Reply
Thread Tools View Mode
Old 24th Jun 2009, 12:49   #61
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Long time between updates my friend but well worth it, lovin the Blackbird.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 24th Jun 2009, 12:58   #62
MrBean
Supermodder
MrBean has yet to learn the way of the DremelMrBean has yet to learn the way of the Dremel
Was very busy at work, but having a bit more free time now. Will finish it pretty quickly, next couple of weeks.
Just need to get those fittings.....
MrBean is offline   Reply With Quote
Old 24th Jun 2009, 15:14   #63
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
I can't criticize your workmanship, because it's truly stellar. That being said, I'm a little concerned about your cooling loop. You'll have a pair of processors and a 4870x2 on a 240 rad, right? That's a whole lot of heat to pull out of the loop. Do you have any way test whether or not you'll be cooling limited before final assembly?
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 25th Jun 2009, 03:22   #64
MrBean
Supermodder
I have had this running on this rad before, and it did a fine job of cooling down the processors.
Much better than the stock aircooling could anyway, even in the heat of Melbourne in the summer. Thanx for your inout though, appreciated.
Old 25th Jun 2009, 20:15   #65
craigbru
craigbru's Avatar
Excellent news! I'll just sit back and look forward to updates then!
__________________
Old 26th Jun 2009, 08:00   #66
DonT-FeaR
I know what a fk'n Dremel is ok.:D
DonT-FeaR has yet to learn the way of the Dremel
looks good . like the black tubing looks good
DonT-FeaR is offline   Reply With Quote
Old 27th Jun 2009, 02:59   #67
MrBean
Supermodder
Thanx Guys,
Will keep ya'll posted
Old 27th Jun 2009, 03:14   #68
blackflag
I Kill Dremels
blackflag's Avatar
blackflag has yet to learn the way of the Dremel
That tubing screaming "TYGON R3400" every few inches is kinda distracting... maybe run over it with some rubbing alcohol to make it "unbranded"... just a suggestion...
Looking good otherwise!
blackflag is offline   Reply With Quote
Old 27th Jun 2009, 06:21   #69
MrBean
Supermodder
@ Blackflag: Thanx Mate, and yes, I will clean it off once the tubing is trimmed down to proper length, and I have the fittings on
Old 28th Jun 2009, 00:37   #70
MrBean
Supermodder
Hello Guys,
Just a short update - I have refitted the SAS drive-cage once again this weekend, with all 5 SAS drives (for now) displayed in all their glory - I am planning 8 drives for ultimate speed and reliability, as well as storage-space.
Here's a shot of the cage fitted, I will post another one from the rear at a later point in time:
and an angled one.....
Also note to the left of the drive-cage the standard (long) PCI-Card support bracket, often found in high-end servers, behind this support there is a decent 120mm fan providing airflow accross the drives, as well as cooling the cards in the "PCI-chamber"
For those that own Blackbirds, they know that there are unique thermal-zones, and the PCI zone is seperated by ducts from the top- and PSU zones. I will retain the zone-structure for this project, it works well, and will add to the overall clean look of the project.
Here's another pic of the pci-support mechanism...and you can make out the fan behind too in this shot....
Anyway, had to make a support bracket for the SAS Raid card, as it is very heavy towards the rear due to 2x backup support batteries for the batter write cache module.....
Here you can see the bracket fitted, and the 2 batteries I am on about....
Here's another shot.....
Here's the fron-half of the SAS card, with some memory-sinks I have fitted to cool down the CPU and controller chips....
and here's the card, exposed in all it's glory - it's a monster, really....
Everything will fit together like this....
and, finally, a shot from underneath.....
Enjoy it for now, feedback as always appreciated
Old 28th Jun 2009, 01:09   #71
Matticus
Matticus's Avatar
Matticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpit
Very elegant solution for supporting the card. I am loving this.
My only issue is with the tubing, whenever I see tygon tubing I just want to scrub off the writing
__________________
::i5 - 750::P55M-UD2::8GB Corsair::5850::CM Silent Pro Gold::F3 1TB::OCZ Vertex 2E::
::giffgaff::
Matticus is offline   Reply With Quote
Old 28th Jun 2009, 01:16   #72
MrBean
Supermodder
Thanx Mate.
Once I have the fittings, and trim down the tubing, I will clean it of any markings/branding et all
Old 28th Jun 2009, 07:41   #73
MrBean
Supermodder
Ok, a last update before the weekend's out.
