Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 25th Sep 2008, 21:08   #1
yanglu
Hmm...
yanglu has yet to learn the way of the Dremel
Furmark and crossfire?
Does anyone know if its possible to make Furmark stress a crossfire setup. At the moment with my two 3850's, running the benchmark puts the first card on full load and seems to ignore the second card, leaving it at 0% load. Does Furmark not have Crossfire support?
yanglu is offline   Reply With Quote
Old 25th Sep 2008, 21:55   #2
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.
Obvious questions: but is CrossFire enabled in the driver? Does it have the CrossFire connector between the cards and what drivers are you using?
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 26th Sep 2008, 18:59   #3
yanglu
Hmm...
Yes crossfire is enabled. I can see it through GPUZ. I've got both connectors connected and I'm using Catalyst 8.9
Old 26th Sep 2008, 19:21   #4
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
Do they both stress during 3DMark or a game?
mm vr is offline   Reply With Quote
Old 26th Sep 2008, 19:58   #5
yanglu
Hmm...
Yep I think so. They both stress under 3DMark Vantage so crossfire is working.
Old 13th Oct 2008, 03:15   #6
cynan
What's a Dremel?
cynan has yet to learn the way of the Dremel
If you want crossfire to work in Furmark, you need to rename the FurMark.exe to something with a crossfire profile in the drivers. Try renaming FurMark.exe to ETQW.exe
Before doing this I was getting a score of 4400. After the rename I got around 8500. (this was with 2 HD4850s at stock)
cynan is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
