can be found on sale for around ~$35-$40).
__________________
[[Asus P6T | Intel Core i7 920 @ 2.67Ghz cooled by Noctua UH-P12 Push-Pull Config | 6GB DDR3-1600 Patriot Viper Xtreme XMP C8 | nVidia GeForce 280 GTX 1GB | Corsair HX620 620 Watt PSU | Antec P182 Case]] |
#6 |
Hypermodder
But is it worth almost twice the cost of a 965?
#7 |
I Mod, Therefore I Own
Not sure if Im missing it or not but what is the rated noise on this fan? I can only assume "loud" is about the right amount due to the CFM and the high ish rotational speed.
__________________
#8 | ||
Benchmarketeer
bit-tech Staff
At full speed it was just about audible over the test rig's fans, but not intrusively so. Obviously with the PWM connector, you'll probably be running a little quieter and you can always easily drop a lower noise fan into the fan bracket. |
#9 |
Ultramodder
This is probably one of the first coolers that is easy to fit.
I am also wondering , since the Thermalright U120E is ages old already, did Thermalright made any new cooler solutions that is outperforming their own 120E. For example the True Black 120. Any review in the works for that one?
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#10 | |
Benchmarketeer
bit-tech Staff
taken from the site - so not much point then
#11 |
Modder
The heatpipes must be staggered like the Coolermaster Hyper 212 ,to spread better the heat,not in a row one after the next
| Thread Tools | |
