RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Sep 2008, 08:11   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Silver Power SP-S850 PSU
http://www.bit-tech.net/hardware/200...-sp-s850-psu/1
From its Tagan roots we have an inexpensive, yet powerful 850W power supply from Silver Power. We find out if it's a wolf in sheep's clothing or bit of bling strapped to a brick.
Tim S is offline   Reply With Quote
Old 26th Sep 2008, 17:03   #2
tonschk
Modder
tonschk's Avatar
tonschk is on a distinguished road
Excellent review , I agree the heatsink looks small but each heatsink have many thin fins to improve dissipation, I like also because is not modular , was better if made with the single rail configuration
tonschk is offline   Reply With Quote
Old 26th Sep 2008, 21:18   #3
Jokkocze
Hypermodder
Jokkocze's Avatar
Jokkocze is on a distinguished road
Beware of Silver Power's psu's! We get Silver Power's various psu's alot at work (Komplett's returns department), and they've got a nasty habit of blowing up in your face. We get alot of them, and they're all pretty much the same. Some arent as loud as some others and some are worse.
They might be good when they're working, but they're a nightmare when they work. Do not buy!
__________________
Main rig: Intel C2D E8400 @ 3.91ghz | 6GB Corsair Dominator | EVGA GTX 280 SSC | ASUS P5E | 1x150gb Raptor & 3tb storage | 550w Corsair PSU | 2x Samsung T220
HTPC: Intel C2D E8400 | 2GB Corsair XMS | XFX 8800GT 512mb (Passive) | ASUS P5Q-VM | 4x1.5TB | 550w Corsair PSU | Sony 46V4500
Jokkocze is offline   Reply With Quote
Old 26th Sep 2008, 22:04   #4
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Interesting! How do they blow up? Which models exactly?
Bindibadgi is offline   Reply With Quote
Old 26th Sep 2008, 23:02   #5
Jokkocze
Hypermodder
Jokkocze's Avatar
I've got no idea what the models are called, if they have any name at all, but we get their 500, 600 and 850w psu's. Usually 2 or so per day, but sometimes more and sometimes less.
Their blowing up quite dramatic, compared to others (that I've seen). There's usually one loud bang and then a few quiet ones, while there's sparks flying, or something else that's really bright, around inside the psu. It's not uncommon that the protective cover (really no idea what the case is called) gets electrified and shocks you when you try to switch it off. A guy got a quite powerful shock from one, and got some burns on his hands when he were shutting one off.
If there's anything else you're wondering, you're welcome to send me a pm instead
__________________
Old 27th Sep 2008, 00:28   #6
Tile
Banned
Tile is on a distinguished road
Deleted
Tile is offline   Reply With Quote
Old 27th Sep 2008, 03:24   #7
wbdog206
Don't mind me.
wbdog206's Avatar
wbdog206 is on a distinguished road
i have had more deer psu's drop dead on me
than any other brand!
__________________
Of all the things I have lost,
I miss my mind the most.
wbdog206 is offline   Reply With Quote
Old 27th Sep 2008, 17:50   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Wow, well thanks for your valuable input!
Old 28th Sep 2008, 11:36   #9
tonschk
Modder
tonschk's Avatar
The Manufacturer is Tagan , I must check this info
Old 30th Sep 2008, 09:57   #10
Nanopoint
What's a Dremel?
Nanopoint is on a distinguished road
Greetings all.
These comments made by Jokkocze are very odd, as compared to the amount of system builders who purchase SilverPower from us, we have had no complaints on quality of these power supplies and a returns rate of less than 1%.
Jokkocze has stated that the 500, 600 and 850w psu’s all fail, however the new series of SilverPower have only been on sale for the past month. The comments given do appear to be a direct attack to tarnish the brand name.
I can assure all readers who have a SilverPower psu or those whom are planning to buy a SilverPower that they have nothing to worry about, these are high quality products as you will see from previous & future reviews.
Nanopoint is offline   Reply With Quote
Old 30th Sep 2008, 11:00   #11
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Thank you for your input and a balancing of the opinion
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