I have properly secured the radiator, and fitted 2x 25mm fans to see how everything fits together.....here's a shot showing the front fan, clearing the CPU waterblock retention bracket by approximately 1mm.....I will anyway make my own retention brackets, these stockies look totally crap.
And here's a shot showing the rear fan, and the small piece I have to cutout from the fan-body to get the ATX and 4-pin connectors to fit - I can probably get them in, but will prefer to have an easier fit, so I will remove a small piece of the fan-body.
Close fit, as I have said.....
Here's another upside-down shot of the rad/fan fitment - looking rather nice....
Here's one, showing the 2x onboard fan-headers, which will make cable-run easy and clean....nice....
And here's a last one, right way up......I will get two decent fans to use, these one's shown here are for measuring purposes only....
Old 28th Jun 2009, 20:52   #74
haakon.t
haakon.t's Avatar
haakon.t has yet to learn the way of the Dremel
Just lovely
__________________
| Lian-Li PC-A08 | E6420 @ 3,2 GHz | Asus Radeon HD4890 | MSI P35-Neo | Corsair HX750w | 2TB | 4GB Corsair XMS PC2-8500 |
haakon.t is offline   Reply With Quote
Old 28th Jun 2009, 23:57   #75
Matticus
Matticus's Avatar
A set of slim (20mm) Yate loons or some of those slim scythe slip streams would go nicely in there. The only problem with both is the lack of static pressure.
Depending on how much you have to cut out of the standard fan, surely the fan blade is going to his the ATX connector, unless its not as close as I thin
__________________
::giffgaff::
Old 29th Jun 2009, 02:05   #76
The boy 4rm oz
Project: Elegant-Li
That is the biggest SAS card I have ever seen lol, even the support bracket you made for it looks beautiful. Everything it looking great, a real tight fit .
__________________
Old 29th Jun 2009, 09:12   #77
MrBean
Supermodder
Hey Guys,
Thanx for the replies
@ Matticus - the connector will be clearing the blade by at least 5-7mm, the photos are a bit deceptive.
Anyway, been playing with the fans a bit, and I have a very good solution to the problem - I will put the fans in a push configuration, ontop of the rad - you see, due to the shape of the case, the top is not horizontal, and when I made the fan-brackets, I had to built in a "tilt-angle" to get the fans horizontal.
Now, there's a gap between the top of the radiator, and the roof of the case, and if I drop the brackets by 15mm, the 25mm fans fit - and, best part, there is a 10mm clearance between the bottom of the radiator, and top of the otherboard then, and all cables fit very well, plus, the end result is a much sleeker appearance.
Neat. I will fab new brackets, and then have a very nice rad-grill lazer-cut to go where the fans are currently located.
So I could use a few Scythe S-Flex F's after all, they do a pretty decent job, and nice and quiet to boot....
Should look pretty decent.
Old 5th Jul 2009, 01:59   #78
MrBean
Supermodder
I have fired her up last evening, and I can say the 240mm Feser radiator is doing a great job! I had OCCT Linpack running for a few hours, and none of the 8 cores went over 44 deg C, while the GPU temperature increased from 28 to 34 deg C, testament that the CPUs are dumping a fair bit of heat in the water, but the system is doing a great job of maintaining equilibrium.....
So yes, to prove a point to all guys over at certain forums who told me you cannot cool all this hardware with a single 240mm rad......it does a very, very good job. You can throw anything at this system, the 2x CPUs, as well as the HD4870X2 (dual-GPU) stays cool and calm. Will run a few hours of 3dMark Vantage , but doubt it will make a ding in the temps.
Ah well, I'm pretty happy, now I neat to tidy the tubing - still need to get some Bitspower fittings, but at least the cabling on the non-motherboard side is all neat, and ready to go. Will post pics later.
Old 5th Jul 2009, 02:28   #79
docodine
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
Quick, someone send this to Rahul Sood.
http://www.rahulsood.com/
If you're lucky, he might help you out with the fittings you needed.
A+++++++ case regardless, amazing build. +rep
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Old 5th Jul 2009, 03:00   #80
MrBean
Supermodder
@ Docodine: The blokes over there are not interested in even sponsoring me with a plastic front-button panel, and a few pci-clips at the back.
Tried my best a while back, but generally got the run-around.
I guess they are to big now for us modders, especially now they're part of HP.
edit: I may be considering doing a different approach to the tubing, I may end up finally using all the 15mm dia x 2m lengths, and probably 50x elbow-bends I have. Will still think about this "rigid" approach I have wrt the tubing - I have a decent idea, but need 1 or 2 things before I can try it out.
Will keep you guys posted.
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
