Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 13th Sep 2008, 20:06   #1
daguuy
I hate lolcats
daguuy's Avatar
daguuy has yet to learn the way of the Dremel
Do air filters really affect gas mileage?
They say replacing an air filter will save me gas (which I might do since my car has over 170k miles), but to me it seems like a dirty air filter would just limit and amount of air that goes into the engine just like a throttle does. Would it really make a difference?
daguuy is offline   Reply With Quote
Old 17th Sep 2008, 06:32   #2
daguuy
I hate lolcats
daguuy's Avatar
It's probably been replaced by a previous owner (I bought it 6000 miles ago) but I wouldn't be surprised if it hasn't because there are so many other problems with it that should have also been taken care of (valve cover gasket, axle boot, coolant leak, dashboard lights, huge dents, completely worn out tires, etc...), though I've taken care of the more serious problems. Considering it's a cheap beaten up old car, I won't pour any more money than necessary into it so I'll just get a cheap one.
Reply
Tags
motors
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
